RoboServer 7 fails miserably
Jun 17, 2008 9:41 PM
I recently upgraded to RoboHelp 7, RoboSource 3.1 and RoboServer 7. My issue is with RoboServer.
RoboServer 6 was working relatively well. I have two servers, one for Test/Development and one for Production. Our team maintains about seven seperate RoboHelp projects. I am a Technical Author in the team, and I am also a MCSIE Server admin and IIS admin.
I installed RServer 7 on the Development server first. Straight away, there were issues, particularly with the constant protocolhost.exe error messages generated by the Windows 2003 server. Once I cleared these error messages (about seven, just clicked OK and continued) I configured the RServer, set up the virtual servers for our separate projects and published.
So far so good, although it took me a whole day to get this far.
Access to the development server is fairly limited, but it all seemed OK, so I went ahead and planned the upgrade for the Production server. I waited for scheduled downtime, and gave myself 6 hours to do the job, called in the other two Technical Authors for the 9PM downtime, and proceeded to upgrade from RServer 6 to RServer 7.
Once I set up the configuration, I decided to re-boot the server just to be safe. Again, a constant stream of protocolhost.exe errors had to be cleared, and I could not see any reference to this in Adobe's knowledge base, although a Google revealed that I wasn't alone dealing with this issue. However, once it "stabilised" I proceed to publish our projects and test them.
All appeared OK in the end.
The next day, I received a message that no-one could open the On Line Help in Production. Sure enough, the server was down. It had re-booted itself. The event log revealed an issue with RServer 7 and protocolhost.exe. I also noticed that the RoboHelp Service had stopped, so I re-booted the server. Heaps of protocolhost.exe errors again, and I could not view the projects in the RServer Config panel. Restarted IIS and had some luck. Left things as they were for a day or two, but again, the server went down and no-one could access the On Line Help. I checked the Development machine, and it was also in the same stae.
I uninstalled RServer 7 and re-installed RServer 6 on both servers. This has stabilised the system somewhat, but I still have to re-boot the servers about once per week and I still get several protocolhost.exe errors when I open the RServer Configuration panel.
I tried contacting Adobe, to no avail (no surprises there). I asked any others at a recent conference, but no-one I spoke to is using RServer. Our systems are dependant on RServer, and it worked very well when it was an eHelp product, so there is legacy there. I have submitted a case to our section management to change over to Madcap software, but will need to maintain RServer and RHelp for a year or two, and I am sick of this constant problem. Has anyone here got any advice for me?
    Jul 3, 2008 7:56 AM   in reply to Frank Munday
    Has ANYONE got RH7 to publish successfully to RH7 Server? If so, what's your secret? We continue to get Connection Failed - Native Error messages when publishing and have resorted to manually publishing. Just out of curiosity what are you running RH7 Server on? Windows 2003 server?
    Jul 4, 2008 1:55 PM   in reply to Frank Munday
    Did you actually get your money back?
    Jul 6, 2008 7:41 PM   in reply to Frank Munday
    Could you please post back here once Adobe gets back to you? Just let us know how they fixed the problem (if they in fact fix it). I am also about to try to escalate our server issues with Adobe. Thanks.
    Jul 8, 2008 2:25 PM   in reply to Frank Munday
    We had the same error messages when trying to publish. There was a service that was supposed to be set to re-initialize on its own, but wasn't. Once we fixed that it worked, but it quits about once a week, we reboot, and everything is peachy.
    Jul 14, 2008 10:02 AM   in reply to Frank Munday
    We too are having similar problems. The RoboHelp (7) Server Service does not crash, but end users receive errors, typically HTTP 500, the web site can not display the page. There are a slew of Protocolhost.exe errors when I log on to the server. We were having the troubles on a virtual server sharing resources with other applications, so we decided to dedicate a server. Things seemed fine until a number of projects were published. It is a shame that one has to pay for support to get help getting something they paid for to work. Our technical writing department is looking into alternative software.
    Jul 15, 2008 8:47 AM   in reply to Frank Munday
    Has anyone been able to get a response from Adobe on this issue yet? I can find no acknowledgement of this issue on their site. My department has a large merged project that is dependent on getting this server issue resolved. Unfortunately, when we were evaluating RH7 we did not discover this issue. It reared its ugly head once we decided to start rolling out the product.
    It's pretty laughable now, but when we evaluated Madcap Flare, we thought it might not yet be ready for prime time and that the learning curve would slow us down, so we opted to upgrade to RH7 for the time being, figuring we would get a few enhancements without having to slow down to accommodate a new tool.
