Home/Support/
Forums
1 2 Previous Next 11668 Views 67 Replies Latest reply: Jul 2, 2008 4:36 AM by ryclark RSS
User 795 posts since
Aug 11, 2002
Jan 10, 2005 11:43 AM
Cubase VST Instruments
This is not exactly a Audition question but, It was through the original Cool Edit forum that I picked up a Hammond B3 VST instrument plug-in for use with Cubase, and I just installed it last weekend. It works but I am getting some popping and crackling with the sound. I'm using a notebook computer, 640mb ram, with built-in soundcard. Do I need a better computer to make VST instruments work?
  • Calculating status... 7 posts since
    Aug 23, 2003
    1. Jan 10, 2005 12:52 PM (in response to (Ken_Nielsen))
    Re: Cubase VST Instruments
    You're right, it isn't an Audition question! But since audition doesn't support instruments, I suppose you can't help using Cubase or similar.
    I'm guessing you might be using Cubase with the so called ASIO DirectSound driver? You'd be better off with a true ASIO driver.
    This can be added to many ordinary on-board sound chips with a free adapter called ASIO4ALL
    http://michael.tippach.bei.t-online.de/asio4all/
    Then again, some laptops require some of their energy saving functions to be disabled in order to get good audio performance. That's a specialist area and I for one have never owned a laptop.
  • Ozpeter User 1,341 posts since
    Jun 27, 2006
    4. Jan 19, 2005 4:43 PM (in response to (Ken_Nielsen))
    Many of the links at Ozpeter "USEFUL LINKS" 12/3/04 5:40pm (the list of my bookmarks in the second post) are vst / vsti related, with the emphasis on freeware.... you are standing on the edge of a time-consuming but most enjoyable obsession, if my experience is anything to go by!
  • Calculating status... 10 posts since
    Jul 1, 2003
    6. Jan 20, 2005 11:28 AM (in response to (Ken_Nielsen))
    Here are some free VSTi's that will give you some good sounds. IMO, the first in each category is the best, but the others are worth checking out. In some instances, I've provided more than one address, as a guard against dead links. Enjoy.
    (Note: mdaPiano kept crashing in my SynthEdit program until I moved both pointers to approximately the "e" spot in the "Muffle" setting. You may need to do something similar, but do it. The program is worth making it work on your computer. Check out the Concert Piano pre-set.)
    MIDI Cables: (if needed)
    http://www.midiox.com/myoke.htm
    http://members.nextra.at/hubwin/midi.html
    HOSTS for playing VSTi's: (free)
    http://www.tobybear.de/p_minihost.html (need ASIO)
    http://www.hermannseib.com/english/vsthost.htm
    http://www.hermannseib.com/english/savihost.htm (check this out)
    (if you get a "could not be found" message, highlight address in browser and reload)
    http://www.xlutop.com/html/chainer.html
    http://www.console.jp/eng/ (not free)
    ORGAN:
    ORGANized Trio
    http://www.soundfonts.it/
    http://www.soundfonts.it/?a=read&b=13
    Morphiza
    http://www.krakli.co.uk/freesynths.asp
    http://www.krakli.co.uk/zips/Morphiza.zip
    Phibes
    http://www.funkelectric.com/%7Ecockaigne/
    http://www.funkelectric.com/~cockaigne
    OrganOne
    http://www.bojo.dk/downloads.html
    PIANO - Accoustic
    mdaPiano
    http://www.pluginspot.com/documents/46.html
    GrandPiano
    http://www.sinte-virtual.com/evmsynths/free.htm
    4Front Piano
    http://www.yohng.com/piano.html
    PIANO - Electric
    Mr. Ray
    http://www.soundfonts.it/?a=read&b=16
    mda ePiano
    MIDIKbd
    http://www.dehaupt.com/SynthEdit/DH_MIDI_Kbd.htm
    SYNTHS:
    SuperWave P8
    http://home.btconnect.com/christopherg/main.htm
    http://home.btconnect.com/christopherg/superwave-p8-16.zip
    http://www.superwave.co.uk/
    Stringer
    http://www.falkes.org/music (scroll down)
    http://www.falke.adbe.org/stringer_12_setup.exe
    Crystal
    http://www.greenoak.com/crystal
    Oberon
    FreeAlpha
    http://www.linplug.com/Products/FreeAlpha/freealpha.htm
    ASynth
    http://antti.smartelectronix.com/
    Synth1
    http://www.geocities.co.jp/SiliconValley-SanJose/5005/softsynth/index. html
  • User 7 posts since
    Aug 23, 2003
    7. Jan 20, 2005 12:23 PM (in response to (Ken_Nielsen))
    Great list Bonnder, very comprehensive.
