Jun 20, 2007 3:07 PM
PDF Preview Handler doesn't work
Like (0)
Same problem, same operating system, same outlook. How is it possible that Adobe doesn't repair the bug?
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
ADOBE COME ON!!!
This is a problem only for x64 platforms… in the same machine I have 2 drives with exactly the same configuration except that one drive runs Windows 7 x32 and the other Windows 7 x64. The preview handler of adobe does not work only when I run Windows 7 x64!
As I see this problem is around for years with vista x64 and adobe has done absolutely nothing. And won't do for the years to come. For some reason adobe does not like much x64 platforms. With the recent exception of photoshop no other product of adobe has a x64 flavor…
I am having a similiar problem with Vista x32. The preview handler is able to display the pdf, but the fields that were filled in prior to the email are not showing any values, but when you open the pdf with reader the values are there. Below is a more detail account of what is happening. I have contacted the third party dll as well, but thought someone here might have an idea too.
I have a client that is using the a thrid party PDF dll (Syncfusion) to generate and email PDFs reports. There seems to be an issue with the PDFs that are generated and using the built-in PDF Preview Handler for Vista. The scenario is ...
1. User receives an email into Outlook that contains a generated PDF (see image ''01-Opening-Email.jpg'')
2. User clicks on the attachment in Outlook and the preview handler starts up (see image ''02-Loading-Previewer.jpg'')
3. The PDF displayed in the preview handler does not have any of the fields filled out (see image ''03-Report-Loaded-In-Viewer.jpg'')
4. User then right clicks on the PDF (in outlook) and selects to open the PDF with Adobe Acrobat Version 9.0 and the report is displayed with all the fields filled out (see image ''04-Report-Opened-With-Adobe.jpg'')
All of these images are included in the attachment that I have uploaded with this incident. As well, in the RAR file is the PDF that was sent by the system using the PDF dll from Syncfusion. Please let me know if you need any more information from me.
Installed Windows 7 RTM 64 bit with Outlook 2007 and Adobe Acrobat 9 standard.
The PDF preview handler still doesn't work.
I looked into this today and discovered a simple fix for the problem:
http://www.pretentiousname.com/adobe_pdf_x64_fix/index.html
I built a workaround into my own software which uses the Adobe PDF preview handler but you can make a simple registry change to fix the problem in Outlook and Explorer as well.
I thought I'd share it with everyone as it doesn't look like Adobe are going to fix it themselves.
Thanks Leo… it did the job…
Would you by any chance know something similar for previewing Office 2003 files in the Windows explorer?
(I am running Windows 7, x64)
Thanks again…
Only thing I know that will view Office 2003 files in Windows Explorer is Office 2007 (or 2010 presumably).
There are alternative file managers which can view Office 2003 files using earlier versions of MS Office, or OpenOffice (free) or things like QuickViewPlus. Even there, though, if you want top-notch Office document previewing then Office 2007 is the best because it is the first version of Office to come with proper file viewing components for other tools to plug-in.
I am running Windows XP 32-bit with Office 2007 and had been able to preview PDF's without a problem until recently when it began displaying an error (detailed in previous posts).
I was able to resolve the problem by running Microsoft Office Diagnostics.
From within Outlook, click Help/Office Diagnostics
This ran for about 10 minutes and although it stated that it did not detect any problems, I am now able to preview PDF's once again.
Good luck.
I have given up on this problem. I have tried all the suggestions offered to fix the preview problem, and have emailed Adobe several times. I've returned to using "Thumbs Plus" a wonderful program (by Cerious Software). My pdf thumbnails display beautifully in this program, and it shows your thumbnails MUCH faster than Explorer. Debbie Knight
please visite this site it works fine for me "vista 64x"
I used the same fix as Leo on Outlook 2007 and Windows 7 64 bit and it worked - I did the manual regedit with no issue. Just waited a few minutes then went to different email with pdf attached and preview worked just like it used to before the windows upgrade
Mike
Dear Leo. I have tried the change of key value in the registry by regedit command. It has SOLVED the preview problem of pdf files in outlook 2007. I am running 64 bit verstion of windows 7.
Thanks.
Thanks Leo! Your solution at:
...Worked on both Win 7 x64 machines we tried it on here.
How on earth do you know where to find these things in the registry? You should be called Neo rather than Leo!
Thanks again for the fix.
Hello, I tried this fix and it did not work. I have Acrobat Pro v9 and not reader, so I am not sure if this is the same fix. Also, I am using W7 Pro
x64. Much thanks! So confusing that this is an issue and Adobe hasnt fixed it.
I don't know if Acrobat even installs a preview handler (even on 32-bit Windows). You may need to install Reader as well to get the preview handler. Can't say for sure as I don't have Acrobat, though.
(BTW, not sure of the URL off the top of my head but Adobe have a page on their website that lists which versions of Acrobat and Reader can safely co-exist on the same machine. If you have an older version of Acrobat then installing the latest Reader may cause problems. Installing an older version of Reader isn't a good idea, though, due to all the security holes in older versions.)
Yeah, it's ridiculous that, three months after I reported the fix, Adobe still don't seem to have updated the Adobe Reader installer to incorporate it. I'm still getting loads of "thank you" emails so it's clear the problem affects a lot of people. It's also ridiculous that such a simple problem, caused by not following the Windows API documentation, that affects so many people was completely ignored for so long. Adobe: Pull your socks up!
My page about the fix is updated:
There is now a tool that automates the fix.
After three months, Adobe still haven't fixed their installer and I'm still getting loads of people emailing me to say thanks. I figured the existing info was too complex for a lot of people, and it looks like the fix may be useful for some time, so I wrote the tool to make things easier and help more people.
The tool takes care of stuff like the extra registry value that Vista and Vista-to-Win7-upgrade users need to modify. It also offers to reset the preview handler association for people who have another one installed, makes sure people don't try to "fix" 32-bit Windows by mistake, and some other stuff. It should give people a one-click fix.
Of course, I've left the old details there for those who prefer to do things by hand.
This works like a charm. You are awesome!!!!
Leo Davidson's elegant fix to this long-standing Adobe bug is highly recommended. It worked instantly on my 64 bit Windows 7 machine.
It would be great for all us Adobe users, if Adobe would Mr. Davidson as an ombudsman. Think Mark Russinovich . . . SysInternals . . . Microsoft.
Leo
I just want to give you a pat on the back for your help on this matter. Well done. I obviously join a chorus of users who send a message to Adobe to make a fix for the billion other users around the world... and perhaps they can throw your name into the fix for good measure. If you had a small paypal donation button on your installer (or webpage) i would definitely have thrown a few bucks your way, because i think you're a mensch.
Regards
Paul Steinberg
Melbourne Australia
I have just released an additional fix that makes Adobe Reader's thumbnails work on 64-bit Windows Vista and Windows 7 machines:
Enjoy!
BTW, I made the thumbnails look better by trimming the white frame. Might even be worth installing on 32-bit machines. :-)
Here's a screenshot showing the thumbnails and preview handler working on my 64-bit Windows 7 machine:
Thanks Leo!
I read through your site, and chose to go the lazy route using the app to modify the registry instead of doing it manually. I can add to the list of confirmations that it worked flawlessly as advertised on Win 7 x64 without any issues what-so-ever. Now if only Adobe could make their software so reliable.....
Anyhow, just a quick note to say thanks for doing this!
Eric
Leo,
Good job...fixed my problem with Acrobat 9 and Windows 7 Professional 64 bit
DJ
North America
Asia Pacific
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