    12. ,
    Jul 22, 2008 1:04 PM   in reply to Frank Munday
    We have a support package and Adobe has still not been helpful. When I call, I am told that they are aware of the issue and there is no fix.
    When users attempt to upload projects, they fail with the "native" error. It seems that these errors would generate a "dynaZIP error" on the server and the popup would reference files in a Windows temp directory. When investigating, that I found that there were a large number of RHS*.tmp files in the c;\windows\temp directory (65535 to be exact). Since 65535 is the largest 16 bit binary number, could there be an issue with the DynaZip toolkit that Adobe looks to be using for compressing the help systems for upload?
    Does anyone else see a bunch of these temp files on their Win server?
    Jul 22, 2008 1:50 PM   in reply to gomuc88
    For some reason our Robohelp server has settled down and worked better for the past week. First we moved it from a VMWare instance which it shared with a couple of other apps because it seemed to work OK at night when few were using the system. We still experienced a lot of problems, but our Technical Writing department noticed that it seemed to misbehave worst after a project was published. We began doing the publishing at the end of the day, and the projects are reindexed nightly. There is still some quirky behavior, but not the consistent HTTP 500 errors we ecperienced before. Unfortunately this doesn't help those having problems publishing.
    Jul 23, 2008 9:49 AM   in reply to gomuc88
    I, too, was hoping to use RoboHelp Server 7. I'm having the same problems as the others. Details in http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=6 5&catid=447&threadid=1353841&enterthread=y
    Aug 11, 2008 8:39 AM   in reply to MrPuck
    Any updates anyone?...Success stories?
    Aug 18, 2008 8:40 AM   in reply to Frank Munday
    Hello, I have been reading this thread with great interest. I am considering implementing the RH7 Server solution for the first time, but am really not sure I have 1/2 a clue as to whether it will work or not. Would there be anyone who is currently working with this solution who would talk to my about this approach? trials? pitfalls? cautions? recommendations?
    pepy3
    Aug 18, 2008 8:55 AM   in reply to Frank Munday
    Maybe wait until RH Server 8 and hope they fix the issues? Just my opinion after six months of headaches and not getting anywhere.
    Mar 12, 2009 9:57 AM   in reply to hughbetcha
    Here's my 2 cents on the Protocolhost.exe errors. Hope this blog isn't deadended - no updates since August? We just recently put up RH Server 7 on a Windows 2003 partitioned server. We've only had this system up for a week. Yesterday, my response time to open my project was very slow but working. I re-booted the server and everything worked...for a day. I spent the afternoon searching on the Protocolhost error - since I saw about 10 of them (historical references) as server came up. This morning, I received HTTP 500 errors when trying to start new project sessions. Sure enough, I was receiving Protocolhost.exe errors everytime I'd try to view my project on Configuration Manager or open it through the server website from a browser. The user rec'd HTTP 500 connection errors. I thought Scott_I had a good point about the temp files and persued that aspect. He wrote "When users attempt to upload projects, they fail with the "native" error. It seems that these errors would generate a "dynaZIP error" on the server and the popup would reference files in a Windows temp directory. When investigating, that I found that there were a large number of RHS*.tmp files in the c;\windows\temp directory (65535 to be exact). Since 65535 is the largest 16 bit binary number, could there be an issue with the DynaZip toolkit that Adobe looks to be using for compressing the help systems for upload?" So, I decided to delete these RHS*.temp files. There were over 51,000 of them created just in the month and half we worked to get RHserver up and tested. After I deleted them one Protocolhost.exe error showed up in the event viewer. Without rebooting I was able to, though slowly, connect from the Configuration Manager but still got HTTP 500 from the website - a time out? Tried again from the Config Manager and got HTTP 500. Looked at the temp directory and found 544 new RHS*.temp files just created in the last 5 minutes. Delete them. And waited about 10 minutes. (This is starting to sound like a recipe)
    I then tried to view the project from the Config Manager again and it worked. Looked at the temp file folder and found 14 newly created 202kb RHS*.temp files. I tried connecting through the website and it worked too. 2 hours later... no new/additional temp files are being created even though I starting Config Manager views and several web connections - quickly. So, conclusions? Clearing out the temp files appears to help as does letting the server 'catch up' by waiting to start applications until the network is ready? The fact that my 'working' system is not creating Protocolhost errors and appears to use the 14 temp files initially created may be what should happen - Not the 2kb 51,000 temp files over time. We'll see as we go on.
    Mar 12, 2009 1:47 PM   in reply to rune1io
    I have been unable to fix this problem, so I have settled into a routine whereby I take the server off the air, uninstall RServer, delete all the databases and temp files, delete the sites in IIS and reboot the server. I then re-install and re-publish everything, and it works OK for about a week before trouble starts again.