    MrRay is a very good EP sim. The same developers Organized Trio organ can compare favourably with B4.
    The MDA pianos are surprisingly good considering they are very frugal programs. While in the MDA site, checkout the plug-in FX pack. Plenty of useful odd FX in VST format, including a very useable Rotary sim.
    Transistor organs like the Farfisa (surprisingly, this was quite common on '70's recordings) are poorly represented, though Morphiza can come close. There is a commercial one called Combo Sister (based on the VOX Continental but tweakable).
    Where's the Lowrey? Nobody seems to want to do that one, but wasn't it on some Dylan/Band tracks?
    String Synths?
    Cheeze Machine (Solina/Logan)
    Mellosound (Mellotron)
    Jun 27, 2006
    8. Jan 20, 2005 2:08 PM (in response to (Ken_Nielsen))
    Excellent links! And unlike mine, well ordered....
    http://www.wstco.com/pianosounds/downloads/ has some excellent piano soundfonts which can be played with the free soundfont player from http://www.rgcaudio.com/sfz.htm - imho better than the non-soundfont pianos, but it does depend on the musical context.
    For me the best organ is at the downloads page of http://rumpelrausch.de.vu/ - the zr3. Also the Crazy Diamonds string synth there. All good stuff.
    Jun 27, 2006
    10. Jan 20, 2005 3:05 PM (in response to (Ken_Nielsen))
    Ah, I had wondered whether yours was the Native Instruments one - not cheap by comparison!
    Jun 27, 2006
    12. Jan 20, 2005 5:22 PM (in response to (Ken_Nielsen))
    You open the piano soundfont within the player itself and therefore it doesn't matter where the soundfont is on your system. I keep all soundfonts in a dedicated folder quite separate from the vst folder.
  • User 10 posts since
    Jul 1, 2003
    13. Jan 20, 2005 8:47 PM (in response to (Ken_Nielsen))
    I have never been able to get a sound out of either of these on my SB16, Win98 machine. And as I type this it occurs to me that I have never tried them on my WinXP machine. Will do so soon and see if I can get some sounds to see what Ozpeter keeps raving about.
    I thought we were limiting this listing to VSTi's and ignoring Soundfonts - so I did not put up any links. I will go through my list and post some of the better ones. Again, Ozpeter likes to promote the rgcaudio SF player. And again, I can't even get a soundfont to load in the regcaudio SF player on my SB16 Win98 machine. Says there is not enough memory. However, I can load multiple SF's with both SynthFont and SynthEdit. I'll post links to both when I post my Soundfont list.
    Jun 27, 2006
    14. Jan 20, 2005 9:53 PM (in response to (Ken_Nielsen))
    Well, the SFZ player can be used as a VSTi, so... :) - but I'm surprised you don't get a result on your Win98 machine (Win98SE?) - they seem ok on mine, with an SBLive Platinum card.
    BTW my preference for ZR3 is based on personal taste for its perhaps smoother sound, rather than accuracy of emulation - I wouldn't be able to judge that.
    Jul 1, 2003
    15. Jan 20, 2005 10:12 PM (in response to (Ken_Nielsen))
    Just for the record: As I read through my post directly above, I can see how some might get the idea that I am arguing against Ozpeter's recommendations. I am not. I was just stating my experience with some of them for whatever that perspective might provide to a newbie (same with my comments about mdaPiano). I have benefited mightily from Ozpeter's recommendations over the last couple of years.
    Jun 27, 2006
    16. Jan 20, 2005 11:46 PM (in response to (Ken_Nielsen))
    This is an area of creative endeavour where all we can do is to throw in our experiences brainstorming-style and leave it to the readers to extract what juicy morsels they care to fish out of the resulting soup!
    Jun 27, 2006
    17. Jan 21, 2005 12:51 AM (in response to (Ken_Nielsen))
    If this thread disappears, it will be found in the Third-Party Plugins folder, by the way, as it's a bit out of place here.
    Meanwhile I see Cakewalk have bought RGC Audio - now's the time to download anything free there!
    Aug 23, 2003
    18. Jan 21, 2005 7:41 AM (in response to (Ken_Nielsen))
    "Meanwhile I see Cakewalk have bought RGC Audio "
    That explains the appearence of SFZ+ soundfont player bundled with the preview 64bit Sonar.
