how we can populate the form data from 2D barcode
Jul 15, 2008 3:17 AM
Hi All,
Can anyone tell me how we can populate the form data from 2D barcode, will this can be done through script(javascript)?.
Thanks & Regards,
Faisal Afzal
    Jul 15, 2008 4:59 AM   in reply to (Faisal_Afzal)
    Hi Faisal,
    This really depends on what products you have available to you. If you have Adobe LiveCycle Barcoded Forms ES then your process would look something like this:
    - Decode the PDF or TIF image to extract the data from the barcode
    - Convert the extracted data into XML so that it may be easily mapped to your form
    - Reformat the data into a format that can be used to pre-populate your form, or use the converted data as-is if the format is acceptable
    - Import the data into your form using the import data service
    Each of these steps is a single service in LC ES and are provided with the Barcoded Forms ES product.
    May 6, 2010 1:51 PM   in reply to (Lee_Sutton)
    I was hoping someone could put me in the right direction here. I am basically doing the same . I am decodeing the information stored in a 2D Bar code and sending this information to an XML file, then I am trying to combine that xml file with a blank PDF template but the process is failing beacuse there are some additional tag fields the XML data from the  Decode->Extract XML process.
    The XML file from the decode process gives the structure below..notice therer some extra tags (lines 2- 4)
    <?xml version="1.0" encoding="UTF-8"?>
    <xdp:xdp xmlns:xdp="http://ns.adobe.com/xdp/" xmlns:xfa="http://www.xfa.org/schema/xfa-data/1.0/">
    <xfa:datasets>
    <xfa:data>
    <form1>
    The XML structure that is expected by the PDF template is as follows
    <form1>
    So the xml output of the Decode barcode + Extract XML process has three extra lines of tag. Is there a way I could use a process within liveCycle to clean out those three lines in real-time before sending the xml to be recombined with the PDF template.
