• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Convert to PDF problem - spooler/direct printer settings
New Here ,
Mar 26, 2009 Mar 26, 2009
When I try to create a PDF from say a Word doc I get the following error message:
"Invalid Adobe PDF printer properties: Do no change spooler settings.
Please select Print directly to the printer option (from Adobe PDF printer properties Advanced tab)"
I can change the settings to print directly and it works. But the next time I log on to do it, the settings have gone back to how they were. This would't be a big problem for me personally but other less technical users have problems doing this.
Any ideas how I can make this change permanent or remove the error entirely?
Views
29.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Mar 27, 2009 Mar 27, 2009
Hi Nozza, you didn't mention what the settings revert back to. I am guessing from the context of your post that you are trying to spool the document. I don't think Acrobat ever let you spool documents.
You would get better results overall if you did not print Word docs to PDf but instead converted them using the PDFMaker plug-in for Word. It offers much better control and more features.
You didn't say which version of Word or Acrobat that you are using but the plug-in is available for most MS Office products, the print to pdf is most commonly used for applications that do not have conversion options.
Why do you need to change the print settings? What issues are you trying to avoid or experiencing? There may be a better solution if there is more information provided.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 30, 2009 Mar 30, 2009
I need to change the print settings to avoid that error. The default spooler settings cause the error.
I'm not manually printing to PDF but rather using the "Convert to PDF" function that installing Acrobat added to my Word toolbar. I assume this is the PDFMaker plugin. This converts to PDF by printing to a virtual PDF printer. AFAIK this is the way all PDF conversion is done.
Anyway, I have solved the problem now by changing the port that the PDF printer uses to the MyDocs/PDF one rather than the default COM1 port it had selected on installation. Now it doesn't care about the spooling settings.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 09, 2009 Jul 09, 2009
If you get this:
Invalid "Adobe PDF" printer properties
Do not change spooler settings.
Please select "print directly to the printer" option (from Adobe PDF printer properties "advanced" tab)
Try this:
Find the Acrobat printer in Printers.
Right click on it and select Properties then the Advanced Tab.
For me, "Spool print documents..." was selected.
The Fix:  Deselect "Enable advanced printing features".
Click OK.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 26, 2010 Feb 26, 2010
Just wanted to say that this worked for me on a system I was working on.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 08, 2011 Jun 08, 2011
Able to fix by the spooling method & unclicking "eable advanced printing features"
- thanks;
what I would like to know is WHY did the issue occur in the 1st place;
W7 newish Laptop, with MS2003 package and Adobe Standard v8 is on the system; I regularly use print PDF from Explorer or a scanned imaged (large JPG); easier to send as  PDF file; have been doing this for years and suddenly this error occurs; initally tried to restore system to an earlier version, downloaded latest version W7 Service packs etc - nothing worked until I saw your advice on the matter.
Thanks again
Votes
Translate
Translate
Report
Report
New Here ,
By the way; as I said, the fix worked but created a new issues:
1: after creation of the PDF file, will not delete the file from the print file queue list - status will randomly indicate "error printing"
2: does not request for a file name prior to PDF creation despite clicking the approproate boxes for this option
any advice?
Votes
Translate
Translate
Report
Report
New Here ,
Jul 04, 2011 Jul 04, 2011
LATEST
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Get more help to fix Printer Spooler Error :
http://printers.iyogi.com/errors/printer-spooler-error.html
Hope this helps you.
Votes
Translate
Translate
Report
Report