    Jun 27, 2006
    21. Jan 21, 2005 2:41 PM (in response to (Ken_Nielsen))
    Ken, I can't come back to this for 8 hours but remind me if I forget!
    Aug 23, 2003
    24. Jan 22, 2005 1:33 PM (in response to (Ken_Nielsen))
    Do check the sfz FAQ at the RGC site. It has several methods you can choose for playing the soundfont, including direct from disk.
    Full functions are only available if your machines CPU supports Intel SSE instructions.
    Also note that not all soundfont instruments appear in the first bank or preset. I don't know why, perhaps they've been taken from larger multitimbral banks and have retained their original location?
    If the soundfont file is .sf2, it should be usable.
    Jun 27, 2006
    25. Jan 22, 2005 6:14 PM (in response to (Ken_Nielsen))
    I doubt whether I could add any wiser words than Jim's at this point, so I won't! Let us know how you get on with it next week.
    Jun 27, 2006
    27. Jan 24, 2005 2:43 PM (in response to (Ken_Nielsen))
    http://www.wstco.com/pianosounds/freesoundfont.htm - the free 25mB soundfont listed on that page - is the one to go for. I've tried the paid-for larger ones (the payment is very small!) but I think the free one is my preference!
    Jun 27, 2006
    29. Jan 24, 2005 4:10 PM (in response to (Ken_Nielsen))
    Well, I've now actually got around to firing up sfz as a standalone app (you should have sfz.exe somewhere, or is that an optional download, different from sfz.dll which is the vst version?). That way no other program's complications come into it.
    I click in the box to the right of "File" in the main part of the interface - NOT using the menu option - and there I select "WST25Stein...sf2". And off I go playing it with my keyboard. I've in the past made the right selections in "asio" "outputs" and "midi" in the menu.
    Now using it within Cubase I can't advise on, because having bought Cubase SX2 months back, I've never had the chance to try it! So much software, so little time.... but if you get it working in standalone mode as suggested above, that will whet your appetite.
  • Calculating status... 19 posts since
    Oct 1, 2004
    32. Jan 27, 2005 12:36 PM (in response to (Ken_Nielsen))
    Hey guys, for those of you who have tried out the Piano VSTs, could you guys recommend a good one that has a darker sound? I have a very high quality Steinway bundled in the Garritan Personal Orchestra sampler. I am happy with the sound very much, but it's rather bright for some of the songs I have in mind and was hoping to find a decent quality alternative for free or a decent price for when something darker is needed. EastWest makes a great Bosendorf (sp?) sample that sounds wonderful, but it's way too much for my limited budget right now. Any good piano VST's for something a little darker? I would prefer it not to sound too warm, but some warmth is certainly ok and it doens't have to be free but that is preferable. Thanks in advance!
    Jun 27, 2006
    35. Jan 27, 2005 4:17 PM (in response to (Ken_Nielsen))
    Thanks Ken - well, certainly the sfz.exe program does stand alone - it did yesterday when I tried it! You'll see it amongst the files installed in the directory of your choice by the sfz installer, along with the .dll file (which may not show unless you have "show hidden files" switched on). The rest of the advice in that post is all good stuff.
  • User 19 posts since
    Oct 1, 2004
    36. Jan 27, 2005 5:28 PM (in response to (Ken_Nielsen))
    Thanks Ken, I did check out the demo on Steinberg's site and "The Grand" seems quite comparable to the quality of the Steinway that comes with Garritan PO. It sounds like it may be darker as well, but I can't tell for sure without demoing it I am thinking (small file downloads aren't the best for hearing critical details ;) ), I'll have to see if I can turn any leads up on the internet for that demo as I am in a very bad area for music gear. There are only 2 music stores in the area, both very small and I don't think either one sells any kind of software at all, except for the recording software that comes bundled with some of the Digitech pedals now. There isn't a large demand for music gear around here and so they only stock bare minimums and safe items, like small amps and cheap guitars.
    My Cubase copy came with an extras CD that has some form of light version Halion listed on the front. Perhaps if I dig around on that CD they'll have a trial version of the piano or a light version? Thank you very much for the lead!
    Oct 1, 2004
    39. Jan 28, 2005 2:14 PM (in response to (Ken_Nielsen))
    I agree Ken. I will continue my search and in the meantime I believe I may have to investigate some of the interesting possibilities mentioned in this thread.
