Hi
I have 64 bit SP1 and have been running Elements 2 (YES 2) for nearly a year with no problems can anyone explain that ??
However I have been thinking of upgrading to version 7, but after reading all of your comments I think I will stick to the horse and cart version.
Just to let you know I have also asked this question of "customer support" and I am still waiting for an answer - it's enough to make you want to rush out and buy Paint Shop and a mac !!
It's been very interesting reading your comments thanks for your help, looks like you have saved me a lot of trouble.
Bob
I have just received my "answer" from Adobe and to assist this forum I have copied it in red below.
Photoshop Elements 7 is not certified to run on Windows Vista 64 bit
systems, so we can not guarantee that this will work.
It may be that the applications works without issues, but it may also be
that this will not run correctly.
We can offer support if you encounter issues, but only to the extend
that we know it is the 64 bit system causing the issue.
Have a nice day.
Considering that Adobe makes the best photo software in the world you would think that accommodating 64 bit Vista would not be too much of a problem.
In any case it looks like Adobe have / will totally ignore 64 bit machines at present, which is just not good enough really.
By the way, if Adobe is reading this (I doubt it) have a nice day to you too !!!!!!!!!!!!!
Bob
Have a nice day.
Bob
I think Adobe's marketing practices with respect to Vista 64 are deceptive.
They have a distribution agreement with Dell, selling PSE 7 pre-installed on Vista 64 systems, e.g. the XPS 630. They don't have an asterisk in the Dell shopping cart telling customers that Adobe won't support PSE 7, and a customer would have a quite reasonable expectation that PSE is supported. I wonder if Dell knows that Adobe isn't supporting the pre-installed PSE?
Nowhere on Adobe's site do they say that PSE 7 is not supported on Vista 64. The System Requirements page says:
Most typical users aren't going to interpret this as meaning that Vista 32 is required to receive support. They won't have a clue as to what "Certified for 32-bit version of Windows" means. If Adobe cared about its customers, it would just state plainly and clearly that Vista 32 is required. For example, Nikon states clearly that the drivers for its popular Coolscan scanners require Vista 32.
This is typical of marketers trying to have it both ways. If the product had a bigger customer base, it would be fodder for slimy class-action lawyers.
We can offer support if you encounter issues, but only to the extend that we know it is the 64 bit system causing the issue.
If this is precisely what they said in your reply, this makes no sense. I think what the support person meant was that they would provide support only to the extent that they know it is not the 64-bit system causing the issue.
I envy all of you who have been able to get PSE7 installed on your 64 bit Vista system at all... I can't even get that far.
I am able to run the installation, and after going through the process it says the program installed successfully. But many key program files and folders (including the program .exe files themselves) are not there. The start menu links and other shortcuts that the install spawns are "missing shortcuts" that cannot find the target.
I've tried all the tricks to try to get this to install: installing in both the 64 and 32 bit program folders, installing from the desktop, running the setup as administrator, installing to the drive root, disabling all anti virus and other running programs, etc. with no success.
Adobe support only gives me the same line about how the product is not supported by the 64 bit version (nice to learn that now-- the box said it is Vista compatible and makes no mention of a 64 bit limitation).
Before I return this brand new (three day old) computer to the manufacturer and exchange it for a 32 bit version (and settling for only 3 gigs of ram), anyone have any advice on how you were able to even get Photoshop Elements 7 to install at all?
On my Dell Vista 64, it just installed straight from the file I downloaded from the Adobe store, which I had placed on the desktop.
Some suggestions:
1. Download the free trial of PSE 7 and see if that installs correctly. If it does, that at least tells you how to get an installation to work. But you won't be able to enter your serial number into that trial -- it only accepts serial numbers that you purchased through the Buy It button the in the program. You may be able to persuade Adobe Customer Service to give you a download through the store.
2. Uninstall PSE and then manually remove all traces left behind by the uninstaller:
http://www.johnrellis.com/psedbtool/photoshopelements-6-7-faq.htm#_Rem oving_all_traces
Then reinstall by copying to the desktop and running as administrator.
That is particularly sleazy marketing on Adobe's part. They even have a distribution agreement with Dell to sell PSE 7 preinstalled on Dell Vista 64 systems (for which there isn't an option to get Vista 32 preinstalled). If it were a bigger market, there'd surely be a class-action lawsuit.
Thanks for the input, John.
I just downloaded the Trial version at your suggestion, and it installs flawlessly and runs beautifully on my system. So I know there's no technical or logical reason why my purchased product shouldn't do the same. As you mentioned, the download version won't accept my box serial number, so this is at best a temporary fix, but a fix nonethless. (Is Elements 8.0 is coming out anytime soon... and will it have 64bit support?)
Same with HP, which is where I purchased mine. In fact, they give the option to have Elements preinstalled on this very computer I am having this problem with. So I don't buy for one second their statement that Elements is unable to run on 64 bit computers.
I am wondering, then, if my installation woes may not necessarily be a 64 issue, but a licensing issue; since I had previously had this copy of Elements installed and registered on my previous computer (an XP). That computer suffered a horrible death, so I was not able to uninstall or deauthorize Elements or anything like that. Could that have anything to do with my problem, and if so is there a workaround?
Previous Windows versions have come out at the very end of September. Whether Adobe provides support for PSE 8 on Vista 64 and/or Windows 7 64-bit, who knows. Microsoft is really pushing hard on 64-bit in Windows 7, and all versions (except Home Basic) allow the user to choose between 32- or 64-bit at installation. I'll bet we'll see a lot more new computers preconfigured with 64-bit Windows 7. So if Adobe were still investing in PSE development, you'd expect that they would of course support PSE 8 on Windows 7 64-bit.
Unlike full Photoshop, PSE doesn't require "activation" of a serial number -- it doesn't phone home to the mothership for permission. So there's no need for deauthorization either.
Now that you successfully installed the trial, you might try uninstalling and installing the CD version (from the desktop).
BINGO. That did it.
After installing and running the Trial download, I decided to try to install my purchased product to see what happens. It prompted me that I must first uninstall my previous installation (the trial), which I did. I then ran the setup straight off the disc, it installed, all the necessary files are in place, and the full program launches and runs without a hitch!
Guess I just needed the direct-install from the download version to "prime the system" before it allowed me to successfully use the CD version. Weird.
Thanks again for all your help. My headache from the past couple days is finally gone, and I am very happy with my new computer now. ![]()
I have been using PSE for years. Running vista Home Premium 64 bit. Started having trouble with ver 6 , bought ver 7 and have a trial of ver 8. I uninstalled ver 6, but having alot of problems with ver 7. It takes forever to perform an editing function. No problems with the trial version of ver 8 however. Is version 8 compatible with windows 64 bit ? Is therre soomething I can do to make ver 7 work properly ?
thanks !
North America
Asia Pacific
