Populate  Text Field Based On Drop-Down List Selection
Jun 12, 2006 11:23 AM
I'm trying to set up a form so that a text field will populate with default text (that could later be edited by the end user) based on a users previous drop-down selection.
For example:
The end user is putting together a proposal for a client and is able to choose the type of proposal or service from a drop-down list. Once the user makes a selection from the drop-down list a text field is populated with default text describing the service.
The only catch is that the end user would need to be able to edit the default text. An example would be if an individual purchased a car but all the specific features and/or accessories could be added into the default text as necessary based on the purchasers desired upgrades. The common or universal features of the car would, however, show up as the default text.
Would this scenario be possible through the use of XML? Any tips on how I can accomplish this would be much appreciated.
    Jun 20, 2006 4:39 AM   in reply to (Adam_Conner)
    I'm finding it a little difficult to grasp what you're trying to accomplish so here's what I think you're asking for: You have a form which has a drop down list and a text field. When the user selects an item in the drop down list, you would like the text field to be automatically populated with an initial (default) value describing the selected item which the user could then edit (in the text field) to suit their specific needs.
    If that's correct, then you would need just a little bit of script on the drop down list's Change event which would determine the item selected by the user and would set the text field's value to that which pertains to the new selection.
    Let's say the text field is named "TextField1" and that you've associated a value to each item in the drop down list so that the selection is easy to compare in order to determine which initial (default) value to set in the text field. In your drop down list's Change event, you could use the following script (in JavaScript):
    var sNewSel = this.boundItem(xfa.event.newText);
    switch (sNewSel)
      case "1": // car purchase
        TextField1.rawValue = "Basic features:\n- frame\n- wheels\n- glass";
        break;
      case "2": // other purchase
        TextField1.rawValue = "Basic features..."
        break;
      default: // unknown value -- do nothing
        break;
    Here we see the use of the xfa.event.newText property in order to retrieve the text associated to the item which was just selected in the drop down list. Then we use the boundItem method of the drop down list (this) in order to retrieve the value that we associated to that item. Finally, we check the value and assign multi-lined values (note the "\n" characters in the strings which represent new lines) to our multi-lined TextField1 field's value.
    To help illustrate this, I've create a small sample form which uses the code I described above with the added feature that the text field is disabled until the user makes a selection in the drop down list.
    Stefan
    Adobe Systems
    Jul 28, 2007 4:00 AM   in reply to (Adam_Conner)
    Using Adobe LifeCycle Designer for Adobe 8 I'm trying to populate a text field with multiple entries from a drop down list. I managed to be able to populate the text field for a single selection from the drop down list but am having trouble getting it to allow multiple selections from the drop down list to populate the text field keeping all of the selections within it. When I click another selection from the drop down list the first entry that populated the text field is replaced by the new entry, I need it to maintain all entries entered...please help.
    Jul 28, 2007 6:34 AM   in reply to (Adam_Conner)
    Your post is different form the Original Post and should be a separate post of it's own since it maybe lost and if the OP subscribes to this post by email, that person will be flooded with responses to your post.
    In Acrobat, the Drop Down Box/List field does not support multiple selections only Combo List field does when that option is set for that field. Looking at the Drop Down List, I did not see an option to enable multiple item selection. Also LC D does not support the Acrobat JS "currentValueIndices" field property that is used to recover the multiple item selection array nor does it support the "getItemAt" field property that is used to get a selected entry from the combo list. So it appears this might not be possible.
    For more information about Scripting in LC D see:
    Scripting languages and resources (LiveCycle Designer 8.x)
    http://www.adobe.com/cfusion/search/index.cfm?loc=en_us&term=livecycle +javascript
    Aug 1, 2007 9:49 PM   in reply to (Adam_Conner)
    I am new Adobe livecycle developer , my knowledge is Oracle and Sql , plSql . I want to design an adobe form, for which I have 2 drop down lists , one for all ministries , the other one is for all directorates which related to the selected ministry. The scenario is as follows:
    The user will pick a ministry from the 1st drop down list, then for the 2nd dropdown, the list of all directorates that are belongs to the selected ministry should appear in order he can select the specified directory from the dropdown list. (no need for buttons).
