• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFMX falls over
Guest
Jul 26, 2006 Jul 26, 2006
Regarding a moment of clarity and frustration with issues relating to server consumption (tb) and the following long running threads (insert irony here)
http://www.macromedia.com/cfusion/webforums/forum/messageview.cfm?catid=143&threadid=776647
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?catid=143&threadid=907581&enterthread=y
AND also just casually browsing the following article,
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_19438
AND the fact that everything these days is a webservice or a component call, is it perhaps a MASSIVE problem that the following tags (which I'm sure everyone must be using) DO NOT obey server settings relating to thread timeouts etc:
-cfstoredproc,
-cfcontent,
-cfftp,
-cfexecute,
-cfobject
Imagine thread request 1 asking for a cfobject on something that won't respond, and a similar (say) X requests come in, thus hogging your X setting of possible threads running making it impossible for any more requests to be processed and thus giving the appearance of CF being broken (though necessarily it may be saying "I'm alright jack, just running my X requests")
You are then screwed are you not or am I missing something?
Views
901
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Aug 04, 2006 Aug 04, 2006
does anyone even have a single thought on this or is it just too hard? I see plenty or replies to posts about "my sql statement doesn't work" etc.
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 08, 2006 Aug 08, 2006
I think your right - it's just too hard for Adobe. We spent our $500 with Adobe and for 6 weeks we sent them logs and code and configuration file settings to only have them give up and say they have no clue. Save your money on Adobe. We are now looking into a Java Memory Profiler and CF Enterprise so we can run multiple instances and hope that all the instances don't crash at the same time. (Insert more Irony here - CF dosn't work well so we buy more CF?!?)
We also purchased Fusion Reactor which can kill those long running threads for you either manually or on it's own based on a time limit you set. Yes, I know this is not a solution, it's just a reaction (hence the name of the product) to the poor programming in parts of ColdFusion.
Our problem is we are seeing an issue where a thread or threads won't die completely and then memory builds ups over a span of about 20 minutes. Some others in other threads noted it takes hours to see the memory max out. The reason ours maxes so fast (at 1gb of memory for the JVM) is that we average 10-15 simultaneous requests/second. The hardware is big and massive and the CPU usage is about 33% across all 4. We are using Fusion Reactor (FR). It shows the threads that are running and the ones that are not releasing. We have FR set to kill long running threads, but that does not always work. We can almost guarantee that when a thread gets killed we are going to have a crash in about 20 minutes. It happens so much that I wrote a BASH script that runs every minute and checks to see if our web service is still responsive and does a CF Restart when it fails the response test twice. At this lets us sleep at night.
Votes
Translate
Translate
Report
Report
Guest
Aug 09, 2006 Aug 09, 2006
thx wil.
The multiple instances will not really do the trick without some planning. For example if you have appA shared/ balanced accros instance X and Y, and appA relies on WebService Z going off somewhere else and this is hanging, then both instance X and Y will go down. The only viable solution I can think of is to have parts of the appA split into basic stuff that can timeout correctly on instance X and stuff that doesn't obey timeouts on instance Y and use a scripty thing to determine if a user useing appA can actually do the cool stuff on instance Y (perhaps displaying messages like "service unavailable" or something). but this seems like a lot of work for something that should be simple. Remember, CF is supposed to be RAD.
The Thread killing stuff is a nightmare, as far as I can see it always will knock over the server.
I looked at Fusion Reactor before, but never got it, just checked out their site, they have a nice debugging thing coming out soon.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Actually we are moving onto a fully clustered environment. It won't be easy or cheeap, but we have to improve our service and uptime. Everything will run from multiple servers with mutile instances of CF. We have 4 db servers, 4 photo servers in place already. We are adding a cf server and a load balancer machine.
So, this should overcome CF's weak points.
Votes
Translate
Translate
Report
Report
Resources
Documentation