    I have met with the applications team and we have a solution in place for when we roll out Madcap Flare to the Tech Writing team. It's kinda sad, really, as I have been using RoboHelp since it first came on the market. I was among the first users of Roboserver (then known as Enterprise Server) which was a great move at the time.
    End of an era, as far as I am concerned.
    Mar 12, 2009 2:04 PM   in reply to Poppachoc
    We had the same problems after upgrading to RoboHelp 7. Our organization ended up biting the bullet and moved to a different solution.
    Mar 12, 2009 3:22 PM   in reply to gomuc88
    Hi all
    As many of my posts in these forums will attest, I've never been a fan of the RoboHelp Server. There always were too many unanswered issues surrounding it and I failed to see the real benefit when publishing plain old skinned WebHelp to a regular Web Server worked just dandy.
    However, if any of you are still enamored with whatever it was that made the RoboEngine or RoboHelp Server attractive to you to begin with, you may wish to investigate the RoboHelp 8 Server. I understand it has been rewritten from the ground up. Supposedly it no longer relies on Windows IIS and is simpler to configure and maintain.
    Then again, if you already have a sour taste in your mouth I totally understand. I just hope you feel that changing the platform will be worth it in the long run.
    It would be interesting to see what you find (or had hoped to find) the RoboEngine or RoboHelp Server provided that you didn't have with the typical Web Server.
    Cheers... Rick
    Mar 12, 2009 4:02 PM   in reply to Captiv8r
    If I could add my three cents. While this may not be satisfactory for those using the older eHelp technology of RoboHelp Server 7, my advice is to upgrade to the newer Adobe technology of RoboHelp Server 8. The Adobe team has completely re-written the code from the old eHelp Corporation's product. It is now Java-based.
    While there are many benefits to using RoboHelp Server 8, the two main ones are the Feedback Reports and a much more granular and robust "permission/access". I agree that in the past, the old RoboEngine which was based on technology from 7 or 8 years ago was not easy to install and because of the necessity to integrate with Windows IIS, was fragile to maintain (the old Protocolhost problem).
    I am happy to report after installing it on three machines, that this has changed with Adobe RoboHelp Server 8. (Also, you can still use RoboHelp 7 "client" to publish to the new Server 8.)
    You can read more about the installation process in this thread.
    RoboHelp Server 8
    It is easy to create "protected areas" for groups to gain access to the RoboHelp content. This is good for companies with security concerns and needs to restrict access to content. Also these separate groups and sites do not require extra licenses. You only need one license.
    The server software is no longer limited to just Windows IIS (although it can co-exist with IIS). It is based upon the open source Apache Tomcat Server (free) and then RoboHelp Server (a Java app) is installed on Tomcat. It is then configured with SQL Server (or SQL Server Express) for the database support.
    This provides a much easier installation and configuration as well as a lot more flexibility in how you deploy it to different groups within the company. The search engine is vastly superior and uses the versatile Apache Lucene Search Engine (which is installed automatically). I think it is a positive thing that Adobe is embracing more open source standards.
    I am not an IT person by any stretch, but just following the documentation, I was able to install and configure Adobe RoboHelp Server 8 (and even the Apache Tomcat piece) on my laptop (Windows XP) and have it work as advertised in less than an hour. This is a far cry from the fragile eHelp/Macromedia RoboEngine. Adobe obviously
    paid attention to the long-standing gripes about the old eHelp/Macromedia RoboEngine and IMHO has done a nice job of re-tooling the server.
    I would encourage you to download the trial and see the differences. No robust Server application setups are ever trivial "single click" manuvers. That said, I think you will like the installation and maintenance of the new RoboHelp Server 8.
    Thanx,
    john
    Apr 28, 2009 11:53 AM   in reply to Captiv8r
    Rick Hi
    I am considering the RoboEngine 8, however, I am concerned about all of the negative comments I have seen with previous versions.  My draw to the server edition is the ability to get feedback from the end users of our products.  Also the ability to generate reports on search terms, where users navigate etc. are of great importance in making future improvements to our online help.  Are there additional benefits that I should be aware of as well?  Could you elaborate please?  Also does Adobe have any classes, Webinars, or consultants that could help in gaining a better understanding of the new RoboEngine 8 and help to set it up and integrate it with RoboSource Control?
