I haven't found this particular issue covered before, apologies if I have missed it. I am using a Windows PC running XP Pro SP2. My attempted installation of CS4 Web Premium (as an upgrade from CS3) failed early on when the installer said that I needed to install XP SP3. However, the results of running Windows Update does not list SP3 as an available update option (nor can I see it in my Update History). Before I search through the Microsoft Update pages looking for SP3, can anyone confirm whether SP3 is actually necessary? Thanks.
After paying the big bucks for this CS4 master collection software, I can't get it to install. I have 1.5 gig of ram, all slots full. Will it not install with that? The install won't let me install on a drive with 123 gig of free space, the install pop-up says there's not enough room please change location. I change it to another drive with 197 gig of open space and it won't install. Customer service is closed until Monday...I'll be back in class and don't get out until 8pm every frickin weekday.
I'm working on a sony the runs 3.20 ghz with the 1.5 gig of RAM running windows XP. I just reformated the harddrive but windows takes up the C: partition but the extention is 123 gig, and I have several other drives (with hundreds of gigs open) I've tried to put it on anyone of them....it says they're too small.
I've tried to install the trial version and it does the same thing. I'm at my wits end with this!
If there's only one out there willing to help me I would really appreciate, because Adobe doesn't seem to give a fig about helping me. I'm so thrilled that my purchasing this Master suite. Since I can't return it, I am throwing myself on the mercy of anyone who can help me with this
Adobe Creative Suite Web Premium CS4 - upgrade from CS2
Windows Vista Home Premium SP1 - 32 bit OS
HP Pavilion dv9720us Notebook PC - 2 gb ram
Installation Issues
Application Disk 1: The installation proceeded till there was about 1/4 left on the progress bar. It was in the process of installing Adobe Acrobat Pro. All the icons on my desktop disappeared, the install froze. I was unable to exit using the task manager. Finally had to use my on/off switch to get out of the freeze.
Attempted the install again a few hours later. The installer seemed to hang at the same point but this time the icons did not disappear. I gave it some time and eventually the program installed. It appears to be ok.
New Issues
Now I have new things happening that weren't happening before.
• I have some programs that I right click and "run as administrator". Now, if I right click on any desktop icon the installer for Acrobat Pro comes up. Why is this happening and can I make it stop?
• My Adobe Flash player is now totally broken. I have always had issues with it but I had a workaround for it that seemed to work. I have the following icons on my desktop:
-- the Adobe uninstaller (downloaded from the Adobe site)
-- the executable Flash Player with Active X installer
If I right click on the uninstaller and run as administrator, then do the same with the installer at start up I am able to have Flash in IE7. This has worked for me until yesterday. Now when I try to install (using the above methods) the install fails and directs me to tech note 19166. I really need a functioning flash player.
I would like to open a web support ticket but I have been through the support pages and can't find how to do that.
Can someone please help me. I've tried to install CS4 and every time it's checking the setup, it stalls at 90%. I don't get any error messages or BSOD like a lot of you are talking about. It just simply hangs there. We've gone out and purchased additional RAM, turned off the virus program, ran registry cleanup, ran the Adobe script, etc... we've tried everything. It still just stops at 90%. I am not a technical person, but I have been installing software programs for 20 years, this is the first time I can't install a program. Can someone please tell me what the problem is? Thanks.
For those getting BSODs (Blue Screen of Death) during installation on Windows 7 or Vista, the issue is probably related to the installation DVDs. Maybe some DVD drives don't play well under Windows 7 with those installation DVDs, or whatever else the issue may be, there is definitely a problem with the installation discs, as those numerous complaints about them indicate.
I've had problems installing Production Premium CS4 on Windows 7 RC (beta went fine) using the installation discs. Win 7 RC just didn't play well with the Adobe installation DVDs so I installed the suite directly from a hard drive. Worked perfectly. Here are the steps again in case you can't find Adobe's document about it: http://kroycom.com/blog/2009/bsod-install-adobe-cs4-on-windows-7-or-vi sta/
Again this is not a solution if you're low on disk space, or if you clogged your system with antivirus or other junk software. See my notes on that at the end.
