Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Cocomo and Ajax
Avatar
Level 2
Currently Cocomo is used primarily as a realtime data
exchange engine for Flash/Flex; can it
also be leveraged by Ajax web sites/apps ? Using client-side
frameworks like Smartclient,
Javeline, Dojo, Cappuccino, etc. ?
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Hi VerlSnake,
At its core, Cocomo is intended as a Flash/Flex technology -
for instance VoIP and WebCam video isn't supported in Ajax - so we
focused most on making sure that development model made sense. We
also currently run exclusively with the bi-directional persistent
sockets provided by the Flash Player (RTMPs). In the longer-term, I
can see cases where embedding Cocomo in Ajax might make sense, but
for now our focus is really improving what we've got in Flash.
thanks
nigel
View solution in original post
1 Reply
Avatar
Correct answer by
Hi VerlSnake,
thanks
nigel
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
