Adobe Photoshop Album Starter edition 3.0
Aug 18, 2006 12:59 PM
I have a mustek 2400 M series scanner. How do i add the adobe photoshop to the shortcut for the scanner panel? i sometimes need to do a direct scan using the 2400m scanner. i can open from photoshop, but in some cases i need to do a direct scan.
Branched to a new discussion.
Replies 1 2 3 Previous Next
    Aug 18, 2006 3:37 PM   in reply to (Steve_Zeitz)
    Scan and import later perhaps?
    Not really sure what you're asking.
    Aug 20, 2006 7:02 PM   in reply to (Steve_Zeitz)
    how can i email photos from (Adobe Photoshop Album Starter Edition 3.0) thanks very much, Rosalinda
    Aug 20, 2006 11:17 PM   in reply to (Steve_Zeitz)
    Rosalinda
    This is really a new topic ...
    Just select the photo(s) and click the Sahe button. Should be straightforward from then on. Have you tried and had difficulties?
    Aug 21, 2006 4:30 PM   in reply to (Steve_Zeitz)
    How do I copy pictures from Adobe Photoshop to a CD.
    Aug 21, 2006 5:34 PM   in reply to (Steve_Zeitz)
    I downloaded Photoshop tryout version. I got E mail with the unlock code
    Where do I enter this code?.....Mike
    Aug 25, 2006 3:57 AM   in reply to (Steve_Zeitz)
    I am running microsoft XP. How do I move the album from an old pc to the new without resorting to coping all to a cd?
    Aug 25, 2006 4:02 AM   in reply to (Steve_Zeitz)
    Liz
    You need to do 3 things:
    1) Install PSA SE 3 on th enew PC.
    2) Move the image files - these are probably located in/under My Pictures - making sure that they are in the exact same place on th enew PC. How you do this move is up to you - I normally use an external hard drive, but networking is another option, as are CDs.
    3) Find and move the catalog file. This is called My Catalog.PSA - you will have to search for it, as I don't know he default location and it may be in a hidden folder. Locate it in the same place on the new PC.
    Sep 1, 2006 7:45 PM   in reply to (Steve_Zeitz)
    I have Adobe Image Ready, Photoshop 7.0 and Photoshop Album SE 3.0. I am just learning to use these programs and thought the SE would be the easier program to begin with...) Anyway, I want to add music files from my Windows Media Player to my digital photo slideshow...is this possible? When I first created the catalog I noticed a dialog box asking if I wanted to attach media files to my slideshow, I didn't at that time. However now I cannot seem to find the option. (I am running XP Professional.)
    Any insights would be extremely helpful and most gratefully received.
    Sep 1, 2006 11:37 PM   in reply to (Steve_Zeitz)
    PSA SE will let you import MP3 files [in the same way as you do pictures] and use those. I believe that WMP uses a different format - because Uncle Bill knows best.
    Sep 8, 2006 5:56 AM   in reply to (Steve_Zeitz)
    How can I set up the Album Starter Edition 3.0 NOT to save images from websites I explored? Thank you, Frank
    Sep 8, 2006 6:07 AM   in reply to (Steve_Zeitz)
    kyi lin
    It sounds like you have Watched Folders set to include the folder that IE uses to cache images.
    Sep 8, 2006 2:54 PM   in reply to (Steve_Zeitz)
    Hi Colin:
    How can I find watched folders? I haven't set up anything to catch images.
    Sep 9, 2006 3:33 AM   in reply to (Steve_Zeitz)
    Just look in Edit/Preferences - you can just turn off folder watching there.
    Sep 9, 2006 3:34 AM   in reply to (Steve_Zeitz)
    BTW, PSA SE isn't saving these images, it is just cataloging them. IE is saving them.
    Sep 9, 2006 7:39 AM   in reply to (Steve_Zeitz)
    Hi Colin.
