Solution of this problem is very easy, first don't use any FTP software just because while uploading files the FTP software encode files which might not be compatible with Web Server, the simple solution is to use a Web Designing software which has the capabilities and most of them do have to upload the website files to the server (for example Dreamweaver, Golive etc.) This should solve your problem!
Yes but still not able to make these files work on the seperate pages I have created inside my site.
I am using these for client portfolios etc on their sites.. do not want this to show up in index and can't get nav bars to go in either???? I want to add this with nav bars to an existing site- not an easy task.
Got it to show up by using home page nav to click direct to gallery BUT can't nav to anything when on this page?
HELP!
Look at my site: http://www.chamoismoon.com On the Index page,
under "Last Update:" near the bottom are initials. These are client
portfolios. In Dreamweaver, I linked these initials to the Index of
the slide shows in the appropriate folders in the Assets file. Then
I chose to have them open in Blank pages since they are not part of
the main site.
It is also possible to upload to your site without a visible link.
Upload the slide show and then send the link to the client. For
instance: http://www.chamoismoon.com/Pope/Pope/index.html
Don't create a page on your site to upload to. The pages were
already created in the Bridge then saved to a specific folder in your
site folder.
Robert Campbell Photography / Chamois Moon
707 996 8338 main
707 953 2753 cell
http://www.robertcampbellphotography.com
gbaerial@sbcglobal.net
I use Mac OX 10.5.6, CS4 11.01 and Fetch 5.3.1. First I called Adobe and they said it was the "hidden" files that Mac OS X creates, for example .DS and _DS. Adobe said that when you called the index.html file with your browser, these files pop first because they have the . and _ character first (dot and underscore). Also said that since the site was hosted in a Windows based server andSo, being a Mac Geek, I open in the Mac Terminal>_ the option to see the hidden files in the Mac in every folder where the web galleries were being created. Not a single hidden file. So I called Godaddy (hosting my site) and told them what was going on. They switched (for Free) the hosting from a Windows based server to a Linux (Unix) based server and nothing. Then I just tried using Bridge upload option and it does works. I will post any other details of my research. Thanks for illustrating the rest of us!
Hello guys,
I managed to solved my problem.
The issue has something to do with the type of server that your web host is using. My server, unfortunately, uses some type of UNIX server which is not compatible with the Web Gallery upload feature of this Bridge CS4.
So you may want to verify this information first with your web host and see if that will be the issue.
I am having the same problem as everyone else.
I have tried changing the permissions which made no difference.
tried to load from Bridge to the server which also did nothing.
And have tried using fetch to load the directory unachanged as it
is made from bridge to my desktop.
I am on an Apache/Linux server
Adobe seems to offer little if any help with this issue
They should have left well enough alone rather than releasing a
program upgrade that obviously does not work correctly.
If anyone has figured this out I would love to hear what they
had to do
Its a shame that Adobe seems to care less about this issue
as it is a major flaw with the program, customer support seems to
be non-exsistent with this matter.
It's a permissions Issue for me too. For some reason CS4 Bridge seems to give directories a permission of 755 (correct for me) and the individual files in all directories a permissions value of 660 (wrong for me! I need 644). So, in my FTP app CyberDuck, I changed all the individual files permissions to 644 after I uploaded. My host is bluehost.com.
-N
I have had this issue and have not been able to make a functioning website using bridge.
Adobe has been unable to help me with this problem. They told me it was from my server.
Has anyone ever been able to make a website using bridge?
Here is my test site:
http://www.erinpatriceobrien.com/preview/maya/
This is what my server responded to me when I approached them with the issue.
the path to the xml file is not correct. so im thinking they missed a
step on the setup. or something got moved. who knows.
i downloaded the whole thing locally to test and it wont work on my
system either. again there is an xml file that references the images
that is not being loaded by the index.html page.
...which is located here:
http://erinpatriceobrien.com/preview/maya/resources/group.xml
and working fine.
the images are accessible too:
http://erinpatriceobrien.com/preview/maya/resources/images/large/TANGO_023.jpg
Yes, I have been able to make a functioning webpage with Bridge / Photoshop
CS4, on my Mac. I used the 'flash web page' gallery style and suggest that
you do that too to see if it helps you. Also, change your permissions on
all files to 755 and directories to 644 before you try testing. Are you on
Mac or PC?
-N
I am on a G5 with OS 10.5.7
How do I change the permissions?
I do it after I upload the site to my server. (I use CuteFTP for upload).
Right click the folder you want to change perms on and then select the Get
Info... (or equivalent command) and then change permissions - include the
recursive command checkbox. I change everything to 755 and then go back
and change the subdirectories themselves (not their contents) to 644. Or
you could do it through the finder. This widget may help
http://www.apple.com/downloads/dashboard/networking_security/unixpermissionswidget.html
-N
I don't see where you change the permissions. Can you do it in fetch?
I just spent another 2 hours with adobe on the phone with this issue and they keep saying its permissions.
