Yes, Quark does have an easy as pie way to turn off Hyphenation. Under the Edit menu, select H&Js (hyphenation and justifications) then double click on No Hyphenation. This will open a window that shows the current settings for No Hyphenation. If the Auto Hyphenation box is already Unchecked, just click OK or press Enter. If there's a check in the AH box, just uncheck and click OK.
Now click the Save button and you're all set. Easy peasy. This is just one of the many many reasons I prefer Quark over ID. But that's me.
I try the script, but doesn't work in table, how can also turn off hyphenation in table's text with javascript?
@creativejoan0425 – As you can see tables have to be accessed separatly.
Also footnotes.
The following script handles also footnotes and tables (but not tables inside tables!):
//TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx
//Uwe Laubender
//DESCRIPTION:Does NOT work for TABLES INSIDE tables!
//See discussion at:
//http://forums.adobe.com/thread/323599?tstart=0
* @@@BUILDINFO@@@ TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx !Version! Fri Dec 06 2013 11:24:16 GMT+0100
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
app.doScript(_TurnHyphenationOff, ScriptLanguage.JAVASCRIPT, [], UndoModes.ENTIRE_SCRIPT, "Turn off hyphenation");
alert("Done: Hyphenation is off for all stories, footnotes and plain, not nested tables.");
function _TurnHyphenationOff(){
var everyStory = app.documents[0].stories.everyItem();
//Plain stories:
everyStory.texts[0].hyphenation = false;
//All footnotes:
everyStory.footnotes.everyItem().texts[0].hyphenation = false;
//Plain table cells (NOT NESTED TABLES):
everyStory.tables.everyItem().cells.everyItem().texts[0].hyphenation = false;
}; //END function _TurnHyphenationOff()
You can undo the script in one go…
Uwe
If I want to do it in a selection? I want to select a table row to turn off hyphenation, how can I do?
從三星手機發送
Do it manually -- select the text in the row, choose Hyphenation from the Control panel flyout menu, and clear the checkbox.
That would be:
app.selection[0].cells.everyItem().texts[0].hyphenation = false;
Uwe
It doesnt work
從三星手機發送
With a table row selected, it will work. I tested that…
Or did you ask how to select or adress a table row to turn hyphenation off? If yes, which one?
For a table put into the variable myTable, for the first row of that table it would be:
myTable.rows[0].cells.everyItem().texts[0].hyphenation = false;
The variable myTable can stand for any table in a document.
To make myTable the first table in a specific story, select a text frame of that story and:
myTable = app.selection[0].parentStory.tables[0];
Uwe
Here is my script, I use the Adobe FindChangebyList to make some modified, I want to clear the hyphenation and break link to style when I select texts or table row, or maybe a cells, can you help me to fix the error? thx ver much
main();
function main(){
var myObject;
//var myCheckSelection = false;
//Make certain that user interaction (display of dialogs, etc.) is turned on.
if(app.documents.length > 0){
if(app.selection.length > 0){
switch(app.selection[0].constructor.name){
case "InsertionPoint":
case "Character":
case "Word":
case "TextStyleRange":
case "Line":
case "Paragraph":
case "TextColumn":
case "TextFrame":
case "Text":
case "Cell":
case "Column":
case "Row":
case "Table":
myDisplayDialog();
break;
default:
//Something was selected, but it wasn't a text object, so search the document.
//myFindChangeByList(app.documents.item(0));
//alert("Nothing Selected, Please Select Text Frame or Text.");
else{
//Nothing was selected, so simply search the document.
