Disable all fields, buttons, etc in Subform
Nov 27, 2008 6:24 AM
Is there an easy way to disable the contents of a subform?
    Nov 27, 2008 7:01 AM   in reply to (Affliction)
    You can turn the presence of the subform to invisible and all children will be made invisible as well.
    You could get all child nodes of the subform and change their access property to readOnly. I have a script function that accepts a node (in your case a subform) and will get all children of that node....then you can do what you want to them.
    Post your email address and I will send the sample ...if you want it.
    Jan 23, 2009 4:11 AM   in reply to (Affliction)
    If the «subform» already has an «access» attribute on its xml template definition, then you can make the subform and all its descendants read-only by setting the subform's «access» attribute to «readOnly», in JavaScript.
    Nov 15, 2012 9:19 AM   in reply to pguerett
    Could you post that code here?
    Nov 15, 2012 11:22 AM   in reply to JohnQWestat
    Will be like this.
    subformname.access = "readOnly"; //javaScript
    $.access = "readOnly"; //formcalc
    update the "subformname" with the name of ur subform which want to make readOnly. Place this on a required event based on ur requirement, both javascript and formcalc sysntaxes are above.
    Nov 15, 2012 11:27 AM   in reply to Raghu Nagireddy
    Raghu,
    Thank you for your response.  My request was intended to be a response to pguerette's post:
    If anyone has this code, that is what I was asking for.
    Nov 15, 2012 11:41 AM   in reply to JohnQWestat
    If need only at "subform" level please check the thread: http://forums.adobe.com/message/4389004#4389004
    If need at "form root" level, Please check the below function.Pass "oParentNode" as root of the form.
    function traverse(oParentNode)
              var allChildElements;
              var intNumElements;
              var currentElement;
              var i;
              var j;
              // Get all occurances of the parent element
              intNumOccurances = oParentNode.all.length;
              for (i=0; i < intNumOccurances; i++)
                        oCurrentParent = oParentNode.all.item(i);
                         // Get all the child nodes of the parent element
                        allChildElements = oCurrentParent.nodes;
                        // Total number of elements in the object
                        intNumElements = allChildElements.length;
                        // Loop through all the child elements
                        for (j=0; j < intNumElements; j++)
                                  currentElement = allChildElements.item(j);
                                  // If the element is another subform we'll recursively call the function again
                                  if (allChildElements.item(j).className == "subform")
                                            traverse(currentElement);
                                            // If the objects are fields or exclusive groups then we'll encode them
                                  } else {
                                            if (currentElement.className == "field" || currentElement.className == "exclGroup")
                                                      //Here have the access for both field and value
                                     //your code comes here
                                                      fields += currentElement.name + "\t";
                                                      values += currentElement.rawValue + "\t";
    }          // end traverse function
    Hope it may helps.
