@ cheung
(OS Windows 7, 64 bits) I had the exact same error. The only problem in my (and your) case was (is) in the registry key AppInit_DLLs at: SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Windows. You should only make sure that the value data contains: acaptuser32.dll.
I guess if this does not correct the error, you have to make sure that acaptuser32.dll and acaptuser64.dll in fact do exist in Wow6432Node and System32 windows folders respectively. If they don't you should go for the repair process.
Thanks all for sharing your experiences.
Worked. Excellent. Thanks for the fix.
I have XP with Norton.
I tried these fixes but no luck.
Any other suggestions?
I just updated my system to Windows 7 and also updated my Acrobat 9 Pro Extended installation to 9.2.0.124. I started receiving the error message, but once I corrected the registry keys it started working.
The correct entries for me are:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"AppInit_DLLs"="acaptuser64.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls]
"C:\\WINDOWS\\system32\\acaptuser64.dll"=dword:00000001
The first registry key had had the DWORD value erased, so it was blank. As soon as I put the DLL name in, the error disappeared. I am using Windows 7 64-bit; previously I was on Vista 64-bit.
Thanks so much for the insight!
My situation was identical to yours, and the registry fix solved the Capture3d error. For me, resetting "AppInit_DLLs"="acaptuser64.dll" was the solution with Acrobat Pro Ext. 9.2 on Win 7 x64. Repairing the installation did not help at all.
My question is what is the cause of the problem, and why is the above registry edit necessary? Is it a Win 7 compatibility issue that will be fixed with future releases of Acrobat 9? I thought that Pro Extended 9.2 was supposed to be completely Win7 compatible?
These approach didn't worked for me.
Installed is Windows 7 Enterprise and Windows 7 Professional. I tried the registry settings but they didn't worked.
I found only this file on my system: C:\Windows\SysWOW64\acaptuser32.dll
In C:\Windows\System32 there is no acaptuser32.dll nor acaptuser64.dll
I also changed the "AppInit_DLLs" to acaptuser32.dll. That didn't help, too.
The problem still exists. I found another solution here:http://tehparadox.com/forum/f51/adobe-acrobat-9-capture-3d-damaged-fix-275954/
Adobe Acrobat 9 - Capture 3D Damaged Fix
If you start Acrobat 9 , and a "Warning: A part of the Capture 3D plug-in has been damaged", "To fix it you will need to repair the installation of Acrobat. This may have been a result of an anti-spyware application modifying the system's registry"
Here's the fix:
1. Right click on Acrobat.exe located in the install folder.
2. Under the computability tab; check the box and select windows 2000.
3. Apply and click ok.
4. Start Acrobat 9.
5. Wait until it's stable.
6. Click on 'Help'.
7. Click on 'About Adobe Plug-ins...
8. Click on 'Capture 3D' in left window pane.
9. Look in right window pane for 'Loaded' and 'Certified'.
All done.
None of these solutions worked for me. For "teigaff's" solution, Windows 2000 was not an option--only Windows Vista--and I couldn't change it because it was disabled (greyed out).
For the registry changes, the only registry entry I could find is the following one. 'Any ideas as to what I can do? (I'm running Win 7Professional SP1/64-bit.)
I have Windows 7.1 and Acrobat 9 Pro Extended 9.4.3. I started receiving the error message, but once I corrected the registry keys it started working. I had previously used the Acrobat 9 Pro Extended repair option three times with no success.
The correct entry for me was:
I did not need to modify the following as it was already there:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDl ls]
"C:\\WINDOWS\\system32\\acaptuser64.dll"="dword:00000001
thanks,
Roger
Exactly similar situation for me (Adobe Acrobat Pro 9 Extended v 9.4.4) and exactly the same solution:. Win7 64-bit Upgrade appears not to have set a value in:
Really it matters the most...thanks for sharing..
Okay. So I'm a little confused because all the threads pertaining to 64bit. Is the dword on
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows] "AppInit_DLLs"="acaptuser64.dll"
a 1 or a 2? And where is this "comma" supposed to be put? My above key was 1 and I changed it to 2. Unfortunately I do not know if it fixed because I inadvertantly clicked on the "do not show this error message."
Bludyfish
I am running Acrobat Pro Extended 9.5.5 under Windows 10. Up until the yesterday, APE worked beautifully as it has always worked, when I was running it under Windows 7 Pro.
Yesterday I was prompted to update my OS. I did so! It seems like it was a major update due to the length of time it took to make and to restart.
When I went to run Acrobat Pro Extended, I received the error: A part of the Capture 3D plug-in has been damaged. I am also running Kaspersky Total Security 20.0.14.1085(k). Does the Capture 3D plug-in problem also have to do with KTS? I read the fix regarding the Windows registry keys. Are the ones in the fix the before or after edited versions? I checked in my Windows 10 registry, and find both keys to be identical as in the examples above! I checked character by character to be certain.
