Error while firing WatchedFolder trigger
Mar 11, 2008 11:34 PM
Hi all,
Once every day the server reports the following error and cannot recover (needs restart):
2008-03-10 22:36:50,855 ERROR [org.quartz.core.ErrorLogger] An error occured while firing trigger 'WatchedFolder.WatchedFolder:605'
org.quartz.JobPersistenceException: Couldn't select trigger state: Communications link failure due to underlying exception:
** BEGIN NESTED EXCEPTION **
java.net.SocketException
MESSAGE: Connection reset by peer: socket write error
STACKTRACE:
java.net.SocketException: Connection reset by peer: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
at java.net.SocketOutputStream.write(SocketOutputStream.java:136)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65 )
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2692)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2621)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1552)
at com.mysql.jdbc.ServerPreparedStatement.serverExecute(ServerPreparedSt atement.java:1124)
at com.mysql.jdbc.ServerPreparedStatement.executeInternal(ServerPrepared Statement.java:676)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java: 1030)
at org.jboss.resource.adapter.jdbc.CachedPreparedStatement.executeQuery( CachedPreparedStatement.java:76)
at org.jboss.resource.adapter.jdbc.WrappedPreparedStatement.executeQuery (WrappedPreparedStatement.java:211)
at org.quartz.impl.jdbcjobstore.StdJDBCDelegate.selectTriggerState(StdJD BCDelegate.java:2317)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.triggerFired(JobStoreSup port.java:2778)
at org.quartz.impl.jdbcjobstore.JobStoreSupport$37.execute(JobStoreSuppo rt.java:2757)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.executeInNonManagedTXLoc k(JobStoreSupport.java:3662)
at org.quartz.impl.jdbcjobstore.JobStoreSupport.triggerFired(JobStoreSup port.java:2751)
at org.quartz.core.QuartzSchedulerThread.run(QuartzSchedulerThread.java: 313)
I have just reinstalled the server and imported the processes I had created earlier, but no custom setup within the "stomach of JBoss/LiveCycle".
Does anybody knwo what I can do to rectify/localise this error?
Sincerely
Kim
    Jun 11, 2008 9:57 AM   in reply to kc@dafolo.dk
    From the LiveCycle ES Error Code Reference
    Extended periods of server inactivity when using JBoss
    Application Server configured with MySQL (the JBoss
    turnkey). The exception is raised by background
    processing during internal database management. Its
    presence is expected: Idle connection with the
    database times out and causes the TCP/IP connection
    to close. Exceptions typically occur after 8 hours or
    more of inactivity in LiveCycle ES.
    [Exceptions seen on JBoss/MySQL and start with:
    java.sql.SQLException: No operations allowed after
    connection closed. Connection was implicitly closed
    due to underlying exception/error: ** BEGIN NESTED
    EXCEPTION
    **com.mysql.jdbc.CommunicationsException
    MESSAGE: Communications link failure due to
    underlying exception: **java.net.SocketException
    MESSAGE: Software]
    The document also says
    This exception does not
    impact the LiveCycle ES
    server processing and
    can be ignored.
    However, I also need to restart the server to get it working again.
    Sincerely,
    Nick
    Jun 11, 2008 10:45 PM   in reply to kc@dafolo.dk
    We had a problem with LC ES on jboss with MySQL. I believe the problem was that after the server being idle for a while, the connection to MySQL could not be restored untill the server was restarted. This was reported to Adobe, and a patch was made. Try contacting Adobe support and ask for the patch. It may help you.