    I had tried the Stefan Camerons procedure in connecting a form to Db, and selecting specific record from a data base , the dropdown "Pick a Category" field is not working, also I had tried to copy his script into my form ,still is not working. Is there any method ? or maybe something I need to add to my script .
    I am using adobe live cycle designer 7.1
    Adobe reader is 7.0
    the file is saved as pdf
    data connection informations in the form are as follows :
    1-DataConnection1.
    Using OLEDB
    database name is : Financial_DB_Forms (on the server)
    OLEDB provider is :Microsoft OLEDB provider for SQL Server
    Server : MOFNEO
    Connecting string : Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=Financial_DB_Forms;Data Source=MOFNEO;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID=CPU-0900;Use Encryption for Data=False;Tag with column collation when possible=False
    Table1 : Financial_Form_Ministry ( contains all ministries numbers and description)
    2-DataConnection2. (same info. As above )
    Table2 : Financial_Form_Directorate ( contains of all directorates for all ministries and description) .
    Also can you please send me a telephone number and e-mail of any adobe developer that I can call him if I need any assistance .
    Your help will be much appreciated,
    Mariam Kadhimi
    Tel : +973-39597575 (mobile)
    Tel : +973-17575560 (Office)
    Kingdom of Bahrain
    Sep 4, 2007 11:00 AM   in reply to (Adam_Conner)
    Stefan -
    I had itially looked for a way to simply wrap text in a drop down list as I thought that would be the simplest way to do what the client requested (have a list of standard options to choose from but still enable custom entries).
    Since I couldn't find a way to wrap my dropdown text, I tried to modify your sample from but I can't get it to work for me, and I'm not sure if it's the best option for what the client needs.
    In addition to not being able to make the drop down affect the text box, how would I get the drop down to hide after exit? I will want to have this pairing repeat (for a total of 6 or 8 text boxes) and want to only print/see the text boxes, and not the drop downs after the text is entered.
    My test doc is at www.scottsdaleaz.gov/Assets/documents/airport/TESTING-StipDropDownSel ection.pdf
    ' Here's how I modified what you gave:
    var bEnableTextField = true;
    switch (sNewSel)
    case "1": // Changes Require Approval Prior to Development Review
    Stipulation1.rawValue = "Changes to the development plans anytime after airport staff has signed this
    form requires additional airport approval of the change prior to development review
    board hearing.";
    break;
    case "2": // FAA form 7460-1
    Stipulation1.rawValue = "Developer must demonstrate that an FAA form 7460-1 was completed unless
    exemptions apply."
    break;
    case "3": // Noise Disclosure
    Stipulation1.rawValue = "Applicant must demonstrate aircraft noise and overflight activity disclosure to
    proposed occupants."
    break;
    case "4": // Fuel Dispensing and Storage
    Stipulation1.rawValue = "Fuel dispensing and storage proposed for development projects must have
    specific documented airport review and approval. Storage and dispensing of fuel
    must be in accordance with Airpark Rules and Regulations."
    break;
    case "5": // Significant Changes Required Additional Review
    Stipulation1.rawValue = "Significant changes to this project require additional project review by airport
    staff."
    break;
    case "6": // Approval Valid for 1 Year
    Stipulation1.rawValue = "This approval is valid for up to one year from the date it was signed. Further
    review is not required prior to final plans approval unless substantial revisions are
    made to the development plans anytime after the date this form was approved."
    break;
    bEnableTextField = false;
    break;
    Thanks - This is the first time I've had to use LiveCycle instead of the basic forms tools.
