Multiple clients connected to LocalConnectionServer
Nov 18, 2008 6:21 AM
I'm trying to use the LocalConnection example application to test a few scenarios for Cocomo, and I'm unable to run more than one client instance on the same computer. Once the exception occurs, the entire state of the system seems to be unstable, and I have to restart the LocalConnectionServer. For specifics, it gacks on the startup of the second client with the following exception:
ReferenceError: Error #1065: Variable flash.media::SoundCodec is not defined.
at com.adobe.rtc.clientManagers::MicrophoneManager/get selectedMic()[C:\work\main\connect\cocomoPlayer10\src\com\adobe\rtc\c lientManagers\MicrophoneManager.as:155]
at com.adobe.rtc.clientManagers::MicrophoneManager/set _1703516469micIndex()[C:\work\main\connect\cocomoPlayer10\src\com\ado be\rtc\clientManagers\MicrophoneManager.as:121]
at com.adobe.rtc.clientManagers::MicrophoneManager/set micIndex()[C:\work\main\connect\cocomoPlayer10\src\com\adobe\rtc\clie ntManagers\MicrophoneManager.as:117]
at com.adobe.rtc.clientManagers::MicrophoneManager()[C:\work\main\connec t\cocomoPlayer10\src\com\adobe\rtc\clientManagers\MicrophoneManager.as :77]
at com.adobe.rtc.clientManagers::MicrophoneManager$/getInstance()[C:\wor k\main\connect\cocomoPlayer10\src\com\adobe\rtc\clientManagers\Microph oneManager.as:88]
at com.adobe.rtc.sharedManagers::StreamManager/findCodec()[C:\work\main\ connect\cocomoPlayer10\src\com\adobe\rtc\sharedManagers\StreamManager. as:1839]
at com.adobe.rtc.sharedManagers::StreamManager/onUserAdd()[C:\work\main\ connect\cocomoPlayer10\src\com\adobe\rtc\sharedManagers\StreamManager. as:1811]
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at com.adobe.rtc.sharedManagers::UserManager/userReceivedOrEdited()[C:\w ork\main\connect\cocomoPlayer10\src\com\adobe\rtc\sharedManagers\UserM anager.as:988]
at com.adobe.rtc.sharedManagers::UserManager/onItemReceive()[C:\work\mai n\connect\cocomoPlayer10\src\com\adobe\rtc\sharedManagers\UserManager. as:841]
at com.adobe.rtc.sharedModel::CollectionNode/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveIt em()[C:\work\main\connect\cocomoPlayer10\src\com\adobe\rtc\sharedModel \CollectionNode.as:741
at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveIt em()[C:\work\main\connect\cocomoPlayer10\src\com\adobe\rtc\messaging\m anager\MessageManager.as:661
at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveIt ems()[C:\work\main\connect\cocomoPlayer10\src\com\adobe\rtc\messaging\ manager\MessageManager.as:536
at com.adobe.rtc.session.managers::SessionManagerBase/receiveItems()[C:\ work\main\connect\cocomoPlayer10\src\com\adobe\rtc\session\managers\Se ssionManagerBase.as:374]
    Nov 18, 2008 10:50 AM   in reply to RickBullotta
    Hi Rick,
    From the looks of it, you're compiling against the FP10 swc, but haven't set your project to require Flash Player 10 - the exception is referring to player internals. If you look at Project Properties->Flex Compiler, is your "Require Flash Player Version" set to 10.0.0 or higher?
    thanks
    nigel
    Nov 18, 2008 11:27 AM   in reply to RickBullotta
    Hi Rick,
    Yes you need to a have Flex SDK targetting player 10 for getting the correct playerglobal.swc. It can be either Flex SDK 4.0 build or Flex SDK 3.0 build that support player 10.
    Hironmay
