Possible solutions include a bunch that I can't try, such as issues with fonts or colour spaces, as it's a supplied pdf. Given the resolution of exported jpegs, exporting as such won't do. I suppose I could try converting to eps via Photoshop.
This is weird one:
>Solution 3: Change print options in the Print dialog box.
>Make the following change in the Print dialog box:
>If you print a section that contains only one odd page, deselect Even Pages Only.
If you print a section that contains only one even page, deselect Odd Pages Only.
Umm, if I was printing only an odd page, I wouldn't get very far printing even pages only, now would I?
If I ever get to work through the snow, I'm going to look at this one first:
>Solution 6: Remove OPI 2.0 comments from the PDF file.
>Remove OPI 2.0 comments from the PDF file, place the PDF file into InDesign, and then print the document.
>To remove OPI 2.0 comments, do one of the following tasks:
>In Adobe Acrobat, manually remove the OPI 2.0 comments and then re-create the PDF file.
It doesn't mean much to me, but it might be a plan. As I said, for this document it doesn't really matter, I can print from Acrobat, but if a placed pdf is only part of a document I could be in trouble.
It's weird, one problem, all kinds of possible causes. If I'm being a pest, someone please say, otherwise I'll report back on which solution/workaround succeeds.
