Accessible PDF Form
Feb 1, 2005 7:41 AM
I trying to create an Accessible form using Adobe 7
Everything looks fine except it always gives me an arror about Languange and Tab Order.
any ideas?
    Feb 1, 2005 5:59 PM   in reply to (Mahesh_Agrawal)
    IS this Acrobat Professional 7.0, right? Where are the errors coming from?
    You should use the features found in Advanced > Accessibility menu:
    Quick Check
    Full Check
    Add Tags
    Touchup
    They will help create tags, tab order and generate accessibility report to help analyze/fix problems. The Acrobat Help guide also has more information on these tools.
    Feb 14, 2005 5:09 PM   in reply to (Mahesh_Agrawal)
    Can you post the accessibility error(s) you are receiving in Designer 7.0?
    RE: Language, do you have "Default locale" set for Form Properties (Defaults), or are setting Locale for each field object?
    RE: Tab Order, accessible forms require a tabbing order. One of the final tasks you should do when creating a form is set the tabbing order (see "Setting the tabbing order" topic in Designer help).