else{
alert("No documents are open. Please open a document and try again.");
function myDisplayDialog(){
var myObject;
var myDialog = app.dialogs.add({name:"Joan New Clear Setting_v1.0"});
with(myDialog.dialogColumns.add()){
with(dialogRows.add()){
with(dialogColumns.add()){
staticTexts.add({staticLabel:"Search Range:"});
var mySearchButtons = radiobuttonGroups.add();
with(mySearchButtons){
radiobuttonControls.add({staticLabel:"Current Document", checkedState:true});
if(app.selection[0].contents != ""){
radiobuttonControls.add({staticLabel:"Selection", checkedState:true});
with(borderPanels.add()){
staticTexts.add({staticLabel:"Clear Setting:"});
var myDateButtons = radiobuttonGroups.add();
with(myDateButtons){
radiobuttonControls.add({staticLabel:"English", checkedState:true});
radiobuttonControls.add({staticLabel:"Chinese"});
var myResult = myDialog.show();
if(myResult == true){
switch(mySearchButtons.selectedButton){
case 0:
BreakLinktoStyleDocument();
TurnOffHyphenationDocument();
myObject = app.documents.item(0);
break;
case 1:
BreakLinktoStyleSelection();
TurnOffHyphenationSelection();
myObject = app.selection[0];
myCheckSelection = true;
break;
switch(myDateButtons.selectedButton){
case 0:
myFindChangeByList1(myObject, myCheckSelection);
break;
case 1:
myFindChangeByList2(myObject, myCheckSelection);
break;
myDialog.destroy();
//myFindChangeByList1(myObject);
else{
myDialog.destroy();
function TurnOffHyphenationDocument() {
app.activeDocument.stories.everyItem().texts.everyItem().hyphenation=false;
myTables = app.activeDocument.stories.everyItem().tables.everyItem();
myTables.cells.everyItem().paragraphs.everyItem().hyphenation=false;
function TurnOffHyphenationSelection() {
app.selection[0].texts[0].hyphenation=false;
app.selection[0].cells.everyItem().texts[0].hyphenation=false;
function BreakLinktoStyleDocument() {
app.activeDocument.stories.everyItem().texts.everyItem().applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.activeDocument.stories.everyItem().texts.everyItem().applyCharacterStyle(app.activeDocument.characterStyles.item(0), false);
myTables.cells.everyItem().paragraphs.everyItem().applyParagraphStyle( app.activeDocument.paragraphStyles.item(0), false);
myTables.cells.everyItem().paragraphs.everyItem().applyCharacterStyle( app.activeDocument.characterStyles.item(0), false);
function BreakLinktoStyleSelection() {
app.selection[0].applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.selection[0].applyCharacterStyle(app.activeDocument.characterStyles.item(0), false);
app.selection[0].cells.everyItem().texts[0].applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.selection[0].cells.everyItem().texts[0].applyCharacterStyle(app.activeDocument.paragraphStyles.item(0), false);
function myFindChangeByList1(myObject, myCheckSelection){
var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit;
var myStartCharacter, myEndCharacter;
var myFindChangeFile = myFindFile("/ScriptSupport/te.txt")
if(myFindChangeFile != null){
// Because the selection will change as we add/remove characters,
// we'll need to reset the selection after each pass if we are
// checking the selection. We'll get the index of the first character
// in the selection (relative to the start of its parent story) and
// the index of the last character in the selection (relative to the
// *end* of the story, and we'll use them later in the script to
// keep the ends of the selection in place.
if(myCheckSelection == true){
var myStart = myObject.characters.item(0).index;
var myEnd = myObject.characters.item(-1).index;
var myStory = myObject.parentStory;
var myStoryEnd = myStory.characters.item(-1).index;
myEnd = (myStoryEnd - myEnd)+1;
myFindChangeFile = File(myFindChangeFile);
var myResult = myFindChangeFile.open("r", undefined, undefined);
//Loop through the find/change operations.
do{
myLine = myFindChangeFile.readln();
//Ignore comment lines and blank lines.
if((myLine.substring(0,4)!="text")||(myLine.substring(0,4)!="grep")||(myLine.substring(0,5)!="glyph")){
myFindChangeArray = myLine.split("\t");
//The first field in the line is the findType string.
myFindType = myFindChangeArray[0];
//The second field in the line is the FindPreferences string.
myFindPreferences = myFindChangeArray[1];
//The second field in the line is the ChangePreferences string.
myChangePreferences = myFindChangeArray[2];
//The fourth field is the range--used only by text find/change.
myFindChangeOptions = myFindChangeArray[3];
switch(myFindType){
case "text":
myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
break;
case "grep":
myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
break;
case "glyph":
myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
break;
myStartCharacter = myStory.characters.item(myStart);
myEndCharacter = myStory.characters.item(-myEnd);
myObject = myStory.texts.itemByRange(myStartCharacter, myEndCharacter);
app.select (myObject);
} while(myFindChangeFile.eof == false);
myFindChangeFile.close();
alert("Done");
function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change preferences before each search.
