Fillable fields in Framemaker 8
May 21, 2008 7:25 AM
Can you create fillable fields within Framemaker files in Framemaker 8?
Thanks!
Meaghan
    May 21, 2008 8:02 AM   in reply to (Meaghan_Campbell)
    How do you define a fillable field
    keep smiling
    thomas
    May 21, 2008 11:07 AM   in reply to (Meaghan_Campbell)
    Meaghan,
    See Shlomo Perets TimeSavers Form Assistant option:
    http://www.microtype.com/timesavers_Assistants.html#FormAsst
    May 21, 2008 12:34 PM   in reply to (Meaghan_Campbell)
    Meaghan,
    Do not hesitate to follow Arnis' advice.
    keep smiling
    thomas
    May 22, 2008 10:30 AM   in reply to (Meaghan_Campbell)
    Meaghan:
    From the website:
    >Form Assistant enables you to include the definitions of Acrobat fields in FrameMaker through hypertext markers, so that they are automatically present in the PDF file (FrameMaker-to-Acrobat TimeSavers required during distilling): buttons, check boxes, menus, radio buttons, text fields and digital signatures, with complete control over field properties (including active field highlighting and field calculation order). Also included: an AutoPopUp function, which defines automatically-sized variable width/depth popups.
    >Feature demos (distilled with TimeSavers+Form Assistant):
    It clearly says that you need both.
    May 22, 2008 1:10 PM   in reply to (Meaghan_Campbell)
    Meaghan,
    The way it works (in brief):
    The PS files created from FM contains a number of PDF marker (derived from FM markers etc.). These markers needs to be converted into PDF functionality (e.g. form fields).
    To do this two files are need for ACROBAT DISTILLER: Prologue.ps and Epilogioe.ps. These files are supplied by TimeSavers!
    FormAssistant is a kind of an add-on to TimesSavers.
    FormAssistant alone does not contain epilogue.ps and epilogue.ps.
    keep smiling
    thomas
    Nov 17, 2013 12:38 AM   in reply to (thomas_bro)
    Defining PDF form fields in source FrameMaker files (with TimeSavers + Form Asst v3)
    (free webinar)
    Thursday, November 21, 2013 11:00 AM - 12:00 PM PST
    Register at: https://www3.gotomeeting.com/register/277486510
    Adding form fields to PDFs in Acrobat manually is labor-intensive. Using FrameMaker-to-Acrobat TimeSavers & Form Assistant, you can take advantage of all of FrameMaker capabilities to author documents that, upon conversion to PDF, will automatically contain text fields, check boxes, radio buttons and additional controls.
    With Form Assistant 3, markers can be inserted through a dialog box (FM10/11, as Extendscript is required).
    This will also be demonstrated in the webinar.