    I owned Photoshop Album 2.0. In it, I can make a recipient list to send photos by E-mail just by checking the little square left of the recipient name. I recently downloaded Starter Edition 3.0 (try version I guess). In it, I can not make a recipient list to send photos by E-mail. Instead, a window open (with the photo attached) in which I have to write the address of the recipient. Do I have to buy 3.0 in order to have that possibility?
    Sep 9, 2006 7:43 AM   in reply to (Steve_Zeitz)
    Lomer
    This is a new topic...
    Uninstall PSA SE 3. This [free] program is a step back from PSA 2. It is not a "trial" for PSA 3 - there is no such thing. The successor to PSA 2 is Photoshop Elements 3/4.
    Sep 9, 2006 10:32 AM   in reply to (Steve_Zeitz)
    Hi Colin.
    I uninstalled PSA SE 3. I downloaded PSE 4. I can not send photos by e-mail using PSE 4, because the ''send mail'' is not there. Is it because it is a trybuy version? If we are really to try the version, then the logic escape me (if I do not think business of course). Respecfully.
    Sep 9, 2006 10:37 AM   in reply to (Steve_Zeitz)
    The PSE tryout is fully functional. To send email just do Share/email...
    Sep 9, 2006 11:58 AM   in reply to (Steve_Zeitz)
    Hi Colin.
    It does not work. I have PSA 2 and it works fine.
    Sep 9, 2006 12:02 PM   in reply to (Steve_Zeitz)
    > It does not work
    Please explain.
    Sep 9, 2006 12:15 PM   in reply to (Steve_Zeitz)
    I select one photo. I do ''share'' and then e-mail. I click ''next''.
    I see a red bar, like something is loading and then the window ''outlook express'' appears. The menu bar is : reply...reply to all...forward... but ''send'' does not appear. The from line reads : From : sender unspecified. But the same operations with PSA 2 works just fine.
    Sep 9, 2006 12:17 PM   in reply to (Steve_Zeitz)
    This is a well known problem caused by a recent Windows update. Take a look at the PSE forum: http://www.adobeforums.com/cgi-bin/webx/.3bbb4ab0/
    - there is information on how to fix it there. A simple workaround is to Forward this email.
    Sep 9, 2006 12:40 PM   in reply to (Steve_Zeitz)
    Okay, I think I need more direction. Can you explain this process? Import music files from where...I am getting my photos from my camera.
    Sep 9, 2006 1:00 PM   in reply to (Steve_Zeitz)
    Get Photos/From Files and Folders - or something very like that.
    Nov 9, 2007 10:28 AM   in reply to (Steve_Zeitz)
    My 23 page document scanned but only 1 page showed on my adobe phtoshop starter edition 3.0 album
    Nov 9, 2007 10:32 AM   in reply to (Steve_Zeitz)
    I scanned a 23 page document into my adobe photoshop starter 3.0 album. Only one page actually scanned into my album. I tried this three separate times with the same result. Could you help please?
    Nov 9, 2007 10:42 AM   in reply to (Steve_Zeitz)
    PSA SE only handles 1 page PDFs.
    Nov 9, 2007 12:49 PM   in reply to (Steve_Zeitz)
    I seem to have lost an entire folder of photo's I just downloaded from my digital camera last week. I can see them with all my other photo's in my album, but they have a red square at the bottom with a crack in it that seems to signify that they are missing. When I click on the photo, it starts searching for the photo but can't find it, stating that it is missing from the catalog. Where are those pictures and how can I retrieve them. I can't believe they would be totally lost because I can see them in my album. And of course I have already emptied the photo's from my camera. Any help would be appreciated. If you are able to email me, please do so at jodiego@san.rr.com. Thanks
    Nov 10, 2007 2:47 AM   in reply to (Joseph_Furtado)
    Hi Joseph,
    We don't email so that other people can benefit when they search the
    forum for solutions to their problems.
