Hi cmyck,
I just lost several hours trying to fix this problem. Your fix just saved my day. Thank you! And I agree that this is indeed a bug. Setting the bleed in "Save a Copy" as PDF should behave the same as setting the bleed in "Document Setup".
Cheers,
Bernhard
Wow, I'm glad someone found it useful. ![]()
It is sad that Illustrator does not provide updates.
Adobe only sells you the next version as an update.
I am glad that I did not waste my money buying CS4. The bad news is that I have CS3. I am afraid to buy CS5 and end up with more bugs that Adobe wont fix.
Thank you for your solution!
Everybody would benefit if Adobe had some serious competition.
They probably know very well how bad their reputation for fast and sleek apps is.
But they don't bother to react, since they own the market. As long as the cashflow is in the green, investors don't care.
This will backfire eventually.
I don't experience any of the above: I add bleed and crops and other stuff in the bleed area, save pdf, open in acrobat and its all there - The only weird thing is that if I put trims on in acro thay trim to the bleed area
You most likely set the bleed in the document settings. And then you woulnd't experience the problem.
It only occurs if you set the bleed in the output settings during a save (save as PDF) [without having set it in the document settings]
I just confirmed the bug again in version 14.0.0.
Please, double check before you post contradicting findings. It confuses people.
Where is the CS4 update?
Copyright © 2009 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
