How to split PDF file by pages
Feb 28, 2008 2:55 PM
Is there any programming way to split PDF into pages, say one PDF file per page or specify page range to split PDF file?
Thanks for your help.
    Feb 28, 2008 4:04 PM   in reply to (qpan)
    yes, you can use assembler service and use the ddx to split a pdf into pages
    mergeandfuse@gmail.com
    Feb 29, 2008 9:13 AM   in reply to (qpan)
    <?xml version="1.0" encoding="UTF-8"?>
    <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
    <PDF result="Final.pdf">
    <PDF source="PDF1.pdf" pages="1-3"/>
    <PDF source="PDF2.pdf" pages="4-5"/>
    </PDF></DDX>
    Aug 20, 2009 3:10 AM   in reply to (WorkflowUser)
    Is this code really dissassembling the pdf? Look more like merging two pdfs together.
    What if I have a PDF with 10 pages, which I want to split into 10 pdfs - one pdf per page.
    Aug 20, 2009 5:58 AM   in reply to LekomDev
    Yes it does. It disassembles pdf1 by extracting pages 1-3 and disassembles pdf2 by extracting pages 4-5. Then re-assembles the two subsets into a new PDF.
    You could extract page1 from pdf1 only and create a pdf, then page2 of pdf1 into a different PDF using something similar to:
         <PDF source="PDF1.pdf" pages="1"/>
    </PDF>
    <PDF result="Final2.pdf">
          <PDF source="PDF1.pdf" pages="2"/>
    </PDF>
    </DDX>
    You can also use the  PDFFromBookmarks tag to generate a new document for each level 1 bookmark created in a PDF.
    <PDFsFromBookmarks prefix="stmt">
         <PDF source="doc1.pdf"/>
    </PDFsFromBookmarks>
    You can get more info at http://livedocs.adobe.com/livecycle/8.2/ddxRef/000640.html
    Jasmin
    Aug 20, 2009 7:39 AM   in reply to Jasmin Charbonneau
    Great thanks, works perfect! Bookmarks I don´t have, so I will cycle and modify the result and page number in ddx, if possible.
    Anyway - how to get number of the pages from docForm variable?
    Jul 30, 2010 6:21 AM   in reply to LekomDev
    If you use the docInfo command in the DDX it will return a pile of
    info, including the page count
    Feb 13, 2011 10:07 PM   in reply to (qpan)
    The Acrobat Javascript can't access the code of a bookmark,so I think we can also use a 3rd party program PDF splitter to split PDF files by pages or bookmark.
    Feb 22, 2013 5:35 AM   in reply to (qpan)
    The set of codes offered here is a nice finding of me today, I also think it's a simple way that I can use to <link removed> from the tips I find from Wiki how. Both are worth trying.
    Message was edited: for this user, across multiple threads, to remove link promotion
    Aug 4, 2013 8:13 PM   in reply to (qpan)
    Hi.If you want to split PDF,i'll suggest you to creat a sample c#project.With .NET imaging SDK,you may easily split PDFfiles by pages
