using the API SDK to load XML into a DOM (Custom QPAC)
Jun 30, 2006 4:11 AM
Hia,
I just writing a Custom QPAC that will take a serialized stream of XML as an input field. What I then want to do in a Custom QPAC is load this data into a DOM. Can someone point me at the correct API calls I need to do this.
So the input value would be serialize(/process_data/formdata/form-data/data/xdp/datasets/data/*, false)
I read the from the QPAC panel by doing the standard call
String _xmlsource = (TextUtil.isEmpty(DOMUtil.getTextForChild(_rootInput, "xmlsource")))?"":DOMUtil.getTextForChild(_rootInput, "xmlsource");
What I then tried doing is calling
Node n = (Node) aExecCtx.getProcessDataValue(_xmlsource);
This fails as it returns a String of serialize(/process_data/formdata/form-data/data/xdp/datasets/data/*, false) and not the expected result of this command.
If I add a SetValue QPAC before and set a process variable for example mystring and set this to the serialize. And set my QPAC to look at that it seems to work, what I want to do is remove the need for the SetValue QPAC.
Any Help on this would be really appreciated.
