Hello All. I had the same issue. I am using Windows Home Premium with Service Pack 1. All I did to get the preview of my pdf files was to Open Acrobat Reader PC / Edit / Preferences / General - I then checked the box to "Enable PDF thumbnail previews in Windows Explorer" save your settings let Acrobat Reader do what it needs to do. (this only takes a few seconds) and that is it you will now have your previews.
Howdy.
Thanks for this solution, it worked for me. I too just switched to Vista x64 and have the issue where my scans were not previewing and only showing the red Acrobat icon. I opened the reader, chose File Open and pointed it to my folder of PDFs and chose Views/Large Icons and it created thumbnails that were available to Windows Explorer. Thanks, this was, like the other folks, really bothering me!
--dave
Following the steps as your suggest ,i still have the issue. so sad!
Win7 32-bit Ultimate
who knows the workaroud ,please let me know. thanks very much.
It worked - thanks!
Thank you!!!
This fixed my problem. It is still annoying, but at least there is a reasonably quick fix for it!
Also, just found this, in Win 10, in the view plane at the top of the screen, uncheck 'Item Check Boxes', and in Folder Options, uncheck 'Always Show Icons...' This worked for me.
There is a fix for it :
http://www.pretentiousname.com/adobe_pdf_x64_fix/index.html
It will fix both the preview of icon is not showing and the preview of the content of the document is not showing
The installer and executables are digitally signed. Thanks to GPSoftware for signing them for me.
You'll need to re-run the preview-handler fixer each time you update Adobe Reader. A start menu shortcut is provided.
Keep in mind that the above poster has only posted in these forums one time and the files he is pushing are not coming from the Adobe site.
They may be perfectly fine but I'm just saying...
That's why i also posted the link to the original author's site ,
you can take the file directly there if you don't trust my links.
It solved my problems so i just wanted to share it.
Sorry. Not trying to sound like I was accusing you of anything.
Guess I'm just trying to point out that it isn't an Adobe product so it's user beware.
It does not matter if it is from adobe or not, but it makes me angry, that adobe did not solve the problem themselves. A lot of time went by and we still have to patch after each update from adobe again. Thats a shame
Thanks for that fix! It worked on my new Win 7 64 bit machine.
Download the fixes:
- With installer: Adobe_Reader_x64_fixes_v2_002_installer.zip (1MB)
- Without installer: Adobe_Reader_x64_fixes_v2_002_noinstaller.zip (1MB)
Well yeah this is it! This fixed it for me.
It's too bad Adobe doesn't take care of these bugs that they create.
You have found the answer. You are a master and deserve thanks from Adobe! ***Thankyou***
