Error in invocating the service
Jul 3, 2007 12:07 PM
I have a problem in writing a Java program and calling the service using invocation API. The service is a very simple one, which has one input parameter (String) and one output parameter (XML). When I ran the Java program, I got the following error:
ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSe nd(SoapAxisDispatcher.java:102)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(A bstractMessageDispatcher.java:57)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:2 08)
at adobe.lc.sdk.UploadForm.invokeMyService(UploadForm.java:75)
at adobe.lc.sdk.UploadForm.main(UploadForm.java:55)
Caused by: rO0ABXNyAB1vcmcuYXBhY2hlLnNvYXAuU09BUEV4Y2VwdGlvbh5POjjsHQpiAgACTAAJZ mF1bHRDb2RldAASTGphdmEvbGFuZy9TdHJpbmc7TAAPdGFyZ2V0RXhjZXB0aW9udAAVTGp hdmEvbGFuZy9UaHJvd2FibGU7eHIAE2phdmEubGFuZy5FeGNlcHRpb27Q/R8+GjscxAIAA HhyABNqYXZhLmxhbmcuVGhyb3dhYmxl1cY1Jzl3uMsDAANMAAVjYXVzZXEAfgACTAANZGV 0YWlsTWVzc2FnZXEAfgABWwAKc3RhY2tUcmFjZXQAHltMamF2YS9sYW5nL1N0YWNrVHJhY 2VFbGVtZW50O3hwcQB+AAZ0AEdBRE1DMDAxMUU6IFRoZSBTT0FQIHJlbW90ZSBwcm9jZWR 1cmUgY2FsbCAoUlBDKSBjYW5ub3QgYmUgdW5tYXJzaGFsbGVkLnVyAB5bTGphdmEubGFuZ y5TdGFja1RyYWNlRWxlbWVudDsCRio8PP0iOQIAAHhwAAAABnNyABtqYXZhLmxhbmcuU3R hY2tUcmFjZUVsZW1lbnRhCcWaJjbdhQIABEkACmxpbmVOdW1iZXJMAA5kZWNsYXJpbmdDb GFzc3EAfgABTAAIZmlsZU5hbWVxAH4AAUwACm1ldGhvZE5hbWVxAH4AAXhwAAAAsnQALmN vbS5pYm0ud3MubWFuYWdlbWVudC5jb25uZWN0b3Iuc29hcC5TT0FQVXRpbHN0AA5TT0FQV XRpbHMuamF2YXQAD2V4dHJhY3RTb2FwQ2FsbHNxAH4ACgAAAHB0ADJjb20uaWJtLndzLm1 hbmFnZW1lbnQuY29ubmVjdG9yLnNvYXAuU09BUENvbm5lY3RvcnQAElNPQVBDb25uZWN0b 3IuamF2YXQAB3NlcnZpY2VzcQB+AAoAAAA3dAAzY29tLmlibS53cy5tYW5hZ2VtZW50LmN vbm5lY3Rvci5zb2FwLlNPQVBDb25uZWN0aW9udAATU09BUENvbm5lY3Rpb24uamF2YXQAD WhhbmRsZVJlcXVlc3RzcQB+AAoAAAKodAAeY29tLmlibS53cy5odHRwLkh0dHBDb25uZWN 0aW9udAATSHR0cENvbm5lY3Rpb24uamF2YXQAFHJlYWRBbmRIYW5kbGVSZXF1ZXN0c3EAf gAKAAAB5HQAHmNvbS5pYm0ud3MuaHR0cC5IdHRwQ29ubmVjdGlvbnQAE0h0dHBDb25uZWN 0aW9uLmphdmF0AANydW5zcQB+AAoAAAW9dAAhY29tLmlibS53cy51dGlsLlRocmVhZFBvb 2wkV29ya2VydAAPVGhyZWFkUG9vbC5qYXZhdAADcnVueHQAGVNPQVAtRU5WOlNlcnZlci5 