    Beckye Frey
    Customer Relations Specialist
    480-312-2743
    bfrey@scottsdaleaz.gov
    City of Scottsdale
    Planning & Development Services Department
    7447 E Indian School Road, Ste 105
    Scottsdale, AZ 85251
    Oct 12, 2007 5:04 PM   in reply to (Adam_Conner)
    Is there any way that someone could explain it to a beginner?
    Dropdown list > address info is based on list selection (address info is multiple lines "address, city, st, zip, phone"
    So user is filling out a form, selects recipient, and the address info + phone populates on it's on (into a text box) based on the item selected in the drop down.
    Oct 17, 2007 1:42 PM   in reply to (Adam_Conner)
    Help.
    Could you look at the following and see what I am missing? I have copied Stefan's example. I have modified it within the sample pdf that he posted and it works great. I have now tried to move it to my development form and I cannot get the textfield to populate with the drop down selection. I think it may be in naming convention, but not sure where or how to track down my problem. I have put them on the same subform, but that did not work.
    Stan
    ----- form1.form2.BIP_Subform.EquipList::change: - (JavaScript
    switch (sNewSel)
    case "1": // AN
    TextField10.rawValue = "Face Shield\nGoggles\nChemical Gloves\nAir Supplied Respirator\nChemical Green Suit\nChemical Boots";
    break;
    case "2": // BUO
    break;
    //I have 32 cases, but left them out here)
    break;
    if (bEnableTextField)
    TextField10.access = "open"; // enable field
    TextField10.caption.font.fill.color.value = "0,0,0"; // set caption to black
    My textfield info is:
    ----- form1.form2.BIP_Subform.TextField10::change: - (JavaScript, client) --------------------------
    Aug 25, 2008 8:35 AM   in reply to (Adam_Conner)
    great stuff here.
    Can this be applied to work on a second DROP DOWN LIST instead of a text field.
    Simply put, I would like to populate a second drop down list based on chosen selections from a first drop down list.
    thanks
    Aug 28, 2008 12:16 PM   in reply to (Adam_Conner)
    Hi Stefan,
    I'm using you code that you posted first. How do I amend it so that the second text box is actually another drop down list?
    Thanks, Justin
    Aug 28, 2008 12:25 PM   in reply to (Adam_Conner)
    Hi Redcoat,
    Were you able to figure out how to make the second list a drop down menu?
    Thanks, Justin
    Aug 30, 2008 9:21 AM   in reply to (Adam_Conner)
    Dear Stefan
    Ref. you post above, I am trying to do a similar thing but no vain. Would you please help me?
    I have a form where I have drop down list menu named as "Country" it shows names of many countries then I have another drop down list box with the name "cities" which has name of many cities....
    In both of the above fields I have manually entered the names of the countries and cities respectively in the designer.
    what I want is that when i select the specific country then all cities related to the country only show up in the "cities" drop down list box?
    Is this possible in forms? I am using Life Cylce ES 8.2
    please advise
    Asim
    Sep 4, 2008 1:17 PM   in reply to (Adam_Conner)
    I'm using Stefan's original example which is exactly what I am looking for but I'm having trouble moving the text field to a different page than the drop down. I want the user to select from the dropdown on page 1 and have that populate text fields on other pages. Is there additional script involved?
    Sep 5, 2008 7:28 AM   in reply to (Adam_Conner)
    I'm also trying to have it populate multiple text fields across multiple pages.
    Sep 16, 2008 4:12 PM   in reply to (Adam_Conner)
    Greetings,
    I've figured out how to string together different text and numeric fields into a single text field. My question is - is there any way i can have the results sent as a text message to a mobile phone? I simply want to send simple text to a mobile phone number.
    Any ideas?