    I currently have RoboHelpX7 and I did have some initial issues when I upgraded to x7 from x6 previously, but I believe I have resolved all of those issues.  I would also like your opinion on the Technical Communication Suite 2 that is available.  I'm drawn to that because of the inclusion of FrameMaker that can handle printed documentation much better than exporting it into printed documentation from RoboHelp into Word or a PDF.  I also see that FrameMaker is integrated with RoboHelpx8 in this package and when you make a change in FrameMaker you can also update or add the info to a Robohelp project topic with minimal assistance.   There are also other products included in this package.
    Has anyone purchased the Technical Communication Suite 2 product and if so, what was your experience?
    Lana
    Apr 28, 2009 4:45 PM   in reply to blmjohnson
    Hi Lana
    I am really hoping the help developer experience for RoboHelp Server 8 is much improved over its predecessors. I've heard good things from my fellow Community Expert and Certified Instructor John Daigle.
    From what I understand, the underlying engine powering this has been re-written from the ground up. It no longer relies on Microsoft IIS and instead runs on a more common Web platform.
    Sorry, but I'm unaware of any classes or Webinars for it. And the only consultant I'm aware of is my dear friend John Daigle. (There may be others around, but I'm unaware of them) Personally, I'd love to know more about it but am unable to install it and configure to play.
    Please note that RoboHelp Server DOES NOT integrate with RoboSource Control. They are two totally different applications that are used in totally different ways. You install RoboHelp Server on your Web server. It is used to provide dynamic merging of outputs, reporting and the other features you mentioned. You install RoboSource Control on a different server. Possibly a network server on a LAN to provide project sharing among multiple authors and it serves as a weird hybrid between a Librarian, Historian and a Traffic Cop.
    • RoboHelp Server = Uses only RoboHelp OUTPUT
    • RoboSource Control = Manages only RoboHelp SOURCE
    Okay, first let's get some terminology right. There is not (nor ever has been) any version of RoboHelp X6, X7 or X8. X5 was logically "lucky" version 13 of the product. Because Adobe saw the "5", they quite simply named logical version 14 version "6". Keeping in lock step, version 7 and finally version 8 has emerged. So it's quite simply Adobe RoboHelp 6 (or 7 or 8) .
    I think Technical Communication Suite II (TCS 2) is pretty cool. I have installed it and am using parts of it. Note, however, I am *NOT* a FrameMaker user. If you have never used FrameMaker, prepare yourself for a learning curve. Unfortunately I've not found anything that shows you how to do things in Frame. I opened it up and was immediately baffled. The workflow for TCS 2 is this. Author in Frame. Take that Frame content and pop it into RoboHelp for your Web outputs. Output to PDF from Frame. I don't believe an easy path exists to take RoboHelp content and migrate it upstream to Frame. Included in TCS 2 is Photoshop. Yet another complex application. I have no clue how to use Photoshop so cannot help you there.
    I'm not sure if you will see responses to your final question as you seemed to direct at me in the beginning. Unless, of course, you are asking me if others have purchased the TCS 2 product. You may wish to post that separately in a new thread if you are seeking opinions of other users.
    Hopefully I've helped more than hindered here. Rick
    Apr 28, 2009 10:52 PM   in reply to blmjohnson
    Hi Lana,
    You can also check out the following links for some info about RoboHelp Server 8
    http://blogs.adobe.com/techcomm/2009/03/adobe_robohelp_server_8_instal lation.html
    http://forums.adobe.com/thread/88064?tstart=0
    Tulika.
    Apr 29, 2009 8:47 AM   in reply to rune1io
    Here's a folow up on my previous entry. We have a working RH 7 Server environment and have circumvented the ProtocolHost.exe issue with weekly deletes of the RH temp files in the Windows directory and also weekly refreshes of the server. With one caveat. Our usage of the Web Server at this time is very minimal.  My experience upon investigating the ProtocolHost.exe errors are summarized below.
    The  "ProtocolHost.exe encountered a problem and needed to close error" is inconsistent to the execution of RoboHelp's server starting a web session under the server link. The start of a web session may or may not issue the error. One observation is that when RoboServer's 'Configuration Manager Troubleshoot' log issues the message "Error messages were returned from IndexCreator", the ProtocolHost.exe error does not occur. And conversely, when the ProtocolHost.exe error is issued at the start of a web session, no "Error messages were returned from IndexCreator" are logged in the Configuration Manager. I've tried to investigate the "IndexCreator" message to no avail and I don't see any messages in the event log about a failure or restart when this occurs. Generally, it appears that RoboServer 'wakes up' with the request and the ProtocolHost.exe error occurs. It fails in module ntdll.dll located in the server's C:Windows\System32\ntdll.dll.  The ntdll.dll file is a file created by Microsoft that has a description of "NT Layer DLL" and is a file that contains NT kernel functions. The Ntdll.dll file is also the subject of a MicroSoft Security Bulletin regarding an unchecked buffer that could cause server compromise. http://www.microsoft.com/technet/security/bulletin/ms03-007.mspx Why Windows 2003 needs it is another story. Server 2003 is listed as the only server software Not Affected by the service bulletin. This module is a core operating system component that is used by WebDAV, a set of extensions to HTTP that provides a standard for editing and file management between computers on the Internet, - something RoboHelp Server does.
