No Big Deal
Paper vs. White
Mar 4, 2008 11:16 AM
If I want to place an image into a box that has a White background, is there a difference between White vs Paper?
    Mar 4, 2008 11:35 AM   in reply to No Big Deal
    no
    Mar 4, 2008 11:54 AM   in reply to No Big Deal
    There's no such color as white. Use paper just to get yourself use to the concept that you want the paper to show through.
    Mar 4, 2008 12:06 PM   in reply to No Big Deal
    It is possible to define a spot White ink. Not very useful in offset printing, but widely used in silk screen and packaging design.
    Mar 4, 2008 12:13 PM   in reply to No Big Deal
    I usually use C, M or Y to designate white plate on a job. Not like you can see a white plate.
    Mar 4, 2008 12:14 PM   in reply to No Big Deal
    over the years I have used white ink in offset printing about 5 times. Always because I needed a white base and I was printing on colored paper.
    Mar 4, 2008 2:13 PM   in reply to No Big Deal
    Just bear in mind that "paper" actually can be any color you give it to simulate colored paper.
    Mar 4, 2008 2:31 PM   in reply to No Big Deal
    Also, a color named white could be globally manipulated at a later date. If you had many objects or text colored with "white" dropping out of a dark background, you could decide to globally change "white" to something like 10% yellow any timecan't do that with Paper.
    Mar 5, 2008 6:15 AM   in reply to No Big Deal
    OT: PMS uses 'white' as one of its base coulours
    Mar 5, 2008 8:43 AM   in reply to No Big Deal
    PMS white is actually tinting medium - ie a non pigmented varnish to 'thin' down the strength of a mixed ink.
    White ink is generally used in aluminium can printing and CD on body labels to give a base for the subsequent inks to sit on.