    Nevertheless... what has happened is that the photos have become
    disconnected from the thumbnails in PSA-SE. The application does NOT
    hold them. It merely monitors their location. First verify that you did
    not delete the folder in Windows Explorer. If you didn't, then you can
    click on File, Reconnect. The problem with this approach is... you only
    reconnect to suggested images and one at time...
    Cheers
    Nov 10, 2007 6:23 AM   in reply to (Steve_Zeitz)
    Hi - I have down loaded the Starter Version of Photo Album but am unable to
    a: Register as I do not get an email with my Unlock Key ???
    b: Use any of the "Create" functions as the program seems to be trying to down load but after a while a dialog box tells me that my Internet connection is faulty ! I am on ADSL so what's up Doc ??
    Now only have 4 occassions to use this program left and am getting desperate.
    Hank G van de Weg
    Nov 10, 2007 7:16 AM   in reply to (Hank_G_van_de_Weg)
    Hank,
    Please confirm that you saw my previous reply to you?
    Cheers
    Nov 11, 2007 1:41 AM   in reply to (Steve_Zeitz)
    I have downloaded V 3.2 and now it wont access the catalogs and wont completely start unless it can access a catalog.
    Nov 11, 2007 4:33 AM   in reply to (Richard_Aiello)
    Hi Richard,
    Did you happen to change operating systems between upgrades?
    Cheers
    Nov 23, 2007 6:43 AM   in reply to (Steve_Zeitz)
    Jim and Collin - not sure everyone is able to find your responses. After several attempts to find some responses and posts that I submitted, I have concluded that this forum is about as user friendly as PSE (or is it PSE2 or PASE or PSA2 or ???). I found that these acronyms seem to be used interchangably and that other folks are having as much trouble finding their responses as me. I still have not found any of several responses or posts that I submitted. I tried each of the options for replying, posting a response, etc. Maybe you can help some of us figure out how to go back to the same list of questions/responses and find the answers to our questions in this forum.
    Nov 25, 2007 10:57 AM   in reply to (W._Fowler)
    The easiest way, is to subscribe to your own post. Otherwise, the posts
    appear in the order in which they were most recently active. Does that
    make sense?
    Another way you SHOULD be able to do this, is just search for your own
    name. All of your posts will show up.
    Does that help? FYI, Colin and I do NOT use the acronyms interchangably,
    we are might be using them to refer to components in one another but
    they are to us very different products. Keep in mind that this forum is
    for beginners so it is possible that they might not be sure where they
    are... That does happen.
    Cheers
    Nov 25, 2007 11:48 AM   in reply to (Steve_Zeitz)
    I have, previous to Hotmail's upgrading a few months ago, been able to send photos. Now, I send photos by using SHARE in Photoshop, and I am still required to log into Hotmail the same but when the Hotmail screen comes up it shows instead of photo attachment files below the subject line, shows the words "show plain text" and no one is receiving any photos. Anyone else having this same problem?
    Is this Hotmail or a Photoshop problem?
    Frustrated Dan
    Nov 25, 2007 2:07 PM   in reply to (Jim_Jütte)
    Hi Jim,
    I finally figured out yesterday that I could do what you recommended, but thanks all the same. I probably did not make it clear enough, but it was not my intent to criticize you or Colin; just pointing out my observations about the confusing use of the acronyms on the forum. It is often difficult to know which product people are referring to and I did notice that both of you have frequently had to question users to make that determination. I applaud you and Colin for devoting so much of your time to helping all those users and I sincerely do appreciate your help.
    Wayne
    Nov 25, 2007 10:04 PM   in reply to (W._Fowler)
    Not a problem Wayne,
    I think you know that we are just end-users like yourself. We're here
    because we like the products and feel that if we can figure out the bugs
    associated with them etc... Adobe will continue to improve on them etc.
    It's not a perfect world, but we'll work on it... and have it fixed for
    tomorrow ;)
    Cheers
1 2 3 Previous Next
Actions