Hi, was wondering if anyone could help me. I'm installing Design premium CS4 on 32bit Windows Vista. The installation goes through seemingly alright but then when i try to open Dreamweaver, Flash or Fireworks it brings up an error message saying
"The application failed to initialilze properly (0xc0150004)" with these details
Problem signature:
Problem Event Name: APPCRASH
Application Name: Flash.exe
Application Version: 10.0.0.544
Application Timestamp: 48c73089
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6002.18005
Fault Module Timestamp: 49e03821
Exception Code: c0150004
Exception Offset: 00009eed
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 2057
Additional Information 1: 9d13
Additional Information 2: 1abee00edb3fc1158f9ad6f44f0f6be8
Additional Information 3: 9d13
Additional Information 4: 1abee00edb3fc1158f9ad6f44f0f6be8
All the other programs work fine, its just those ones that won't even open. I've tried reinstalling in every different way i can think of, without AV, with MS SQL and IIS switched off, from desktop with selective startup, you name it and it still has the same problem.
Can anyone help with what might be causing the problem?
Also, when i look in install logs it brings up this error
ERROR
Log of: object
isRunning {string}: 0
percentComplete {string}: 100
message {object}: [object Object]
Log of: object
code {string}: 0
args {object}: [object Object]
which i think refers to the installer freezing when checking the system profile on install but it seems to go through install alright. It also has the following errors.
ERROR
The payload with AdobeCode: {35304775-CB5F-101B-A142-83B5468C225C} has required dependency on:
Family: InDesign
ProductName: Adobe InDesign CS4 Icon Handler x64
MinVersion:
This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
Removing this dependency from list. Product may function improperly.
My problem is simply this:
1.I bought this Production Premium from Gradware.
2. I turn everything off as said previously, however when it says checking system profile (Which is the first thing it does) it says:
=Setup Error=
-Setup has encountered an error and cannot continue.
3. I called Adobe and they were absoultely no help.
4. When I opened the box, the CD case was already halfway opened.
Hi. I tried virtually everything in the forums when my Web Design Premium CS4 install froze at the 80-90% and never proceeded. Finally, by deleting one phrase (windows.external.) from the Containerproxy.js file, CS4 installed like a dream -- no glitches, stumbles, or "issues." Here's the link where I found this "solution":
http://kb2.adobe.com/cps/407/kb407428.html
Good hunting!
I deleted the window.external. but when I run the setup.exe from the original media, it will override the ContainerProxy.js file with the default version. So I have to install from Add Or Remove Programs or Programs And Features the Adobe Creative Suite 4 Master Collection! but the not finished installation doesn't react! what can I do? or are there other possibilities to run it?
I admit it -- I've posted the same message elsewhere -- don't know what else to do to get help!!
I just spend thousands of dollars purchasing CS4 Master Collection to install in Windows 7 Professional. I figured a new operating system with a clean install along with a newly purchased Adobe Software Suite -- no problem...
Boy was I wrong. Installer quits with error 1603 everytime I run it. I've searched all over for solutions and tried everything I could. Finally called Adobe Technical Support (worthless)...they registered my program's serial number through support before they would help, even though it doesn't install. Said I need new disks -- the disks must be bad, so I should try an ftp download through Customer Support. Then they passed me on to Customer Support, for an ftp download -- only Customer Support tells me an ftp download for CS4 doesn't exist. You'd think the Technical Support people would know if that's the case (Another example of Adobe's inept practices) Customer Service then proceeds to tell me there is nothing they can do. Thy WILL NOT REPLACE MY DISKS, because I purchsed the software through a vendor. They then told me to go back to the vendor and ask them for replacement disks.
When I checked my Adobe account online, my "support" case was then listed as CLOSED!! The problem has not been solved, but Adobe wants to write me off. Go Figure....typical Adobe.
