Home/Support/
Forums
3308 Views 18 Replies Latest reply: Mar 8, 2008 9:29 AM by JETalmage RSS
Mobius Strip User 137 posts since
Aug 11, 2002
Oct 27, 2007 4:46 PM
Option to select only fully-enclosed objects during drag-selection.
Another baffling omission in the product: A way to select multiple objects when they're amidst others, by NOT having the marquee select everything it touches. There should be an option to select only the objects that are fully enclosed by the selection rectangle.
Corel Draw has always offered this, and in practice I never needed to turn it off. I can't think of another UI feature that enhanced productivity more. What are Illustrator users doing as a workaround? Shift-clicking on things one at a time? Tedious and omission-prone!
  • frax_-L75d7K User 80 posts since
    Jun 25, 2004
    I have never felt that this is a big problem. A lot of my selections are through the layers palette, or select by color/stroke (selection menu, and more rarely using the wand). Also select by group (group selection tool).
    My documents are reasonably well organised in the layers palette though.
    Then there is the lasso tool.
  • NotInUse User 763 posts since
    Aug 11, 2002
    Depends upon how it's added.
    I can see why you feel it's needed David. Good luck with it. For me, I've never missed such a feature in Illustrator, but then I started long before there was a lasso tool as well.
  • Kurt Gold Participant 977 posts since
    Mar 20, 2004
    I've always missed that feature in Illustrator. It is quite disconcerting that this kind of basic stuff is still not implemented.
    What do you mean, Scott?
    I think it's just obvious how it should be added. Either by pressing a modifier key while dragging with the Selection tools in order to switch to the "touch-sensitive" selection behaviour or by providing a general option for the Selection tools.
    Or better yet: Add both models.
    Aug 11, 2002
    I've learned not to try and guess at what implementation route may be taken.
    And you prove my point, Kurt.
    >to switch to the "touch-sensitive" selection behavior
    This means the standard behavior that's been around for 20 years would now require a modifier key. Not good. Leave the standard behavior alone, require a modifier for the new behavior.
    Mar 20, 2004
    This is just a misunderstanding due to my wobbly English skills, Scott.
    By saying "switch to the touch-sensitive behaviour" I meant just what you're describing, that is, press a modifier to get the "new" selection mode.
    But again, in combination with a general preference to set the default behaviour, the user could decide what the modifier key actually does do. I think that would be nearly ideal.
  • Scott Falkner Contributor 4,441 posts since
    Apr 8, 2003
    We're going to need new keyboards, since all available modifiers already have a task. I guess any key can be a modifier (space for Hand tool).
  • Calculating status... 3 posts since
    Jan 15, 2007
    Some people might think that their layer palette or shift-click solutions are ideal, but i think they would be amazed how much time the freehand selection method could save them.
    No need for all the locking/unlocking and creation of extra layers.
    I personally find that layers can get messy to navigate very quickly.
    Why not make it switchable in the preferences if there are no usable keys left?
    If Adobe merge the A and V keys that currently switch between arrows (this should be a toggle switch anywyi in my opinion) the a or v would be free.
  • JETalmage Contributor 3,234 posts since
    Aug 13, 2005
    Very very true.
    In FreeHand, a doubleClick on the selection tool provides a "Contact Sensitive" checkbox for marquee selections. Pressing a momenatry modifer allows you to quickly and fluidly select underlying objects (including hidden points). A momentary modifier allows you to drag retracted handles out of their anchor points individually. A momentary modifier allows you to bend straight segments without switching tools and without adding an unwanted point to the segment. There is no tedious switching between "direct select" and "normal select" and "convert anchor point" tools, and yet you can do far more operations than possible in AI.
    While drawing paths, FreeHand users can do most everything they need without breaking stride mererly by using the three main momenatry modifiers, Shift, Ctrl, and Alt.
    The problem of all of Illustrator's available keyboard shortcuts being "used up" is itself both a symptom and a proof of the horribly inelegant and cumbersome design of Illustrator's interface.
    Competing programs do all this stuff more easily, more intuitively, and with the use of a small set of momentary modifier keys. As always, other programs do more with less complication than does Illustrator.
    Illustrator's whole selection interface--and its whole environment organization scheme sorely needs to be rebuilt from the ground up. It is inefficient, scattered, and unnecessarilly tedious in too many ways to list here.
    JET
  • Michael Brown12 User 89 posts since
    Sep 13, 2004
    I've been begging for a lasso tool since I had to switch to AI from Canvas four years ago. I mean, why do you think they call it a lasso tool? Remember what a real lasso does? What AI has is anything but a lasso.
    Every other application that has ever been written that has a collective select tool works in this way: it selects everything inside it. Some CAD programs also can select contacted AND enclosed items with a key combination.
