• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
Colors faded, washed out in PDF display
New Here ,
Mar 14, 2008 Mar 14, 2008
Hi all, odd problem... found a few like it in the forums, no solutions though.
When I export a PDF from InDesign CS3 to Acrobat 8, the PDF opens with a dull "wash" over the entire pages.
When I scroll or move thru the document in Acrobat, I briefly see the pages properly (vivid color, rich blacks) for a split-second, then this grayish "wash" appears over everything. This even happens in the Print preview dialog.
It seems to print OK, but executives will be opening & viewing this file and not always printing. I'm getting comments like "can you fix the color?"
My color settings are synchronized thru Bridge.
Any insight is much appreciated!!
TOPICS
Create PDFs
Views
83.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Mar 18, 2008 Mar 18, 2008
Sounds like you've converted your RGB indesign document to CMYK (Acrobat press settings.
Also does it make a difference if you switch overprint preview on or off? (Advanced>print production>overprint preview)
Votes
Translate
Translate
Report
Report
New Here ,
Hi, and thanks for the reply...
The ID document is actually CMYK, though it does incorporate RGB elements (photos and PSD artwork). I have tried converting EVERYTHING to CMYK and then RGB to compare -- but I get this "wash" no matter what the original color space.
Overprint preview makes no difference. Selecting Output Preview makes the pages appear correctly as long as that dialog box is open. But as soon as I close the dialog, the pages "wash" and look faded again.
Again, it prints OK. But this washed-out display is a problem and really looks bad.
Votes
Translate
Translate
Report
Report
LEGEND ,
Have you calibrated your display against a known standard?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 19, 2008 Mar 19, 2008
There's a bug in older versions of Acrobat 8 that
has this kind of effect. Which version are you using?
Votes
Translate
Translate
Report
Report
New Here ,
Jun 17, 2008 Jun 17, 2008
Hi
If you save EPSs from your PSDs and use EPSs in your Indesign Doc then the PDFs retain the strong colour.
I recon it's Indesign not processing the PSDs properly into PDF format.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 29, 2008 Jun 29, 2008
THank you!!! I have been having this same exact issue. Did you ever find a solution?
Votes
Translate
Translate
Report
Report
New Here ,
Oct 06, 2008 Oct 06, 2008
I am having a similar but different problem.
My documents print from InDesign CS3 just fine. The printed output matches my on screen colors just fine. When I create a PDF from InDesign, the onscreen PDF looks just fine... BUT (here's the problem) the printed output from the PDF is washed out.
The reason this is important is because I have to send a PDF file to the printer to have it printed. The printer only accepts PDF files.
The color space is CMYK in all cases (US Web Coated SWOP v2)
I have tried a TON of different options, from "Preserve Color Space" to not preseving, convert, etc. etc.
Does anyone have any ideas why printing from InDesign looks good but printing from the PDF file is always washed out?
Votes
Translate
Translate
Report
Report
New Here ,
Dec 20, 2008 Dec 20, 2008
I have exactly the same problem, the "washed out" PDF after converting from InDesign. Funnily enough, if I then open the washed out PDF in Photoshop, it appears in all its richness. And I can save it as a Jpeg or Tiff with full colours preserved.
Also, most of my page layout PDFs convert with no problem. It's just the front cover design that gets washed out, so i'm thinking it must be something to do with having overlapping objects. I have text over colour-filled rectangles, and some drop shadow on other objects. It seems to be something to do with the way InDesign flattens these when it makes the PDF. Images on page layouts without any overlap remain crystal clear.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Feb 11, 2009 Feb 11, 2009
This has happened to me when and is always connected with transparency and/or drop shadows. Make sure that your transparency blend space is set to the final color space the PDF will be used for. If I need the PDF for onscreen display only, then I make the images, the document color space and the transparency blend all the same RGB. When I have to work with CMYK, it always prints correctly, but never displays correctly.
Votes
Translate
Translate
Report
Report
Sep 21, 2010 Sep 21, 2010
That's it!  Was having the same issue ...   I changed my Transparency blend space to RGB and that fixed the problem with my photos.  RGB photos were coming out as faded when I exported to an RBG pdf.  The only other solution was to flatten the pdf.  But changing the transparency flattener colorspace to RBG fixed the problem so that I don't have to flatten the document first.  Thanks!!!
Votes
Translate
Translate
Report
Report
New Here ,
Feb 12, 2009 Feb 12, 2009
There was a bug in Acrobat 8.0 that affected the display of images which had live transparency applied or interacted with transparency (including drop shadows and other effects). The bug was fixed in 8.1. Since things display correctly with Output Preview open, I suspect this is what you are running into. It's only a display problem.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 12, 2010 Nov 12, 2010
I was having the same problem, I am not techy at all just getting started with IndesignC3. So I can't give much insight into the actual issue but i did fix washed-out problem I was having, so maybe this can work for you guys too.
When I was exporting to pdf under: settings-general, in the top right is 'compatibility'. At first it was set at Acrobat 5 (PDF 1.4). I changed it to Acrobat 4 (PDF 1.3) and it is woking...no washed out look!
Hope it can work for you guys too.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 03, 2012 Jan 03, 2012
View: Proof colors. When this is on your document will show correctly.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 18, 2021 Mar 18, 2021
I had the same problem with saving PDFs from illustrator and I went to OUTPUT when saving the PDF and set "Color Conversion" to "Convert to Destination" and it fixed the pdf colors.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 25, 2021 Aug 25, 2021
LATEST
https://youtu.be/nHjfh0DXbVc
Recent Updates seemed to change my PDF Export Presets. I cut a tutorial video for you.
• File » Save a Copy
• Save File as a Photoshop PDF
• Change Adobe PDF Preset from [HIGH QUALITY PRINT] to [PRESS QUALITY]
• Problem Solved
Tim Schmidt
Founder
Agency511 Marketing and Advertising
Advanced Information About Correcting Faded PDF from Adobe " http://www.Agency511.com/ how-to-correct-faded-pdfs-from-adobe HOW TO CORRECT FADED PDFs EXPORTED FROM ADOBE - SOLVED! Video Summary: Here is the solution to correcting faded PDFs created by Adobe Products. If ever you have saved a ...
Votes
Translate
Translate
Report
Report
