Branch target offset too large for short
May 24, 2006 4:57 AM
I havent used this component in about 2 months however when I call any function from this component I recieve this error. "Branch target offset too large for short" Ive searched and turned up nothing.
I tested a really simple component that just returns the argument sent to it even that threw this error. Im testing with CF7 on OS X using Jrun4. Ill include stack below, any help would be awesome .
------------------------stack-------------------------------
The error occurred in /Applications/JRun4/servers/default/cfusion/BIGBLUE/v09/download/dlEn gine.cfm: line 5
3 : <cfif isDefined('ind_#ii#')>
4 : <cfinvoke component="COM.xDownload" method="tester" returnvariable="fixal3Ret">
5 : <cfinvokeargument name="test" value="1"/>
6 : </cfinvoke>
7 : <cfabort showerror="#fixal3Ret#">
Resources:
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3
Remote Address 192.168.100.86
Referrer http://192.168.100.86:8100/cfusion/BIGBLUE/v09/download/todays.cfm?mDi r=%2FVolumes%2F192.168.100.16&textfield=&mDate=05%2F24%2F2006&mTotPer= 6&mConstrain=1&mRecNum=10&imageField.x=60&imageField.y=12
Date/Time 24-May-06 06:54 AM
Stack Trace
at cfdlEngine2ecfm322549419.runPage(/Applications/JRun4/servers/default/ cfusion/BIGBLUE/v09/download/dlEngine.cfm:5)
org.apache.bcel.generic.ClassGenException: Branch target offset too large for short
at org.apache.bcel.generic.BranchInstruction.dump(BranchInstruction.java :99)
at org.apache.bcel.generic.InstructionList.getByteCode(InstructionList.j ava:980)
at org.apache.bcel.generic.MethodGen.getMethod(MethodGen.java:587)
at coldfusion.bytecode.JavaAssembler.getBytes(JavaAssembler.java:369)
at coldfusion.compiler.FunctionAssembler.assemble(FunctionAssembler.java :56)
at coldfusion.compiler.TemplateAssembler.assembleFunctions(TemplateAssem bler.java:255)
at coldfusion.compiler.TemplateAssembler.assemble(TemplateAssembler.java :66)
at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:30 8)
at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:10 6)
at coldfusion.runtime.TemplateClassLoader$1.fetch(TemplateClassLoader.ja va:282)
at coldfusion.util.LruCache.get(LruCache.java:188)
at coldfusion.runtime.TemplateClassLoader$TemplateCache.fetchSerial(Temp lateClassLoader.java:223)
at coldfusion.util.AbstractCache.fetch(AbstractCache.java:58)
at coldfusion.util.SoftCache.get(SoftCache.java:81)
at coldfusion.runtime.TemplateClassLoader.findClass(TemplateClassLoader. java:422)
at coldfusion.runtime.RuntimeServiceImpl.getFile(RuntimeServiceImpl.java :662)
at coldfusion.runtime.RuntimeServiceImpl.resolveTemplatePath(RuntimeServ iceImpl.java:629)
at coldfusion.runtime.TemplateProxyFactory.getResolvedFile(TemplateProxy Factory.java:509)
at coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFact ory.java:617)
at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:341)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210 )
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:5 2)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePers istenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter. java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:7 8)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java: 259)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java: 541)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.j ava:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