FeGNlcHRpb25zcgAiamF2YS5sYW5nLklsbGVnYWxBcmd1bWVudEV4Y2VwdGlvbrWJc9N9Z o+8AgAAeHIAGmphdmEubGFuZy5SdW50aW1lRXhjZXB0aW9unl8GRwo0g+UCAAB4cQB+AAN xAH4AJnQIrGNvbS5hZG9iZS5pZHAuZHNjLnByb3ZpZGVyLmltcGwuZWpiLkVqYlJlcXVlc 3RIb2xkZXIKU2VydmVyIHN0YWNrIHRyYWNlCkpNWFRyYW5zZm9ybUV4Y2VwdGlvbiBqYXZ hLmxhbmcuQ2xhc3NOb3RGb3VuZEV4Y2VwdGlvbjogY29tLmFkb2JlLmlkcC5kc2MucHJvd mlkZXIuaW1wbC5lamIuRWpiUmVxdWVzdEhvbGRlcgoJYXQgamF2YS5uZXQuVVJMQ2xhc3N Mb2FkZXIuZmluZENsYXNzKFVSTENsYXNzTG9hZGVyLmphdmE6NDkyKQoJYXQgY29tLmlib S53cy5ib290c3RyYXAuRXh0Q2xhc3NMb2FkZXIuZmluZENsYXNzKEV4dENsYXNzTG9hZGV yLmphdmE6MTMyKQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmxvYWRDbGFzcyhDbGFzc 0xvYWRlci5qYXZhOjYwMykKCWF0IGNvbS5pYm0ud3MuYm9vdHN0cmFwLkV4dENsYXNzTG9 hZGVyLmxvYWRDbGFzcyhFeHRDbGFzc0xvYWRlci5qYXZhOjg3KQoJYXQgamF2YS5sYW5nL kNsYXNzTG9hZGVyLmxvYWRDbGFzcyhDbGFzc0xvYWRlci5qYXZhOjU2OSkKCWF0IGNvbS5 pYm0ud3MubWFuYWdlbWVudC5jb25uZWN0b3IuaW50ZXJvcC5KTVhDbGFzc0xvYWRlci5sb 2FkSk1YQ2xhc3MoSk1YQ2xhc3NMb2FkZXIuamF2YToyMTEpCglhdCBjb20uaWJtLndzLm1 hbmFnZW1lbnQuY29ubmVjdG9yLmludGVyb3AuSk1YQ2xhc3NMb2FkZXIubG9hZE9sZEpNW ENsYXNzKEpNWENsYXNzTG9hZGVyLmphdmE6MTY1KQoJYXQgY29tLmlibS53cy5tYW5hZ2V tZW50LmNvbm5lY3Rvci5pbnRlcm9wLkpNWENsYXNzTG9hZGVyLmxvYWRDbGFzcyhKTVhDb GFzc0xvYWRlci5qYXZhOjEwMikKCWF0IGNvbS5pYm0ud3MubWFuYWdlbWVudC5jb25uZWN 0b3IuaW50ZXJvcC5KTVhPYmplY3RJbnB1dFN0cmVhbS5yZXNvbHZlQ2xhc3MoSk1YT2JqZ WN0SW5wdXRTdHJlYW0uamF2YTo5NSkKCWF0IGphdmEuaW8uT2JqZWN0SW5wdXRTdHJlYW0 ucmVhZE5vblByb3h5RGVzYyhPYmplY3RJbnB1dFN0cmVhbS5qYXZhOjE1NjMpCglhdCBqY XZhLmlvLk9iamVjdElucHV0U3RyZWFtLnJlYWRDbGFzc0Rlc2MoT2JqZWN0SW5wdXRTdHJ lYW0uamF2YToxNDg1KQoJYXQgamF2YS5pby5PYmplY3RJbnB1dFN0cmVhbS5yZWFkT3Jka W5hcnlPYmplY3QoT2JqZWN0SW5wdXRTdHJlYW0uamF2YToxNzE4KQoJYXQgamF2YS5pby5 PYmplY3RJbnB1dFN0cmVhbS5yZWFkT2JqZWN0MChPYmplY3RJbnB1dFN0cmVhbS5qYXZhO jEzMjQpCglhdCBqYXZhLmlvLk9iamVjdElucHV0U3RyZWFtLnJlYWRPYmplY3QoT2JqZWN 0SW5wdXRTdHJlYW0uamF2YTozNjIpCglh
    Jul 4, 2007 8:09 AM   in reply to (David_Gao)
    You can determime whether a process is being invoked and is working by using logging onto the ACC at and clicking Services > LiveCycle Process Management ES > Process Search.