    Jun 27, 2006
    40. Jan 28, 2005 2:26 PM (in response to (Ken_Nielsen))
    In its standalone form, Sfz can record direct to disk and there should be no reason why that won't work while playing back previously recorded tracks in Audition. Then you can insert the Sfz-recorded track into the Audition session, trim as required, and slide into sync with the other instruments. Not as elegant as being able to use it direct in Audition, but saves purchase of Cubase!
    Jul 1, 2003
    41. Jan 28, 2005 8:15 PM (in response to (Ken_Nielsen))
    Jeremy - have you tried the accoustic pianos I posted at Post #6 above. The are *.dll files rather than SF2 files - but they are not synthesized pianos. They contain samples. Play them with a VST player. In particular, you can adjust the tone quite a bit on the mdaPiano module.
    Oct 1, 2004
    42. Jan 29, 2005 1:15 AM (in response to (Ken_Nielsen))
    Thanks bonnder. I will be checking into several of the plug-ins and samplers mentioned on the site lately, this weekend. I'll be sure to check out the mdaPiano you mentioned. I love options! I'll try and post a cmparison with some of these to the Steinway in Garritan when I feel I have fiddled with them enough to give an honest opinion.
  • mphare1156 User 21 posts since
    Sep 3, 2002
    43. Jan 30, 2005 10:57 AM (in response to (Ken_Nielsen))
    I've always had an attraction to the analog synths of the 70's
    Arturia (http://arturia.com/) has several great programs. (I have the Moog Modular and I've seen they just added the ARP 2600)
    Since Audition is not a MIDI sequencer, instruments are pretty useless. I would liks to be able to record the out put of my Moog as a track in Audition for use in some video sound tracks though.
    Oct 1, 2004
    44. Jan 30, 2005 4:38 PM (in response to (Ken_Nielsen))
    Michael, does the Moog synth offer a Rewire connection? I have Arturia Storm 3.0 and it supports Rewire. If your synth does and you are lucky enough, you may be able to rewire the Moog synth into Audition and you should be able to record audio from it that way. I say if your lucky, because Audition's application of Rewire seems to be less than perfect and it may not be stable enough for you to use, but it's worth a try anyway.
    Jun 27, 2006
    46. Jan 31, 2005 4:51 PM (in response to (Ken_Nielsen))
    Have you tried sfz in standalone mode yet, Ken? Does that make any difference on the volume front?
    Jul 1, 2003
    48. Feb 1, 2005 10:23 AM (in response to (Ken_Nielsen))
    Ken - while we are waiting for Ozpeter to wake up (he's in Australia if you didn't know), let me respond.
    Plug-ins are mini-programs that work from inside a "host" program. Most VST effects are plug-ins. Most VST instruments are plug-ins. In this context, plug-ins are *.dll files. You cannot launch a dll file. It won't run by itself. It must be called from inside a host program. The beauty of this is that VST effects and VST instruments are not limited to just one or two programs. They will work in any host program that supports them. AA 1.5 supports VST effects but not VST instruments.
    A stand-alone plug-in is a *.exe program - or any other launchable extension. You can double-click on "plug-in-name.exe" and it will launch and run all by itself. It does not need a host program. In all other respects, "plug-in-name.exe" should work the same as "plug-in-name.dll" - if the plug-in's author says so.
    The advantage of using a plug-in in, say, Sonar is that you can record the output of the plug-in directly into Sonar (someone correct me if I am wrong about this). If you use the stand-alone version, it is not hosted inside Sonar - so you would need Virtual Audio Cables or some such to get the sound from "plug-in-name.exe" (the stand-alone) into Sonar.
    The author of "Savihost" has created a program to turn plug-ins into stand-alones. I gave the link above, but will repeat it here for convenience. If you wish to record the output of your plug-in, it makes sense to launch it from within the application with which you are going to record (e.g., Sonar; AA). However, if you are experimenting with different plug-ins and simply want to launch them quickly, turning them into stand-alones with the help of Savihost makes them easier to launch.
    You should be able to launch your sfz *.dll file with Savihost, and then load your Yamaha Grand. Two caveats, tho. You will need to rename "Savihost.exe" to SFZ.exe in the same directory where sfz.dll (or whatever the file name is) lives. This may then become the same file name as the stand-alone version of SFZ. Be careful of that. Second, Savihost is a relatively new program. You may discover that it works wonderfully well, or not well at all. If you decide to try it, let us know what you discover.
1 2 Previous Next
Actions
