Illustrator CS3 - How can I remove a "linked" image???
Jan 23, 2009 9:11 AM
I have an illy file that has several "linked" images.
Some of these I wanted to keep and have embedded.
However, I would like to delete two in particular...which the images are no longer available or desired. But I see no way to do this.
I have tried to go to outline mode/wireframe view... and there are no boxes indicating where these images should go...so I can't delete those.
The two images that Illy keeps asking for when I open the file have a red ? to the right of the image names.
How can I permanently get rid of these?
Thanks.
    Jan 23, 2009 9:16 AM   in reply to Todd-sta
    Select image, delete. You can go to the image (which means select it and scroll to its position) using the Links palette.
    Jan 23, 2009 11:50 AM   in reply to Todd-sta
    Click on the link in the links pallette. At the bottom of the links pallette there is a button that says "go to link", click that. That will show the picture in the document, then you can hit the 'delete' key.
    Mar 15, 2013 4:34 PM   in reply to Ozzwoman9
    AI CS5. I have sometimes have missing images that do not show themselves this method. Usually a complex file with a lot of layers. Have made sure all layers are unlocked, but still cannot find the offending image. AI will nag me on every open to replace this image.