    See the Archive Administration Help at http://www.adobe.com/support/documentation/en/livecycle/es/
    Do a search on your process and you will be able tell if the process is being invoked and whether it is stalling.
    Another suggestion is to make sure that you all the JAR files required to invoke this process using WEBSPHERE and SOAP. For a listing of JAR files see the SDK help at the above URL. The topic is named Including LiveCycle ES library files.
    Hope this helps.
    Jul 5, 2007 1:12 PM   in reply to (David_Gao)
    Is you variable xmlDocument of type document or xml in the LiveCycle process?
    Can you try to put it in a String just to test your code?
    Can you also try to use the EJB invocation instead of SOAP and see if you get the same error?
    Jasmin
    Calculating status...
    Dec 18, 2007 2:17 AM   in reply to (David_Gao)
    I dont know whether this is a right forum to ask this question, but I'll go ahead:
    I have a batch processing requirement for the Output ES, I am getting an XML document as input that has records for about 500+ PDF's.
    I am currently doing the following:
    1) Creating the connection properties.
    2) Creating an OutputClient.
    3) using setSynchronous(false).
    4) calling generatePDFOutput
    I am getting the output PDFs and the code is working fine.
    since this is an asynchronous request, is there some way I can get the status of the request(like a job handle or something)?
    I am not using the JobManager currently.
    Dec 18, 2007 5:27 AM   in reply to (David_Gao)
    If you invoke the process asynchronously, then you are using Job Manager.
    That's the nature of an asynchronous call. You make the call, then jop manager returns a job id. Then you can use the job id to query the status of the call.
    Jasmin
    Dec 18, 2007 6:24 AM   in reply to (David_Gao)
    Ok this is what I am doing, But I am getting the invocation ID as
    null
    InvocationRequest request = myFactory.createInvocationRequest(
    "OutputService",
    "generatePDFOutput",
    params,
    false);
    InvocationResponse response = myServiceClient.invoke(request);
    String invocationId = response.getInvocationId();
    But the PDFs are getting generated. Since there are more than 500 pdf getting generated(one XML has all the records) therefore I need to use the asynchronous call. But at the same time I want to also keep querying the status of the process, for that I require a JobManager(and subsequently a JOB ID).Since the invocationId is itself null I am unable to create the job manager.
    Can createJob(request,persistent) be used, I checked the API and it said "used internally"?
    This is really urgent so a prompt answer please.
    Thanks in advance.
    Dec 18, 2007 10:29 AM   in reply to (David_Gao)
    Why are you using the Invocation API as opposed to the Output Java client library. It is recommended that you use the Output Java client as opposed to the invocation API.
    Dec 18, 2007 8:10 PM   in reply to (David_Gao)
    I needed to use the invocation API because I wanted to use the JobManager, We will be processing about 500 PDF at a go, we wanted the process to be asynchronous and also wanted to find the status of the process at run time.I looked into the documentation and found that only long-lived processes can be used with Job Manager.
    Is there some way We can have the same functionality, without using the Job Manager? Or, is there some other way to find out the status of the process while its still executing ?
    Thanks in advance.
    Dec 20, 2007 10:18 AM   in reply to (David_Gao)
    "I looked into the documentation and found that only long-lived processes can be used with Job Manager."
    Where did you find that in the doc? You should be able to call a short lived process asynchronously. I think there is a bug with the current build (that won't help you now) but technically you should be able to do that.
    "Is there some way We can have the same functionality, without using the Job Manager? "
    Your best bet would be to call support and see if you can get it fixed.
