Problem deploying ARES LiveCycle ears on WebLogic Server 8.1_5
May 24, 2007 1:44 PM
Hello,<br /><br />I'm trying to deploy ARES LiveCycle on WL Server 8.1 SP5 (running on WinXP Pro), and am running into errors when I get to the part of the Configuration Manager installer that tries to deploy LiveCycle.ear, adobe-FontManager.ear, and LiveCycle-security.ear.<br /><br />Each time I try to deploy, the installer will think for a minute, then I'll see an ugly stack trace in the WebLogic server and the installer will tell me that deployment failed.<br /><br />I used all of the ARES defaults where I could in the installer. The only thing I changed was the WebLogic port.<br /><br />Has anyone else run into issues with ARES on WebLogic? Any ideas?<br /><br />Here is my ugly stack trace - very long. Thanks for any insight.<br /><br />May 24, 2007 5:23:27 PM com.adobe.logging.AdobeLoggerImpl <clinit><br />INFO: Logging level null<br />May 24, 2007 5:23:27 PM com.adobe.logging.AdobeLoggerImpl <clinit><br />INFO: Logging level null<br /><May 24, 2007 5:23:27 PM EDT> <Error> <com.adobe.service.ServerLifeCycleListener<br />> <000000> <BMC001: Unexpected exception while starting an Adobe Service<br />java.lang.ExceptionInInitializerError<br />        at com.adobe.service.ServiceAPI.<init>(ServiceAPI.java:75)<br />        at com.adobe.service.Service.<init>(Service.java:69)<br />        at com.adobe.service.DataManagerService.<init>(DataManagerService.java:2 <br />6)<br />        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)<br /><br />        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct <br />orAccessorImpl.java:39)<br />        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC <br />onstructorAccessorImpl.java:27)<br />        at java.lang.reflect.Constructor.newInstance(Constructor.java:274)<br />        at java.lang.Class.newInstance0(Class.java:308)<br />        at java.lang.Class.newInstance(Class.java:261)<br />        at com.adobe.service.ServerLifeCycleListener.contextInitialized(ServerLi <br />feCycleListener.java:29)<br />        at weblogic.servlet.internal.WebAppServletContext$FireContextListenerAct <br />ion.run(WebAppServletContext.java:7044)<br />        at weblogic.security.acl.internal.AuthenticatedSubject.doAs(Authenticate <br />dSubject.java:321)<br />        at weblogic.security.service.SecurityManager.runAs(SecurityManager.java: <br />121)<br />        at weblogic.servlet.internal.WebAppServletContext.notifyCreated(WebAppSe <br />rvletContext.java:1753)<br />        at weblogic.servlet.internal.WebAppServletContext.preloadResources(WebAp <br />pServletContext.java:3352)<br />        at weblogic.servlet.internal.WebAppServletContext.setStarted(WebAppServl <br />etContext.java:6208)<br />        at weblogic.servlet.internal.WebAppModule.start(WebAppModule.java:864)<b r />        at weblogic.j2ee.J2EEApplicationContainer.start(J2EEApplicationContainer <br />.java:2134)<br />        at weblogic.j2ee.J2EEApplicationContainer.activate(J2EEApplicationContai <br />ner.java:2175)<br />        at weblogic.management.deploy.slave.SlaveDeployer$ComponentActivateTask. <br />activateContainer(SlaveDeployer.java:2520)<br />        at weblogic.management.deploy.slave.SlaveDeployer$ActivateTask.doCommit( <br />SlaveDeployer.java:2438)<br />        at weblogic.management.deploy.slave.SlaveDeployer$Task.commit(SlaveDeplo <br />yer.java:2155)<br />        at weblogic.management.deploy.slave.SlaveDeployer$Task.checkAutoCommit(S <br />laveDeployer.java:2254)<br />        at weblogic.management.deploy.slave.SlaveDeployer$Task.prepare(SlaveDepl <br />oyer.java:2149)<br />        at weblogic.management.deploy.slave.SlaveDeployer$ActivateTask.prepare(S <br />laveDeployer.java:2401)<br />        at weblogic.management.deploy.slave.SlaveDeployer.processPrepareTask(Sla <br />veDeployer.java:883)<br />        at weblogic.management.deploy.slave.SlaveDeployer.prepareDelta(SlaveDepl <br />oyer.java:591)<br />        at weblogic.management.deploy.slave.SlaveDeployer.prepareUpdate(SlaveDep <br />loyer.java:500)<br />        at weblogic.drs.internal.SlaveCallbackHandler$1.execute(SlaveCallbackHan <br />dler.java:25)<br />        at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:224)<br />        at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:183)<br />C
    Jul 18, 2007 7:58 PM   in reply to (josh_rosenthal)
    i am  facing this issue while deploying a connectionfactory in weblogic9 mp1 on ibm aix machine .we specified the flow control parameters as following
         11
         600
    3]An attempt to initialize property FlowMinimum failed because of java.lang.IllegalArgumentException: FlowMinimum has to be less than FlowMaximum.