    Another observation: Each time the web sessions load from Explorer and Mozilla, there appears to be a performance issue depending on the speed of the load. And once the session is started, the load of the index in the session (a secondary load?) comes in late if at all to the session. I've actually had the initial load work but the index button section show an HTTP 500 screen within the loaded session. Thus producing a partial session if you will. Other times I can scroll down the index and watch the application 'feed' the next section of index items on the 'speedometer' at the bottom of the screen as it 'calls' them from the server. When loading the seesion from an HTML file there is no delay and no apparend secondary index load. The entire session with the full indexing and print button is available at once. Something is delaying and possibly stopping the load from the server.
    Feb 9, 2010 2:25 PM   in reply to rune1io
    Update on ProtocolHost.exe error
    After nearly a year of production use of the RH 7 using RH7 Server, I've had little problem with the server crashing or hanging due to the following error:
    Reporting queued error: faulting application ProtocolHost.exe, version 0.0.0.0, faulting module ntdll.dll, version 5.2.3790.4455.
    This error seemed to occur with no consistency (see above entries).  But if it occurred too many times in a server session, the server's response would degrade and sometimes hang.  My initial solution was to weekly reboot the server and delete temp files created at execution of calls for the RH application's web site.  This "kept the problem at bay".
    Now the mystery.  After many fingers pointing to RH 7 Server about this problem, I've found that the error has not occurred since early November as reported in the server's event viewer. In fact there has not been one application error posted to the viewer since November.  RH 7 user usage has increased dramatically over the last few month's. It is the only application on the server.  I have no explanation for this miracle and haven't changed a thing to the RH releases of RH7 and RH7 server. This leads me to believe that something in the server environment changed - perhaps a Microsoft update to the ntdll module or something. This would seem to vindicate RH server software unless it too was upgraded through server or network upgrades.
    Regardless, the problem appears to be solved in my environment.
    Feb 9, 2010 3:30 PM   in reply to rune1io
    Good to hear, rune1io
    What Windows Server OS are you using and what .NET Framework version is running now and was there a .NET framework change back in November? That may having nothing to do with it, but I seem to see more updates for .NET Framework than anthing else.
    Regardless, I appreciate your posting this for others who are still using RHS v7.
    John Daigle
    Adobe Certified RoboHelp and Captivate Instructor
    www.showmethedemo.com
    Feb 10, 2010 8:25 AM   in reply to John Daigle
    Hi John,
    Not sure how to find the .net framework we're on. Is it in: C:\WINDOWS\Microsoft.NET\Framework ? If so, there is no last update info around that date.  I'm attaching a WordPad file that shows our event viewer for Security, Our Last Application Error, and System events all around the 11/10/09 Time frame that this appeared to fix itself.
    I'm not a server guy (but I play one on TV), but my suspicion is that maybe the Service Pack installed (highlighted) later that day had the framework change that took care of it.
    Jim
    Jim Dages
    Technician II
    Payroll & Benefit Services
    University of Colorado
    3100 Marine Street, 6th Floor
    Boulder, CO 80309-0575
    (303) 735-5495
    jim.dages@cusys.edu
    Please consider the environment before printing this email.
    CONFIDENTIALITY NOTICE - This e-mail transmission, and any documents, files or previous e-mail messages attached to it may contain information that is confidential or legally privileged. If you are not the intended recipient, or a person responsible for delivering it to the intended recipient, you are hereby notified that you must not read this transmission and that any disclosure, copying, printing, distribution or use of any of the information contained in or attached to this transmission is STRICTLY PROHIBITED. If you have received this transmission in error, please immediately notify the sender by telephone or return e-mail and delete the original transmission and its attachments without reading or saving in any manner. Thank you.
    Feb 10, 2010 9:23 AM   in reply to rune1io
    Hi, Jim.
    Boulder? Ha. I'm up the mountain from you in Evergreen .
    I guess your WordPad attachment hasn't made it through the moderation yet. Meanwhile, I believe you can find out the .NET Framework from the Add/Remove Programs in Control Panel.