    Jasmin
    Dec 24, 2007 3:41 AM   in reply to (David_Gao)
    Is XSL-FO supported in LiveCycle Output?
    Dec 27, 2007 3:05 AM   in reply to (David_Gao)
    http://livedocs.adobe.com/livecycle/es/sdkHelp/programmer/sdkHelp/invo kingIntro.24.3.html
    "Processes can be short-lived or long-lived. A short-lived process is an operation that is performed synchronously and on the same execution thread from which it was invoked. Short-lived operations
    are comparable to the standard behavior found in most programming languages, where a client application calls a method and waits for a return value."
    We can invoke the short-lived process using the JobManager.. but it makes no sense since they are synchronous.
    Thanks for your help anyways.
    Well. I have another question
    How do we use the setRenderAtClient() in the class RenderOptionsSpec.
    Have u got any examples or something that could help?
    Jan 2, 2008 5:57 AM   in reply to (David_Gao)
    Can the Watched Folder be configured for the GeneratePDFOutput Service.
    I have a requirement where I will have to FTP an XML data file to a folder and generate the PDFs?
    I dont have an option to use the Java API.
    Sushant
    Jan 4, 2008 4:20 AM   in reply to (David_Gao)
    I have a small question.
    I was looking at the documentation for LiveCycle invocation and found that LiveCycle services can be invoked by
    1) Java API (through RMI or SOAP)
    2) Web-Services(over SOAP)
    3) Watched Folder and Email.
    Is there any difference between invoking the Service through Java API SOAP and the Webservice invocation- if my client is a java based client?
    Sushant
    Jan 6, 2008 10:25 AM   in reply to (David_Gao)
    Sushant,
    There is a difference between invoking the Java API with the SOAP protocol configured, and using the web services bindings. For the Java API the primary contract you have is the Java interface itself. We optimize the serialization of objects across this protocol for performance improvements. But the web services interface is based on the WSDL that we publish in the LiveCycle_ES_SDK and is WS-I compliant.
    What are the guidelines for using each?
    Java API: Use this if you want a strongly typed Java API to call LC or if performance is critical. The RMI protocol is roughly twice as fast as the SOAP protocol, but isn't as firewall friendly. That's why we gave the choice to also use SOAP if needed. We use the Java API with SOAP protocol for the communication between Workbench and the server and for this kind of client/server interaction, the performance difference is negligible.
    Web Services: Use this if you would like to call LiveCycle in a more SOA type of architecture. We publish the WSDL and have tested the creation of client stubs with a number of web service implementations including .NET, Axis, etc.
    Joe
    Jan 7, 2008 5:32 AM   in reply to (David_Gao)
    Thanks Joe for the quick reply,
    another question:
    How do we call the LiveCycle in a clustered environment using
    the SOAP Java API(in Websphere), I know that using RMI(EJB) we can call by using the corbaloc?
    Sushant
    Jan 7, 2008 9:37 PM   in reply to (David_Gao)
    How do we grant the LiveCycle Server the rights to access the physical printer?
    Sushant
    Jan 8, 2008 5:25 AM   in reply to (David_Gao)
    As long as the account the LiveCycle service runs under has access to the printer from the LiveCycle server then you should be fine.
    Jasmin
    Jan 8, 2008 6:27 AM   in reply to (David_Gao)
    Is there anyway to make a static call to the Output Service in a clustered environment(using EJB)?
    Sushant
    Jan 11, 2008 10:46 AM   in reply to (David_Gao)
    I'm not sure what you mean by a static call.
    Jasmin
    Jan 14, 2008 3:01 AM   in reply to (David_Gao)
    By static value what I meant was suppose we have a clustered env with 3 nodes defined(n1,n2,n3) each node having one application server each
    a1,a2 and a3 respectively. When we deploy LiveCycle to this environment then LiveCycle will install in all the application servers.
    Now suppose only one of the application server say a1 has access to the physical printer,so I would want to be able to send all printer related requests to this specific server only.Is there some way to do it(assume I have a WebSphere env)?
    Sushant.
