2D Block Arrows
Oct 22, 2008 12:07 AM
I am trying to mark some military type maps with large, sweeping, curved 2 dimensional block arrows that will demonstrate movement of men and equipment. I seem to have hit a block on an easy way of doing this, can anyone help me with this process?
Neil
    Oct 22, 2008 3:13 AM   in reply to (Neil_Powell)
    Once you've drawn your arrows straight you can try Effect : Warp and experiment with the options there, for example Arch. Best group the arrows first so that they distort as a whole.
    On the other hand, if you've got a lot of basically parallel arrows that you want to fan out to show like troop movements, it might be a better bet to do it in Photoshop using Edit : Transform : Warp. It's easier to control the warp with the Photoshop warp frame.
    It's probably best to paste the straight arrows into Photoshop as a Path and warp the path. Then you can copy it back into Illy as a vector object. Careful though; paths copied from Photoshop come as compounds, so at some time or other you will probably need to release the compound. Otherwise you won't be able to colour each arrow separately.
    Oct 22, 2008 4:15 AM   in reply to (Neil_Powell)
    Create Brushes.
    Artbrushes scale the artwork along the path.
    Pattern Brushes repeat tiles along the path, and have separate end tiles.
    ArtBrushes and PatternBrushes can be combined into one-click effects by applying multiple strokes to a single path in the Appearance Palette and then storing as a Graphic Style.
    I keep a collection of frequently-used sweeping arrow brushes in all my startup files and preset templates. See item 6 below:
    JET