    In my experience, and this is purely anecdotal evidence, the only people who look puzzled by this request are those who have only used Illustrator. They have learned to work without it, as I have, but every time I find myself turning off layers just to select a few buried objects I curse a bit.
    This feature is second only to multiple pages in priority, in my opinion.
    MGuilfoile
  • Calculating status... 10 posts since
    Aug 11, 2002
    I'm not one who typically defends Adobe, and I still think I could work in Illustrator 6 faster and more efficiently than in any version since, but I have never found selection to be a problem,
    The lasso tool hard-selects everything it contains and leaves as soft-selected all points that are connected to the contents of the selection lasso. To me, this is not only intuitive, but also works well. IMHO, if you are using the lasso tool and you don't want something selected at all, then wiggle your lasso around only the things you want to select. That's why it's a lasso, not a rectangle whose boundaries are not flexible.
    Maybe the rodeo riders who also use real lassos will complain that a true lasso always has a perfect contour. Maybe the lasso is not the best metaphor for the tool, which behaves more like a butterfly net. Alas, I guess it depends on what creatures you want to capture.
    Sep 13, 2004
    That isn't how my Illustrator lasso works. It selects everything it touches equally "hard." If the group of objects I want is part of a larger group of objects there is no way to "wiggle" or otherwise manuever the lasso to just select what I want. Everything it touches is selected.
    Just curious, but do you use other graphics/CAD programs? If so, pull one out and you'll see how I'd like the lasso to work. It doesn't matter which one, they all work the same (except for AI.) If you only use AI, well, that's sort of my point.
    The salient feature of a rope lasso, by the way, is not its shape, but the fact that it captures what is inside it.
  • User 23 posts since
    Aug 11, 2002
    That's funny. I must have a super secret version of AICS3 because when I use the lasso tool it only selects the points I surround with the tool. What it doesn't do, thank god, is select the all the objects that the lasso's tool has crossed. That's what the move and direct select tools are for.
    Aug 13, 2005
    Stuart,
    What the others in this thread are talking about is the need to lasso-select only objects (at the object level, not the anchorPoint/segment level) which are fully within the lasso marquee.
    In other words, a "black lasso," given Illustrator's cumbersome insistence that separate pointers should be required for object-level/subselect selection.
    If I'm not mistaken, Illustrator used to have both a "normal select" and a "direct select" lasso.
    > ...when I use the lasso tool it only selects the points I surround with the tool....
    No, it doesn't. It also selects any segments it touches. Those so-called "selected segments" do not have to be fully enclosed. They are selected whether you enclose one of their anchorPoints or not. That's part of the problem.
    Illustrator does not provide user-choice between a marquee (drawn with the Lasso or any other tool) selecting objects merely contacted as opposed to only objects fully enclosed. Other programs have long provided that choice.
    JET
    Aug 13, 2005
    The need for a "contact sensitive" setting in not just the lasso, but the other selection tools as well has been discussed, re-discussed, and well, just plain cussed here for years.
    I still think it would be a wonderful thing for the rightClick contextual menu to offer two options whenever any closed path is selected: Make Selection and Make Cutting Path.
    You know how a pixel selection in Photoshop can be traced into a vector path, right? You know how a vector path in Photoshop can be flattened to a selection marquee, right?
    So why would that not be just as advantageous in a vector program? Heaven knows one of the things most needed in Illustrator (and which it has NEVER had) is a decent cutting tool. But why have to manually and clumbsilly drag along a freehand path to make a cut with a knife? Why have to manually and clumbsilly drag along a freehand path to make a lasso selection?
    Give users the ability to draw a path, by whatever means he chooses, and then simply convert that path to either a marquee selection (yes, with a "contact sensitive" option) or a cutting path. That seems so common-sense, yet I don't know of any drawing program that offers it.
    JET
  • Calculating status... 1 posts since
    Mar 3, 2008
    I am a large format printer and get files from a variety of designers. Since most of them will not draw on seperate layers, I desperately need Illustrator to have a 'select only enclosed' feature! The owner of my company won't even work with Illustrator until it does (he uses Corel :-P ). PLEASE include this feature in future builds!!!! It can't be that difficult and according to the web it is a HIGHLY desirable feature.
    Thank you
    Aug 13, 2005
    > It can't be that difficult...
    And, of course, it's not. The only explanation is that it (like so other mundane but long-needed practicalities) is too low on the priority list of the AI marketers.
    Meanwhile, my workaround is a pair of Javascripts, which you may download if you what:
    http://www.illustrationetc.com/AIbuds/JET_PathScripts.zip
    The .zip archive contains several scripts. The two specifics are:
    JET_MarqueeDeselectPartials.js
    JET_MarqueeSelectRest.js
    After making a white pointer or lasso selection, running the DeslectPartials script deselects paths which are not completely selected. Running the SelectRest script adds the rest of the anchor points of only partially-selected paths to the selection.
    JET
