Convert PDF text to curves
Jul 14, 2008 7:51 AM
I need to do a couple of minor text changes to a menu that I have been sent as a PDF. When I open the file in Illustrator CS2, it all works except for the headings - which are in a font (Shelley Allegro) that I don't have.
The headings look fine viewed in Acrobat 7 Pro, so obviously there is an embedded subset of the font in the PDF.
Is there a way to convert the text to curves when opening the file? I don't need to edit the headings - but I don't want to rasterise them by opening in Photoshop either.
    Jul 14, 2008 1:58 PM   in reply to Guest
    "Is there a way to convert the text to curves when opening the file?"
    technically...NO.
    However-make a copy of the PDF--open the copy in Acrobat Pro--save as EPS click 'settings' go to 'transparency and flattening(look for the check box that says 'convert all text to outlines'--then open EPS in illustrator and copy 'heading text'--open original PDF in illustrator--delete headings--paste copied 'outline text' into file....then continue with your edits...it's a bit of a workaround...but it should accomplish what you need...
    Jul 15, 2008 4:19 AM   in reply to Guest
    You can see if the fonts are embedded in Acrobat (file> properties) if they are, you may be able to make the edits in Acrobat using the select text tool (or pitstop if you have it). A PDF may appear to display properly without embedded fonts, but editing and printing is dicy. Outlining is old-school, but if you must, this will work: In Acrobat go to document> watermark> add> text> (hit space bar) opacity 99%> OK.
    Then, advanced> print production> flattener preview> convert all text to outlines> apply> save. The idea is to add transparency to the PDF (with an invisible watermark) then use the flattener preview to force outlining.
    Edit- These instructions are for Acrobat 8, for 7 use Tools> print production> transparency flattening.
    Jul 15, 2008 4:26 AM   in reply to Guest
    I think tman's suggestion should work, but I haven't tried it. However, what works for me is:
    - Place the .pdf in InDesign
    - Give it an opacity other than 100%, for example 99%
    - Create a Flatten Transparency preset that forces all text to be outlined
    - Export the document to an .eps file and choose the above created preset
    - Open the .eps in Illustrator
    Aug 13, 2008 5:43 AM   in reply to Guest
    I was able to place the pdf in Illustrator CS3 and then go to Object/Flatten Transparency. In the pop-up window check turn fonts to outlines. I didn't need to change the transparency.
    Aug 17, 2008 8:48 AM   in reply to Guest
    If you have pitstop, you can use this to convert text to outlines.
    Tman's suggestion will work. Kurt's suggestion also works.
    Another method, link place the pdf in Illustrator. Select the linked element, object flatten transparency with convert fonts to outlines.
    All methods require embedded fonts in the pdf.
    Every method, except using pitstop, will flatten transparency.
    Aug 18, 2008 9:26 AM   in reply to Guest
    Luke says that outlining is old-school.
    All the same, if you want to be 100% certain that things get printed the way you want them, it's the only foolproof way to do things, especially if you're using unusual or homemade fonts.
    Thing is that fonts are identified by a code number, so if your printer has a font with the same id-code as yours you will get his version - even though your font and his are totally different. No amount of embedding will prevent this.
    I have seen it happen numerous times and it still happens every now and again.
    Aug 18, 2008 2:56 PM   in reply to Guest
    Any suggestions for changing several long Pages (iWork '08) documents into CURVES or Line Art for printing? The above is great, but would take FOREVER to do page by page... and I'm new to this, if that's not obvious :-)
    Thanks!
    Aug 18, 2008 11:14 PM   in reply to Guest
    Emily - why would you want that?
    Aug 19, 2008 2:02 AM   in reply to Guest
    The fonts aren't embedded in the PDF files when I print to PDF or export to PDF from Pages, so they're not appearing correctly for the printer...
    Aug 19, 2008 9:19 AM   in reply to Guest
    Emily - did you check the file in Adobe Reader or Acrobat Pro if the fonts aren't embedded? What I can see Pages (in my case '08 version) embeds a subset by default. Just chekc the file Properties in Acrobat to see what it did. In Acrobat Pro and Preview you can also resave the pdf created as a PDF/X file.
