Not enough ram?
Dec 9, 2008 4:28 PM
I am using CS4 on a 8 Core 3ghz Mac Pro with 16gb ram and a scratch disk consisting of 6 x 36gb Cheetah 15k III's striped in a RAID 0. I have my ram set 100%, cache 4 and 40 history states. I have been using CS4 for a couple of weeks and I have been getting this error message " Could not complete your request because there is not enough memory". This happens on files that are only around 60gb with about 5-7 layers. It will happen with the quick mask selection tool or when I try to use content aware scaling or even open up a camera raw smart object. I have tried trashing the preferences but that has not fixed the issue. I don't have this issue with CS3. Anyone else run into this issue with CS4?
Steve
    Dec 9, 2008 4:45 PM   in reply to (steve_peters)
    I am guessing that you don't really mean 60 GB ?!
    Have you tried putting your Scratch on a separate partition on a single (non-RAID) internal HD?
    And even though you have 16GB of RAM, you might try turning back the memory allocation in Photoshop to 90%
  • Pierre Courtejoie
    Jan 11, 2006
    Dec 10, 2008 4:37 AM   in reply to (steve_peters)
    Try less ram allocation.
  • Ramón G Castañeda
    Jul 27, 2006
    Dec 10, 2008 5:57 AM   in reply to (steve_peters)
    Both Ann and Pierre are right. Lower the RAM allowance.
    If you get used to think of it in terms of memory allowance, which it is, rather than RAM allocation, which it is not, it will be easier to remember that it represent the maximum amount of available memory that is left after the OS and other running applications and processes have grabbed whatever memory they need.
    Setting at 90%, you're still allowing Photoshop to access well over 10, 12 or more GB of RAM, more than it can actually use. But you're not "allocating" or "reserving" any amount of RAM, you're only telling Photoshop not to use more than 90% of whatever is available at any given time.
    Surely you agree that's reasonable?
  • Ramón G Castañeda
    Jul 27, 2006
    Dec 10, 2008 1:23 PM   in reply to (steve_peters)
    >Is CS4 using ram differently than CS3?
    No.
    >I have seen test's showing that if you have over 4gb of ram you should have it at 100%
    Probably misconstrued them, or they're recommending bull.