app.changeTextPreferences = NothingEnum.nothing;
app.findTextPreferences = NothingEnum.nothing;
app.findChangeTextOptions = NothingEnum.nothing;
var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
app.doScript(myString, ScriptLanguage.javascript);
myFoundItems = myObject.changeText();
//Reset the find/change preferences after each search.
function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change grep preferences before each search.
app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences = NothingEnum.nothing;
app.findChangeGrepOptions = NothingEnum.nothing;
var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
var myFoundItems = myObject.changeGrep();
//Reset the find/change grep preferences after each search.
function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change glyph preferences before each search.
app.changeGlyphPreferences = NothingEnum.nothing;
app.findGlyphPreferences = NothingEnum.nothing;
app.findChangeGlyphOptions = NothingEnum.nothing;
var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
var myFoundItems = myObject.changeGlyph();
//Reset the find/change glyph preferences after each search.
function myFindFile(myFilePath){
var myScriptFile = myGetScriptPath();
var myScriptFile = File(myScriptFile);
var myScriptFolder = myScriptFile.path;
myFilePath = myScriptFolder + myFilePath;
if(File(myFilePath).exists == false){
//Display a dialog.
myFilePath = File.openDialog("Choose the file containing your find/change list");
return myFilePath;
function myGetScriptPath(){
try{
myFile = app.activeScript;
catch(myError){
myFile = myError.fileName;
return myFile;
and here is my text file (te.txt)
//001
grep {findWhat:"."} {appliedLanguage: app.languagesWithVendors.item("English: USA"), kerningMethod: "無"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//002
grep {findWhat:"."} {kinsokuSet: "繁體中文避頭尾(s)"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//003
grep {findWhat:"."} {mojikumi: "nothing"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//004
grep {findWhat:"."} {ligatures:false} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//005
grep {findWhat:"."} {gridAlignment: 1852796517} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//006
grep {findWhat:"."} {leadingModel: 1248619858} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//007
grep {findWhat:"."} {characterAlignment: 1247896172} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
@creativejoan0425 – maybe it's best, to switch over to the InDesign Scripting Forum to discuss on.
http://forums.adobe.com/community/indesign/indesign_scripting?view=discussions
And another thing:
to present your code, there is the "Use advanced editor" button at the top right, if you are writing a new answer.
To format lines of code, select your code, go to the >> icon, click and chose: Syntax Highlighting/Java.
That's for better readability of your code.
Uwe
I just found when i run the script, that will not change in empty cell, how can i fix it?
從三星手機發送
What script exactly?
If it's something around:
myTable.cells.everyItem().texts[0].hyphenation = false;
it should work.
At least it's working for me.
Btw. what exact version of InDesign on what OS platform are you using?
A Chinese version? Maybe this is the culprit?
(Some bugs that are not present in the other international versions.)
Uwe
It ok, thx juust wrong typing of my script
從三星手機發送
Hi I also want to do in a selection to clear all linked style (Cell and Table Style), but found some error, would u mind to help me to fix it?
Thx a lots
BreakLinkToTableStyleSelection();
BreakLinkToCellStyleSelection();
function BreakLinkToTableStyleSelection(){
var mySelection = app.selection[0];
myTables = myDoc.tables.everyItem().getElements();
for (var i=0; i<myTables.length; i++){
myTable = myTables;
myTable.appliedTableStyle = myDoc.tableStyles.item(0), false;
function BreakLinkToCellStyleSelection(){
myCells = myDoc.cells.everyItem().texts[0].getElements();
for (var i=0; i<myCells.length; i++){
myCell = myCells;
myCell.appliedCellStyle = myDoc.cellStyles.item(0), false;
Hi! I would like to reactivate this old thread.
Can anyone suggest a way how to modify the "TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx"
script by Uwe so that it modifys tables and footnotes only if they are present in a document?
Actually the script does only work with documents witch do contains footnotes and tables.
This would be very helpful, thanks a lot in advance!