    weblogic.application.ModuleException: [Management:141213]An attempt to initialize property FlowMinimum failed because of java.lang.IllegalArgumentException: FlowMinimum has to be less than FlowMaximum
            at weblogic.jms.frontend.FEConnectionFactory.initialize(FEConnectionFact ory.java:329)
            at weblogic.jms.frontend.FEConnectionFactory.prepare(FEConnectionFactory .java:1587)
            at weblogic.jms.module.JMSModule$EntityState.setState(JMSModule.java:170 4)
            at weblogic.jms.module.JMSModule$EntityState.setState(JMSModule.java:166 7)
            at weblogic.jms.module.JMSModule$EntityState.access$100(JMSModule.java:1 608)
            at weblogic.jms.module.JMSModule.prepare(JMSModule.java:277)
            at weblogic.jms.module.ModuleCoordinator.prepare(ModuleCoordinator.java: 170)
            at weblogic.application.internal.flow.ModuleListenerInvoker.prepare(Modu leListenerInvoker.java:93)
            at weblogic.application.internal.flow.DeploymentCallbackFlow$1.next(Depl oymentCallbackFlow.java:360)
            at weblogic.application.utils.StateMachineDriver.nextState(StateMachineD river.java:26)
            at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(Dep loymentCallbackFlow.java:56)
            at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(Dep loymentCallbackFlow.java:46)
            at weblogic.application.internal.BaseDeployment$1.next(BaseDeployment.ja va:615)
            at weblogic.application.internal.BaseDeployment.prepare(BaseDeployment.j ava:191)
            at weblogic.application.internal.DeploymentStateChecker.prepare(Deployme ntStateChecker.java:147)
            at weblogic.deploy.internal.targetserver.AppContainerInvoker.prepare(App ContainerInvoker.java:61)
            at weblogic.deploy.internal.targetserver.SystemResourceDeployment.prepar e(SystemResourceDeployment.java:65)
            at weblogic.management.deploy.internal.DeploymentAdapter$1.doPrepare(Dep loymentAdapter.java:38)
            at weblogic.management.deploy.internal.DeploymentAdapter.prepare(Deploym entAdapter.java:177)
            at weblogic.management.deploy.internal.AppTransition$1.transitionApp(App Transition.java:21)
            at weblogic.management.deploy.internal.ConfiguredDeployments.transitionA pps(ConfiguredDeployments.java:233)
            at weblogic.management.deploy.internal.ConfiguredDeployments.prepare(Con figuredDeployments.java:165)
            at weblogic.management.deploy.internal.ConfiguredDeployments.deploy(Conf iguredDeployments.java:122)
            at weblogic.management.deploy.internal.DeploymentServerService.resume(De ploymentServerService.java:173)
            at weblogic.management.deploy.internal.DeploymentServerService.start(Dep loymentServerService.java:89)
            at weblogic.t3.srvr.SubsystemRequest.run(SubsystemRequest.java:64)
            at weblogic.work.ExecuteThread.execute(ExecuteThread.java:209)
            at weblogic.work.ExecuteThread.run(ExecuteThread.java:181)
    Sep 12, 2008 11:48 AM   in reply to (josh_rosenthal)
    Did either of you ever find a solution to this problem??
