How to use "Form Server Render Form" QPAC
Nov 16, 2005 9:54 PM
Can any one suggest us how to use "Form Server Render Form" Qpac to render a form as PDF we are trying to give content root url as "\Form" and we tried some more option also but it is always giving file not find error.
What will be the value we have to fill under "output" tab?
Is all the variable should be Process Variable ?
    Nov 17, 2005 4:06 AM   in reply to (abhishek_upadhyay)
    Hi
    For the root url, you need to specify the url of an existing form. The easiest way to do this is to copy and paste the url from a Form Variable Definition.
    The only output variable you need (despite the *'s) is the output document, which should be a document variable.
    The documentation is quite accurate and helpful - but you need to read it carefully.
    Howard
    Howard Treisman
    Avoka Technologies
    Specializing in Custom QPAC development and LiveCycle Solutions
    http://www.avoka.com/avoka/qpac_library.shtml
    Dec 7, 2005 5:17 AM   in reply to (abhishek_upadhyay)
    I'm having a little problem with this QPac also. I keep getting a null pointer exception in my stalled error page. Do I have to set all deployment settings for the QPac(JNDI_ProviderURL, JNDI_FACTORY_INITIAL...)?
    Dec 7, 2005 12:43 PM   in reply to (abhishek_upadhyay)
    Matt,
    I set the JNDI_ProviderURL setting to "localhost:1099" and that solved it for me.
    Peter L
    Jan 19, 2007 1:04 PM   in reply to (abhishek_upadhyay)
    Hi Folks,
    I am also trying to use this qpaq with the setValue qpaq in order to create a pdf from xdp and fill a couple form fields with the setValue part..
    Im lost at this point and would love a simple example - can someone set me straight here ?
    Thanks !
    Jan 29, 2007 4:06 AM   in reply to (abhishek_upadhyay)
    Hi Aaron
    You could try using our RenderPlus QPAC, which is easier to configure than the regular Render QPAC.
    You can download a copy from:
    If you need more help, send an email to info@avoka.com.
    Howard