    Also, I think if you go to Windows Update you can give your "Update History" which will list all the updates and dates they were installed.
    john
    John Daigle
    Feb 10, 2010 9:58 AM   in reply to John Daigle
    John,
    There are 3 .NET Frameworks in Add/Remove:
    2.0 Service Pack 2
    3.0 Service Pack 2
    3.5 SP1
    Update history reveals One November 4, 2009 Automatic update to Windows not Windows Server 2003.  Its Windows Update Agent 7.2.6001.788 but this was before the problem fixed itself. All other Server updates were in September and December.
    Try a Docx version of the log.
    Thanks for your interest.  This ProtocolHost error was my reasoning for moving to RH8.  We're thinking of expanding our RH usage to a second website and I know the Server software is all new in RH8. Now that the error appears resolved, I'm not sure what to do. We had such a hard time getting one website working with the server in RH7.
    Jim
    Jim Dages
    Technician II
    (303) 735-5495
    jim.dages@cusys.edu
    Apr 5, 2010 9:35 AM   in reply to rune1io
    Update to my Protocol Host.Exe experience.  Amazing.. It's baaaaack. After over 4 months without an application error on the server, the ProtocolHost.exe error returned on our system on 3/22/10 at 10:30 am.  I noticed that when I loaded a copy of the application from the server, it hesitated to load the index portion of the web RH application.  This was the issue when it was generating Protocol Host.Exe errors before.  I logged onto the server and sure enough the errors were back. Once again, I've seen it load a partial copy of the web RH application - meaning the opening document loads but the Contents pod shows a generic NT 500 network error (indicating time out?).  This error is not consistent with each load but almost every request to load the application from the server, generates the Protocol Host.Exe error to the server event log. Our server support group brought the server up to current patch maintenance with no improvement to the errors. They are still investigating - details for the work ticket are below.
    RoboHelp partitioned server PBSRobohelp has begun logging ProtocolHost.exe errors again in the Event Viewer Application section. This error affects the RoboHelp server\'s delivery of the application by not loading the search feature to the client. We worked and identified this last year. Miraculously, the error quit occuring on 11/10/2009 at 11:01. The Robohelp application had no errors until 3/22/2010 at 10:30 (see attached screen print). There has been no change to the application environment before or during these time periods. Something appears to change in the server environment to cause this. Please investigate what changes to the server environment occured around 3/22/2010 that may have affected this application. Thank you
    May 5, 2010 12:52 PM   in reply to rune1io
    The sad thing is I may be the last living human to be using RH Server 7.  But I think I've found what's causing the Protocol Host exe error.  I also have a simple 'work around' based on my findings. Sit back with a cup of joe, read it and weep.
    History of the RoboHelp Server Protocol Host exe issue
    After intense investigation of the Protocol Host exe issue with RoboHelp (RH) Server 7, I believe I understand what is causing the problem.  RH 7 Server builds temporary files in the C:\Windows\Temp directory when the first client session is requested through the RH 7 application website or by a RH Server routine that runs at midnight every night.  These files appear to be the storage for the index as it is loaded to the application.  And I believe they are reused with each session requested from the server – this is key. They also are not deleted by Windows after a session ends or the server is brought down.  Our site has been running a weekly routine to delete all RH temp files in order to keep the count of temporary files down because of the Protocol Host exe errors.
    In our environment I noticed that if all the RH temporary files were deleted before a session was requested from the server, the server would create temp files with the date and time stamp of the client request (approx. 14 to 116 files in our case).   But I also noticed that 4 RH temporary files dated from months before also appeared in the directory.   The first session requested from a fresh server session does not generate a Protocol Host exe error to the application event log. But, during its initial load, once it creates the first set of temporary files including the 4 previously dated files, any subsequent sessions:
    ·         Work (“over time”) to load the index, laboriously loading as the server application tries to create an index.
    ·         Or will partially load the index leaving a ‘loading index’ message in the application pod
    ·         Or will not load the index at all (leaving a ‘network 500’ message indicating a timeout inside the index pod of the application)
    And all these subsequent sessions:
    ·         Receive the Protocol Host exe error in the Server’s event log
    ·         Send an “Error messages were returned from the IndexCreator” message in the Troubleshoot log  of Adobe RH Server Configuration Manager
    ·         Create more temporary files for each session including 4 more of the same previously dated files
    Success
    I simply deleted the 4 ‘rogue’ previously dated temporary files and requested a client session from the website in order to test.
    The session loaded like lightening and the index was immediately (completely) there:
    ·         No  Protocol Host exe error
    ·         No “Error messages were returned from the IndexCreator” message
    ·         No additional temporary files created
    I started 3 more sessions with the same non-errant results.
