Here's what worked for me,
I am using CS3. I was working with a template. When opening I would get the "font problem" alert. "The missing font was substitued with another when opening."
If I tried to save the document as an AI it would save. But, If I tried to save as an EPS I would get the following response,
"Can't save the illustration Cant print the illustration" Then I also got....
"Can't save the illustration. Not enough memory was available or object was too complex. reducing the size of this document window may help."
If I create outlines to the text of the template, before saving as an EPS, this fixes the problem.
Is there a setting to choose the defaut font to be used?
I've tried all of these fixes...listed in this thread. I've read about Zune and Microsoft Media entertainment players being the problem. I've disabled everything. I'm not using text in my file. My file is not large. Nothing has worked. Unchecking the .pdf compatibility... trying to print to the PDF printer... none of it has worked. I'm using CS3 with more than enough RAM... it's all bogus... nobody has found the real issue. I've been in tech support for years... none of these fixes are fixes... by some unknown reason... they've stumbled upon an anomaly that appears to fix their save issue. The save issue is alive and well. I can't fix my issue because I don't have the same anomaly. I've had it for months. Where's the real fix? p.s. I can't send you the file... because it won't save! I can send you an .eps version of it but I don't think it's the graphic that's the issue.
Same problem here.
Illustrator CS4 running on brand new Sony Vaio with Windows Vista Home Premium 64 Bit.
1. I create a new file. Draw a square and write some text.
It does NOT save AI but it saves EPS
2. I remove the text from the file.
It saves AI and EPS.
Why does Adobe has a bug since CS2, as I see in this forums, and does not solve it?
Worse than that, how can they release a CS4 version still with this bug?
And this bug has been reported ... at least since 2005!
I am really not able to understand this ... really ...
Cheers,
Miguel
I have read every post on this thread and have tried every "fix" - without success.
I am running Windows XP Pro and AI CS2 (12.0.1). I have plenty of memory and plenty of disk space. My IT departrment installed AI CS2 about 6 months and it has worked fine. It was the first time illustrator had been installed on my computer.
A few days ago I opened an .ai file and made some changes to it and tried to save it under a different name. I did a "save as" from the file menu and the title bar went from blue to gray and the program stopped - no error message. Nothing worked. I pressed the ESC key and it returned to normal.
I can use all of the functions of the program to change my illustration and then simply save it under the same name, but I could not do a "save as." I also can not open an .ai file from within the program (although I can double-click the file icon and it will open). I cannot "place" a file in illustrator, but I can copy and paste from photshop to illustrator with no problem. I can even open a file if I do it through the "open recent" and "new from template" menu list.
Also, the only way I can convert the file to .png (for insertion into Word) is to print to PDF and then open the PDF in photoshop and save as .png. This is driving me crazy. I deleted the settings files and re-launched AI. I tried uncecking the "use PDF" when using the clipboard. I even changed the scratch disk from "Startup" to my local D: drive. I tried everything - almost.
The only thing I haven't tried is to remove and reinstall the program (BTW it is not part of a suite). My IT department is VERY reluctant to do this because they, too, read these forums and have seen posts where the person stated that re-installation wasn't successful.
Any help will be greatly appreciated.
Robert Horton
Robert,
Sometimes, it is better to Move the folder than to just delete.
Problem resolved - I am on Win7 32-bit, running Illustrator CS2 and Adobe Reader 10.0. Post # 141 (reproduced below) provided the instructions necessary to fix the problem for me, which started just about two weeks ago.
"141. Dec 8, 2007 3:23 PM (in response to Guest )
Re: Can't save in Illustrator CS2
North America
Asia Pacific
