Livecycle 8.0 multiple signatures problems
Jan 10, 2008 1:14 AM
When I add 2 digital signatures to same pdf document and sign them, the first signature reports
"The revision of the document that was covered by this signature has not been altered; however there have been subsequent changes to the document".
The signature changes from green "check" mark to green "check" mark and a yellow warning marker.
I understand that the document has been changed when adding another signature, but how do I set the preference to allow 2 digital signatures without the warnings at the first signature!?
    Jan 10, 2008 10:37 AM   in reply to (iswen)
    You are right. The addition of a second signature does change the document since it was first signed, resulting in the Yellow Triangle shown in the appearance of the first signature.
    If you Certify the document before any signatures are added then you can have consecutive signatures in that document that retain their valid "green check mark" state.