    Testing
    With a new server environment after a reboot and with no RH temp files in the Windows directory, the initial session request created temp files with a time stamp of the request time and a set from the previous session (from the registry?) and the 4 temp files that are suspected to be corrupt.
    These 4 files are named differently with each load but have the same “date modified” time stamp each time they are loaded.
    -          RHxxxx.tmp       2/25/09 3:28 PM
    -          RHxxxx.tmp       2/20/09 3:12 PM
    -          RHxxxx.tmp       3/03/09 2:43 PM
    -          RHxxxx.tmp       3/13/09 9:28 AM
    This is different (corrupt?) from the other temp files that are date and time stamped based on the time the system builds an index.
    Once I deleted all suspected corrupt files (found by listing the directory by the date column), I loaded as many as 6 client sessions within about 10 seconds with no new temp files created and no corrupt files sent to the temp file folder.
    Now, I suspect that the reason these ‘rogue’ temporary files are showing up is that they are somehow associated with the server’s registry. They are pulled in when the server loads temp files during its midnight routine or the first time an application session is requested and uses that corrupted set the server created at midnight. Each requested session appears to create its temp files in sequence Alfa-numerically. RH or Windows must keep track of its last used number and start with the next number each time. The 4 rogue temporary files are recreated with names that are in sequence with the other temp files being created.  But the rogue files create times remain the same.  The first rogue file seems to consistently appear as the 12th temp file created but each set of files created appear to be almost randomly numbered based on create time.  It also appears that RH Server continues to create sets of temp files that include the rogue files until it is satisfied that it has a good set for the index.  It uses the most recent session’s files as well as new sets in its midnight run and creates up to 120 files.  In our case these 120 files appear to be redundant reloads in sets from 28 to 44 files.  However, each set includes one rogue file in the middle of the midnight set and the previous session’s time stamp set even though the previous session didn’t include the bad file.  So, RH Server’s midnight run appears to always load rogue files where a ‘clean’ set of temp files seems to be created by the initial application request;   unless there are rogue files already in the directory. If there are corrupt files in the temp directory, new application requests create new sets of temp files that include more corrupt files.
    Simply put, these 4 rogue temporary files are essentially corrupt and wreak havoc on the application when it tries to open subsequent sessions.  When there is a session request, the RH application goes out to the temp files and says, “Wait a minute, who are you? Uh oh, I need to create a new index because you shouldn’t be here and you have corrupted my perfectly numbered temporary file system that I want to attach to this session as well.  Oh my, I’ll have to uniquely number these new files (I should be able to delete you all but I don’t)…. I’ll create a new set of files. I’m feeling sick, I guess I’ll just serve the documents and try to figure who’s using what later”.  Network response time, the size of the index and the number of temp files will decide how much of an index build you get.  ‘IndexCreator’ error is logged.  And as more and more sessions are requested the situation ‘snowballs’ as the application agonizes, “Oh, no there’s hardly any room to work and the network will only give me so much time.  Look at all these uniquely numbered files. I’m going to throw up – Blah, Protocol Host exe error!” That session’s index won’t work.  After about 10 Protocol Host exe errors, our server response is very slow and sometimes even hangs. Loaded sessions don’t have working directories, and several sets of files including the 4 rogue files have been generated in the temp file directory.
    RH continues to create new sets of temp files for each requested session as long as any of these rogue files are in the temp directory.
    Another Test
    I tried another reboot of the server, this time keeping the ‘good’ set of RH temp files (no corrupt files) in the directory as I rebooted.  After it came up I looked at the Windows temp directory to make sure no new files were added.  And then, I requested a session from the website. Right now the temp files appear to work for new sessions.
    Watched this good session of the server (with no corrupt files and working) to see what happens to the files at 12:00 AM when the Server tries rebuilding the index  I kept 2 sessions running over night.
    In the morning – Looked at server
    ·         RH Configuration Manager Troubleshoot - no new messages.
    ·         Event Viewer – Application error at 12:00 AM - Protocol Host exe (from RH Server routine).
    ·         New Temp files were added at 12:00 AM including the 4 rogue files.
    ·         2 sessions left running overnight indexes are working fine initially.  But, hitting their indexes generated RH Troubleshoot ‘IndexCreator’ message (this is because of the 4 new corrupt temp files created since they became active sessions).   No new bad files or Protocol Host exe errors are created.
    Deleted the 4 bad files and searched index on existing 2 sessions.  Index did not work and Protocol Host exe errors were generated.  New temp files including the 4 bad files were generated again.  Deleted 4 bad files and hit the index on existing sessions – tries to reload but fails to reload it all. They get RH Troubleshoot Indexcreator messages but no Protocol Host exes.  So it appears existing sessions created IndexCreator messages when rebuilding the index – becoming corrupt.  New sessions create Protocol Host exe errors if the bad files are there or they create the bad files when building an index.
