This discussion is archived
(Greg_L_Smith)
KERNEL32.DLL and DNG Converter
Feb 4, 2009 8:32 PM
I have Photoshop Elements 3 on my Windows 2000 PC. I just got a Canon Digital Rebel XSi/450D camera which saves RAW images in the .CR2 format. Looking for a way to update my PSE 3 so that it will work with the .CR2 files, I posted a request for help in the Tips, Tools, How-To & Techniques for Digital Imaging Forum.
Juergen D replied: The highest Camera Raw plug-in version for Elements 3 is ACR 3.6. It does not support the XSi. You can, however, download and install it and then separately download a newer version of the Adobe DNG converter, which does handle the XSi. Use it to convert the RAW files to DNG and then in turn open those files with ACR 3.6. I think, that is the way to do it.
I tried his suggestion, and the ACR 3.6 update was accomplished without any problem. Using the Adobe DNG Converter did not turn out as well.
The DNG Converter 4.4.1 looks like the oldest version that would support the *.CR2 RAW files from my Canon XSi/450D. The System Requirements listed on the download page for that version state that "Microsoft® Windows 2000 with Service Pack 3" or newer is supported, and I am using Service Pack 4. However, when I try to run the DNG Converter I receive the error message "Adobe DNG Converter.exe -- Entry Point Not Found." Additional details within the error box indicate that the problem is in KERNEL32.dll. I tried DNG Converter 4.4.1 on a second Win2000 SP4 PC with the same results.
Juergen D then suggested that I try this forum. I have looked at the topics that seemed to relate to .CR2 files, and the idea of using the DNG Converter to convert the .CR2 files to DNG seems to be correct. But, of course, only if I can get the DNG Converter to run! I will greatly appreciate any help that anyone can give me.
    Feb 5, 2009 3:21 AM   in reply to (Greg_L_Smith)
    I don't know if the latest offical version (5.2) of DNG Converter is compatible with Windows 2000, even though it is not mentioned. Perhaps an Adobe engineer can confirm that?
    A quick google of the error message produces a variety of problems related to incompatible multiple DLLs sometimes installed by applications. One person suggests installing .NET Framework, another suggests looking for duplicate kernel32.dll files.
    One thing I usually try is to update core Windows files with the latest service packs, runtime libraries, directX and drivers etc., but as Windows 2000 isn't supported any more, this makes the job much harder. I take it you've tried Windows/Microsoft Update, using the custom option?
    Feb 5, 2009 11:54 PM   in reply to (Greg_L_Smith)
    Automatic Updates only applies High Priority updates. I suggest manually logging in to Microsoft update (update.microsoft.com) and clicking on the 'Custom' button to look at the optional updates available, if you haven't done this already. There was a post-SP4 Rollup package and some more hot fixes released. You may or may not have these.
    It might be helpful to scan your hard drive for all occurrences of kernel32.dll (and their locations) and check the internal versions of each (using right-click > properties). You should be able to determine if you have the correct version from the Microsoft website.
