Photoshop CS3 can't do lowercase type-only large and small caps
Mar 28, 2009 4:53 AM
Photoshop CS3, G5 PowerMac Dual 2GHz w/ 7GB RAM
A weird Photoshop problem: using the type tool, I can only produce type in large-and-small-caps, as opposed to upper and lower case. I can't generate any lowercase text. I've tried all the usual diagnostic tools: trashing the prefs seemed to work at first, but it's destructive of other stuff I don't want to lose, and anyway the problem came back after a while. I tried the Phantom User, and learned that the problem is tied to my User Identity, i.e., the problem doesn't exist in other User identities, but how do I make use of that information? I considered migrating to a new user identity, but I would have to go through every single appliciation, blah blah blah. So: does anybody have a quick, elegant solution to this, or is this a problem that has suddenly cropped up elsewhere? I'm not crippled by it, thanks to Illustrator CS3, but it's a convenience that I miss. And how do I trash the PS prefs without losing my brush tool presets?
    Mar 28, 2009 6:26 AM   in reply to (Birck_Cox)
    Birck,<br />>trashing the prefs seemed to work at first, but it's destructive of other stuff I don't want to lose,<br /><br />What "destruction" are you talking about?<br />>and anyway the problem came back after a while.<br /><br />I assume this happens with fonts other than those (such as Trajan Std) that were designed with just caps and small caps. It sounds like it may be a duplicate or corrupted font issue. Did you use a good font manager to check for duplicate or corrupted fonts? Did you clear font caches (with Cocktail)?<br />> tried the Phantom User,<br /><br />I see a black mask, cape and scary organ music here. <g> If logging in as a new user clears the problem, you may have a corrupted user identity and should stop using it.<br /><br />Neil
    Mar 28, 2009 7:28 AM   in reply to (Birck_Cox)
    Birck
    Did you check to see that you did not inadvertently select the All Caps option from the flyout menu in Text mode (the one to the right of the Character and Paragraph tabs). Or, the shortcut shift-command-K, which does the same thing?
    Rafael
    Edited for typo
    Mar 28, 2009 8:06 AM   in reply to (Birck_Cox)
    sounds like he has the small caps checked in the character panel.
