external editor cannot find files
Mar 3, 2007 11:29 AM
this issue did not happen with Lightroom beta, but does happen with 1.0 release.
I use Photoshop 5.02 as the external editor. when I select "Edit in photoshp" from the context menu, it opens the photoshop, but photoshop says "cannot find the file". I tried some other programs as the external editor and it seems to me that the problem happens because Lightroom puts quotes around file path, e.g.
"d:\myfolder\myfile.tif"
instead of just
Is there a a way to fix it? Currently, for each file I have to open it in Explorer and then open it in photoshop. It's annoying and what is most annoying that it used to work in Lightroom beta.
any suggestions?
    Mar 3, 2007 1:58 PM   in reply to gennadym
    Generally, putting quotes around a file/path name shouldn't cause problems. In many situations (at a command prompt) you need the quotes when the path or file name contains spaces.
    I haven't heard of anyone having this problem, but have read many posts of people using Edit in photoshop without problems. I don't have problems on a Mac.
    I assume you use Windows (the use of "d:" is a giveaway :-) ), but is this Vista? Also, what is the d: device, mapped drive to a network? to external drive?
    - Pierre
    Mar 9, 2007 9:54 PM   in reply to gennadym
    I have also encountered this problem ... but I am using CS2. When I look in the preferences, it says photoshop not found