    Sep 18, 2008 8:03 AM   in reply to (Adam_Conner)
    Sep 18, 2008 8:11 AM   in reply to (Adam_Conner)
    I am not sure this is what you are looking for but this is the script behind the drop down on change event and InsertNote1 is the text field being populated. The text field is also set to Calculated - Allow User Override.
    switch (sNewSel)
    case "1": // Option 1
    InsertNote1.rawValue = "Text if option 1 is selected.";
    break;
    case "2": // Option 2
    InsertNote1.rawValue = "Text if option 2 is selected."
    break;
    case "3": // Option 3
    InsertNote1.rawValue = "Text if option 3 is selected."
    break;
    case "4": // Option 4
    InsertNote1.rawValue = "Text if option 4 is selected."
    break;
    case "5": // Option 5
    InsertNote1.rawValue = "Text if option 5 is selected."
    break;
    case "6": // Option 6
    InsertNote1.rawValue = "Text if option 6 is selected."
    break;
    case "7": // Option 7
    InsertNote1.rawValue = "Text if option 7 is selected."
    break;
    case "8": // Option 8
    InsertNote1.rawValue = "Text if option 8 is selected."
    break;
    break;
    InsertNote1.access = "open"; // enable field
    InsertNote1.caption.font.fill.color.value = "0,0,0"; // set caption to black
    Nov 3, 2008 9:16 AM   in reply to (Adam_Conner)
    I am trying to populate text fields with the same information, such as the name, address, and phone number. I want to know if there is way that I can do so, without having to use any outside coding. I don't need to populate complex information, just the basic. I guess my main purpose is to have that simple information populate throughout a form without having re-type such information throughout my 4-6page forms. Leaving me with less room for error.
    Nov 3, 2008 9:21 AM   in reply to (Adam_Conner)
    If you are going to set another field's value from a combo box or list you need to use some form a scripting.
    Feb 5, 2009 11:08 PM   in reply to (Adam_Conner)
    Hi how to generate the text field with the selection of an item in the combo box please help me if any one knows
    Feb 13, 2009 3:23 PM   in reply to (Adam_Conner)
    Stefan,
    I used your example in my table, which worked for the first row. However, I have a repeatable table with add and delete row buttons and the drop down only populates the first row.
    So, if I use the first drop down on the first row, it populates the first text field in the first row just fine. However, when I use the drop down on the next row, the first row gets updated instead of the second row text field. How do I tweak the nomenclature so that it knows to correspond to the same row?
    Dave
    Jun 1, 2010 7:23 AM   in reply to (FormBuilder)
    Hello Stefan,
    I'm interested in the sample file you've created. Could you post it again?   I am also trying to populate textfields which are on different pages than the drop down lists, and have not succeeded. Can you help? Thanks.
    thanks.
    Nellie
    Nov 2, 2010 7:11 PM   in reply to (FormBuilder)
    Stefan
    How do I get the PDF you devloped?
    I need to see details of populating dropdown.
    Can you also "extend" the dropdown to other dependant dropdowns?
    --one DD detrmining another DD, which then fills a text field(s)..
    -Allan
    Oct 31, 2011 10:57 AM   in reply to (Adam_Conner)
    I am Working on a text field to, creating the form is no problem with a little Script.Right now Im just using an easy Drop Down Menu Generator.
    http://www.javascriptsandmore.com/drop-down-menu-generator-software.ht ml
    Jan 24, 2012 9:35 AM   in reply to (FormBuilder)
    Stefan,
    I am not very literate in scripting, but am learning as I go, so hopefully this will make sense. I am trying to get the drop down to generate a message in a text field, and if drop down is left blank, no message is shown. I used your example above to get my drop down to generate a text field, but it is not working. My drop down list is named "Security Deposit" and the text field is "Security". Here is what I entered in the script editor using Javascript and Change:
    var  (sNewSel=this.boundItem(xfa.event.newText);
    switch  (sNewSel)
    Security.rawValue
    = " A security deposit has been paid to the Community. The deposit shall be applied to any damages done to Clubhouse or Community. If there are no damages, the payment will be returned to the Resident following inspection.";
    break;
    default://unknown value--do nothing
    If you could please assist with this, I would really appreciate it!!
    Thank you so much!
