Connecting to Form Server ES
Jul 5, 2007 10:13 AM
Does anyone know the url to the wsdl for Form Server ES once it has been installed?  I have the url in the admin set to http://<myServer>/FormServer .
    Jul 5, 2007 1:35 PM   in reply to (ChrisTurner)
    In LiveCycle ES, everything that is installed in considered a service running in the service container.
    If the service has a web service endpoint created for it (which is the case for most services), then it can be called with the following format:
    http://servername:port/soap/services/NameOfService?wsdl.
    If LiveCycle Forms is installed , then there will be a FormsService service running and the URL should be (jboss example) http://localhost:8080/soap/services/FormsService?wsdl
    Jasmin
    Jul 6, 2007 10:54 AM   in reply to (ChrisTurner)
    Can you go under the administrative console (http://localhost:8080/adminui) under Services/Archive Administration/Services Management and make sure the service is installed and started?
    For some reason it seems that it's not installed or started properly. That URL works for me.
    Jasmin
    Jul 6, 2007 12:53 PM   in reply to (ChrisTurner)
    Hmmm, That is very strange. I'm not sure why it's not there. One thing you can try is to add it manually.
    Start WorkBench.
    Make sure you have the Component view opened (Windows/Show Views).
    Right click and select install.
    Browse to C:\Adobe\LiveCycle8\deploy\adobe-forms-dsc.jar
    Then right click and start.
    This should install it.
    Jasmin
