Image field issues in Adobe LiveCycle Designer
Feb 17, 2006 1:53 PM
Hello All,
When I create an image field in Adobe Designer (I'm creating some interactive forms), the field does not end up being the exact size I specify. It is very important to me that the end size be precise, but Designer seems to allow some border instead of filling the extents I have specified. In other words, the image someone inserts into the image field ends up being a little smaller than it should be. This is very frustrating, and I have to try to compensate for this glitch by specifying image field dimensions that are larger than what I want. (This is not a problem of my not specifying scale to fit, or stretch to fit; when I do this, the image is still too small.)
Another question I have is this: Why doesn't Adobe allow vector graphics to be imported into Designer? I am forced to convert my vector graphics to raster images to bring them into Adobe Designer. Designer doesn't even accept a PDF image, which I find ironic.
This is a super super urgent project work I am doing..
Please help..
Dimitri
    Jul 10, 2007 5:41 AM   in reply to (MenonRamesh)
    I'm having the same problem. What's the trick?
    Thanks.
    Jul 13, 2007 1:33 AM   in reply to (MenonRamesh)
    Please help.
    Once again:
    When I create an image field in Adobe Designer 7, the field does not end up being the exact size specified. I'm sure there must be a hint.
    Thank you!
    Feb 2, 2008 11:16 AM   in reply to (MenonRamesh)
    I'm having the same image proportion problem. Regardless of the setting I apply to the image field object and the size of the field, the form always skews the image to fit the dimension of the field. Any help is appreciated.
    Feb 6, 2008 9:35 AM   in reply to (MenonRamesh)
    Skip
    I'm having the same problem as well. I think it might be part of importing a PDF as background artwork.
    When I use a template the image field works perfectly. But when I try to set an image field on my document, it skews. There must be a step I am missing but I don't know what it is.
    Sarah
    Nov 7, 2008 9:07 AM   in reply to (MenonRamesh)
    Has anyone found a solution to the image proportion problem? Is this user-error or a bug? If it's error, then I'm doing the same thing wrong that some of you have. :)
    Nov 7, 2008 9:42 AM   in reply to (MenonRamesh)
    I never found a solution and eventually gave up in frustration. Sorry ...
    7. ,
    Nov 17, 2008 9:17 PM   in reply to (MenonRamesh)
    Hi all,
    I guess this problem was a bug which was resolved in Reader 9 so if you Scal;; Image Proportionately it should not skew anymore.
    Regards
    Norbert
    Jun 2, 2009 12:27 PM   in reply to Guest
    Nope, nothing got fixed.  Similar issues here with Adobe Pro 8.0 and 9.0, image fields just don't work properly.  Either the aspect ratio is screwed up, or the anchor position is being ignored.
    Haven't seen a fix yet.
    Markus
    Aug 24, 2009 12:30 PM   in reply to Markus Heller
    Better too late than never!
    Here's an answer that I got today about this "bug":
    "It seesm to be related to the setting "Use Original Size". If it is initially set at that setting the picture gets messed up and cannot recover. If I use Fit to Rectangle it seems OK ...then I can change it at will."
    Weird.
    Nov 11, 2009 12:51 AM   in reply to mprovencal
    The "Fit To Rectangle" hint doesn't work on my form. Did anybody find a solution for this rather annoying problem?
    Nov 20, 2009 1:51 PM   in reply to (MenonRamesh)
    I'm also having this issue, except the image field is working in Reader 9.  The image still skews in Reader 8 though, even if I select 'Scale Proportionally'.  Any ideas?  Kind of annoying if the solution is to make your users upgrade to Reader 9.
    Dec 17, 2012 10:13 AM   in reply to kcmoffat
    I'm a little late to this party - but when you bring your document in you can't bring it in as a "fixed" document - it has to be flowable (you may lose your artwork) but you can add it again in livecyle.