    Deleted all temp files and emptied recycle bin
    Started a session – perfect no errors, no bad temp files, 14 temp files created (344k each), index works fine.
    Started another session – perfect again.
    Conclusions
    When RH Server nightly routine runs at midnight:
    It appears to try to verify there is an index at midnight. But it goes ahead and creates a new set of temp files and another set based on the previous application session. And it includes the 4 corrupt files in its ‘midnight’ set.
    RH Server sends “Error messages were returned from IndexCreator” messages every night at midnight only when the previous application session had corrupt temp files. The “Error messages were returned from IndexCreator” message appears when the server or a session references a bad set of temp (index) files in the windows directory.
    The Protocol Host exe error happens when the application tries to build a session index with a corrupt set of temp (index) files.
    When RH application requests a session from the website:
    ·         If there are no temp files in directory, The server will build temp files with 4 corrupt files and generate Protocol host exe error
    ·         If there are temp files with 4 corrupt files, server will build another set of temp files with 4 corrupt files and generate a Protocol host exe error
    ·         If 4 corrupt files are deleted but temp files are left, session will use the temp files and load correctly no Protocol host exe error and no ‘Error messages were returned from IndexCreator’
    When RH existing application sessions reference a set of temp files with 4 corrupt files:
    ·         Creates ‘IndexCreator’ messages when rebuilding the index but no Protocol Host exe errors
    ·         Eventually loads only partial index if the temp directory files change during its session.
    Temporary Solution
    Run the current weekly ‘delete all temp files’ routine on a nightly basis after the midnight RH routine that loads the corrupt files.  This will start each day with a clean Windows temp directory (with no corrupt files) when the first application request occurs.   The first requested application session will create a good (clean) set of temp files and the madness of the ‘snowballing corrupt, redundant temp files’ will stop.
    Permanent Solution
    Determine where the corrupt file names are coming from and delete them.
    What Changed? Ideas on why the RoboHelp application errors stopped between 11/10/2009 at 11:01 to 3/22/10 at 10:30 AM
    Each night at midnight a RH routine logs onto the server to rescan server documents.  This has been in place since we’ve implemented RH.  The application event log reveals that on 2/15/10 the “Error messages were returned from IndexCreator” messages started again. This indicates that there were corrupt temp files in the windows temp directory.
    Our weekly routine wipes out the RH temp files so each server session’s first request uses a stored or found number (Registry?) for its file numbering start.
    So RH or Windows determines starting number for temp file names and creates/moves 4 files with consistent 2009 dates into the temp file folder.
    Assuming these file names come from the registry, if someone recently changed the registry on the server (around 3/22/10), it would explain how our environment miraculously had no errors for 4 month’s with no application errors and then mysteriously re-appeared. It was possibly corrupted, or maybe reloaded with an old one (which included the corrupted temp files). I’m not sure where else these files/file names would be stored.  Or did some maintenance to the registry cause a change that brings in these 4 corrupt files?
    RH Trouble Shoot gave a message on 3-15-00.02 Unable to locate the URL ‘intruvent/jsp/admin/Login.jsp’ – this appears to be an access error.  This occurs at midnight in the log, the same time RH tries to build its index and sends the message that the “Error messages were returned from IndexCreator” message is sent.
    Or the Server’s event viewer Application Log shows that the NetBackup SAN Client Fibre Transport Service stopped being started and stopped every Sunday Morning after 3/21/2010.  It had done this weekly since the server was brought online.
    The Server’s event viewer Application log shows an Information message from HP Port Resolver on 3/12/2010 at 10:58:56 PM stating “the description for Event ID (0) in Source (HP Port Resolver) cannot   be found.  The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer.”  The last HP Port Resolver was 4/23/2009 before this one. And it hasn’t sent a message since the 3/12/2010 message.
    The Server’s event viewer System log shows that an Application Popup for the Service Control Manager occurred on 3/7/2010 at 6:10:41 AM stating that “The RS03 Server service failed to start due to the following error:  The service did not respond to the start or control request in a timely fashion.
    The Server’s event viewer System log shows that for many months the Service Control Manager reported that each Sunday morning around reboot time that the RoboHelp Server Service service terminated unexpectedly. It has done this 1 time(s)…. Restart the service.  This is was pretty consistent on Sunday mornings last year.  And now is less frequent.  Could these restarts have caused a ‘clean up’ of the directory?
