Views
Total Likes
Hi Johannes,
did you ever find out what the underlying issue is/was? Having the same problem, on LC ES 2 though:
2010-07-06 11:24:54,605 INFO [com.adobe.idp.dsc.startup.DSCStartupServlet] Install and start of components complete. Now starting core asynchronous services ...
2010-07-06 11:24:54,980 ERROR [STDERR] 6/07/2010 11:24:54 AM com.adobe.idp.scheduler.callback.ServiceCallbackHandler execute
SEVERE: Exception thrown while calling back a DSC componentcom/adobe/edc/policy/APSDocumentServicesManagerHome
2010-07-06 11:24:55,011 INFO [org.quartz.core.JobRunShell] Job APS_PRINCIPALKEY_REKEY_JOB_GRP.APS_PRINCIPALKEY_REKEY_JOB threw a JobExecutionException:
org.quartz.JobExecutionException: java.lang.Exception: java.lang.IllegalStateException [See nested exception: java.lang.Exception: java.lang.IllegalStateException]
Cheers
Kai
Views
Total Likes
As am I,
I manually installed LC ES2 into a new JBoss/mySQL instance following the manual install instructions here:
http://help.adobe.com/en_US/livecycle/9.0/prepareinstallsingle.pdf
http://help.adobe.com/en_US/livecycle/9.0/install_jboss.pdf
Then, applied the SP1, now I get this exception every ten minutes on the dot.
2010-09-24 00:00:00,038 ERROR [STDERR] 24/09/2010 00:00:00 com.adobe.idp.scheduler.callback.ServiceCallbackHandler execute
SEVERE: Exception thrown while calling back a DSC componentcom.adobe.edc.common.EDCException
2010-09-24 00:00:00,076 INFO [org.quartz.core.JobRunShell] Job APS_PRINCIPALKEY_REKEY_JOB_GRP.APS_PRINCIPALKEY_REKEY_JOB threw a JobExecutionException:
org.quartz.JobExecutionException: java.lang.Exception: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error. [See nested exception: java.lang.Exception: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.]
at com.adobe.idp.scheduler.callback.ServiceCallbackHandler.execute(ServiceCallbackHandler.java:102)
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:529)
Caused by: java.lang.Exception: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
at com.adobe.idp.scheduler.callback.ServiceCallbackHandler.execute(ServiceCallbackHandler.java:101)
... 2 more
Any suggestions on how to check the callback schedule for the misbehaving callback ?
Jason.
Views
Total Likes
Hi Jason,
Does this problem come even after server restart?
Hina
Views
Total Likes
I'm seeing these same errors too. Anyone have any luck figuring out the issue?
Views
Total Likes
Hi All,
Did anyone find a resolution to this problem? even i am facing the same issue.
On one of the blogs i found a resolution, tried it but it seems not to work.
1) Stopped lc server
2) cleared out all temp files and caches
Restarted App server, but it doesn't work. still the same error message every 10 minutes
The blog also states to do the following steps
4) Reinstall the ES 2 server patch
5) Restart server - came up without error
So did anyone else try these steps, and resinstalling SP1, is it required.
Hkin
Views
Total Likes
Hi All,
Did anyone solve this issue ..
I am facing the same issue.
Regards--
Chalukya.
Views
Total Likes
