External Directory
Oct 7, 2004 5:51 AM
I noticed in the role designed documentation A_ExtDisplayName as a parameter for Directory.findFirstUser. Has anyone used an external directory? How do you set this up? What's the utility of this?
    Oct 10, 2004 4:05 PM   in reply to (bill_rowe)
    Bill,
    There is actually very little you need to do if you are using ActiveDirectory and the installation recognises the directory at install time.
    If you use LDAP, such as Novell, you may have to manipulate the XML configuration files to introduce the connection. Some of this is documented with the product.
    Sanna
    Oct 11, 2004 3:24 PM   in reply to (bill_rowe)
    I am interested in more details about interfacing to Novell e-directory.
    We do not have MS Active Directory - and are trying to work out the best way to link Adobe into Novell.
    Dalwyn
    Oct 26, 2004 4:58 AM   in reply to (bill_rowe)
    Currently Adobe AWS only supports a single directory services db - MS ActiveDirectory. The schemea files have been constructed in such away to only read from that single source.
    If you require connectivity to another DS db then the ad-users.xml schema ( amoungst others ) will have to be rewritten for NDS.
    Feb 11, 2009 12:34 AM   in reply to (bill_rowe)
    Is the syntax of these *.xml files documented anywhere? I'm trying to move from one LDAP server to another (with a different structure), and experience major difficulties with it.
    Thx
    CU Dmitri
