Convert Dynamic XDP to PDF
May 7, 2007 1:40 PM
Can PDF Generator programatically (Java) convert a dynamic XDP form that has been filled out by a user into a static PDF?
Bob
    Jul 2, 2008 3:54 AM   in reply to (Bob_Haxel)
    Hi Bob,
    Did you find a solution for your problem?
    Can anybody know any solution to convert dynamic form to static?
    Thank you.
    asiye.aydin@gmail.com
    Aug 13, 2008 10:15 PM   in reply to (Bob_Haxel)
    Is it possible to access interactive PDF through windows logon( windows may have multiple user accounts). On one particular account , if the user enter login credentials--(if valid)--then he should access the paricular pdf( fill & submit vice versa.).
    Any useful information would be appriciated.
    Ramesh
    Dec 13, 2010 11:35 AM   in reply to (Bob_Haxel)
    You can try extrating the xml data from the XDP form and re-render the XDP form with the extracted xml data plus a static PDFFormRenderSpec. Make sure the PDFFormRenderSpec is set to RenderAtClient as false.