So now I'm stuck -- days of frustration later, Adobe won't stand behind their product. I'm now left fighting with a vendor for replacement disks which may or may not work, or for a refund, which they tell me may not be possible because I have already registered the product with Adobe through Technical Support. Catch 22 --
ONCE AGAIN ADOBE SCREWS THE LITTLE GUY -- I don't even know where to go from here.
Bob,
Thanks for answering my forum posts -- I wasn't trying to spam -- just get someone's attention.
I already copied the first installation disk to my hard drive and tried installing from there. The disk copied over just fine, and the installation process did exactly the same thing. I've not only turned off all firewalls, virus protection, etc. -- I uninstalled them just in case they were the problem.
Other than wiping the disk clean, reinstalling Windows 7 Professional, and trying to install CS4 again, I don't know what to do.
Did you run the CS4 clean script before trying again?
http://kb2.adobe.com/cps/403/kb403995.html
Bob
Bob,
Thanks for the suggestion (which technical support never mentioned). However, I ran that even before I called them -- it made no difference.
As to system info: I'm running an Intel Core 2 T7200 processor with 2 gig of RAM on a 32-bit Installation of Windows 7 Professional, with a 300 gig hard drive.
Bob,
It's not the disks -- I went to a coworkers computer and tried the install there. He's runnin xp sp3, and installation (trial version) went fine. I tried it again under trial version (thinking there may be a difference) on my computer same error stops the installation. So I'm down to Windows 7 issue, or a hardware issue.
I followed your suggestion, ran the CS4 cleanup, restarted the computer, created a new user, restarted again, logged on under the new user account, and ran the installation again. The installation failed at the same spot.
I am now in the process of stipping my hard ware down to the bare essentials -- I'll tackle the possible hardware issuses first.
hey i've seen your good whit adobe so i though i could ask you about my problem.
I've tried to download adobe after effects cs4 from internet (the trail) but when im installing the first part goes okay but then its somthing 2nd part installing that always stops when its almost done!!
i'll attach a picture
I decided to go from trial to CS4, when I tried to install the new purchase I received the Vista Service Pack 1 Required error, but I already have SP2 for Vista. Long story short I've gone so far as to completely format this PC so the only thing on it is IE, and my CS4 download, and I'm still getting the same error.
Having difficulty installing CS4 Web Premium Student Edition on XP SP3 laptop and Vista laptop. Software freezes at "Preparing to Install" after about 25 seconds or so, then gives the option to select "Install" or "Back."
Contacted Adobe support about 4 times. Followed all of their suggestions, including copying software to hard drive and creating new user. Unsuccessful with original purchase Student Edition software, replacement software from Adobe, 30-day trial software purchased in summer, and new student edition software purchased two days ago. Downloaded and ran Windows Installer; downloaded and ran Adobe Clean.
My XP has 500 MB and 1.8 GHz. The Vista laptop has 1.5 GB and 1.6 GHz. Adobe recommends minimum of 1.0 GB and 2.0 GHz. However, was successful in loading the software on another XP SP3 laptop with 750 GB and 1.3 GHz.
Frustration building. Please help!
Currently having the same problem. 3 days ago I was running my Fire Works program that is part of Premium 4; I went into the properties of Fireworks because sometimes it crawls aka slow compared to the other Adobe programs on the software. I changed the settings from Windows 7 to Vista later service pack, never had any issue when I had done this in the past, suddenly my Adobe programs wouldn't open up; a user acceptance agreement window kept popping up. I'd click yes to accept it and nothing happened. I uninstalled and then reinstalled it, from there things went down hill, all of my other programs would install minus Photoshop, Indesign, Ilustrator, Flash etc.; the primary programs.
I called a tech. this Sat. with no progress, they suggest that I call them on the busines days, but I got a feeling that they will no figure it out, because the Tech. service just blows. I'm not likng this at all, because I see a lot of bugs in this software that are also posted on their website. This is too much money paid to have these kind of issues.
North America
Asia Pacific
