how to decrease PDF file size without losing quality of images and vector lines?
Feb 27, 2008 11:37 AM
I have several ai files that I saved as PDFs. Now I'm having problem with the size of this combine files. Can some one assist me with the proper way on decreasing file size without losing quality.
Thank you.
    Feb 27, 2008 11:49 AM   in reply to (edcortez)
    What software are you using to combine the files? Create PDF Online
    can't do this.
    Aandi Inston
    Feb 28, 2008 12:41 AM   in reply to (edcortez)
    Ok, if you are using Acrobat, I recommend the Acrobat Windows or
    Acrobat Macintosh forum. You might also like to check in the
    Illustrator forum to see your options for reducing the size exported
    in the first place.
    Aandi Inston
    Mar 3, 2008 9:12 PM   in reply to (edcortez)
    I do architectural drawings in illustrator. when i try to save as a pdf the lines come out significantly less detailed, like broken straight lines when creating a curved line when seen in illustrator.
    does anyone know how to save to pdf... size is not an issue as long as quality is top notch!
    thanks
    Mar 4, 2008 1:35 AM   in reply to (chaz)
    Chaz, I don't think you are using Create PDF Online, and you aren't
    trying to decrease file size. So this isn't really the place to ask.
    Try starting a new topic in a suitable forum (e.g. an Illustrator
    forum).
    Aandi Inston
    Jul 7, 2008 6:48 AM   in reply to (edcortez)
    I have a scanned official document the size of 4.4MB. I need to reduce the size to less than 2MB. How do I do this without having to re-scan the document?
    Jul 7, 2008 6:49 AM   in reply to (edcortez)
    It is a 2 page .pdf file in color.
    Jul 29, 2008 7:13 AM   in reply to (edcortez)
    I created a form using Adobe LiveCycle Designer and saved it as an Acrobat 7 (Static) PDF Form (*.pdf). Once saved, I open the PDF and enable rights for Adobe Reader users. This fillable form I created is 707 KB.
    Any suggestions on how I could decrease the size of this file?
    Jul 29, 2008 1:54 PM   in reply to (Amanda_Babin)
    Please post in the LiveCycle Designer forum. Good luck,
    Aandi Inston
    Aug 21, 2008 4:14 AM   in reply to (edcortez)
    Hi, I wonder if someone can help with what I believe is a fairly straight forward situation? I am a relatively new user to the Mac world and have created a Newsletter document with lots of hi res pictures that I need I need to compress as small as possible. I have converted to PDF and then reduced from around 225MB to 20MB. I am told that bu setting certain parameter in Distiller I will be able to reduce even further...this is where I ran in trouble. HELP!!
    Well, you can adjust Distiller parameters and it may reduce file size,
    but are you using Create PDF Online? If not, you should probably try
    in the Acrobat forum. Good luck,
    Aandi Inston
    Aug 30, 2008 6:20 AM   in reply to (edcortez)
    I am very frustrated. Trying to print to .pdf not export. Keep sgiving me a messge saying not enough memory. I have more than enough memory on my computer.
    Please help urgently.
    Aug 31, 2008 12:25 AM   in reply to (virtualfusion)
    And you are getting this message from the Create PDF Online service?
    Aandi Inston
    Oct 15, 2008 6:01 AM   in reply to (edcortez)
    I have a file of 33mb and when I create a pdf the file reduces to 13mb can any onr tell me what im doing wrong
    Oct 15, 2008 9:18 AM   in reply to (cmc)
    This is using Create PDF Online? What type of file are you sending to
    the service?
    Aandi Inston
    Calculating status...
    Nov 27, 2008 3:16 AM   in reply to (edcortez)
    I have a few drawing files that I saved as PDFs. Now I'm having problem with the size of this files. i am not able to take a printout as the memory is not supporting. Can some one assist me with the proper way on decreasing file size without losing quality.
    Thank you.
    Dec 5, 2008 4:49 AM   in reply to (edcortez)
    Thank for post
    Good Luck.
    ______
    My Si tes
    Dec 15, 2008 7:01 AM   in reply to (edcortez)
    I have converted 15 JPEG files to .pdf and 12 of them are under 200kb. I need the other three, which range from 201kb to 242kb, to be under 200kb so I can upload them into my placement file. How can I shrink those three to under 200kb?
    Jan 19, 2009 10:59 PM   in reply to (edcortez)
    I've seen many high quality PDF's with low size and vice-versa. Is there any tool for compressing the PDF?
    - http://www.reduceweight.org - Lose Weight, Fast!
    Mar 2, 2009 8:53 AM   in reply to (edcortez)
    I am having the same problem with a different file that's in a different format mentioned above. I'm trying to convert a ".srf" file and turn it into a ".pdf." I was successful doing this but my image, once in a .pdf was also pixilated.
    I thought if I convert my ".srf" file to a ".jpeg" first, then bring this newly created ".jpeg" into a ".pdf," I would have more luck. But unfortunately the free download I got on my computer that's supposed to convert any file to any file, CANNOT convert ".srf" files to ANYTHING!
    Does anyone have any ideas? Or any specific programs I should get?
    Thanks!
