Photoshop Will Not Start
Apr 16, 2008 11:47 AM
I am using a G5 2.5 quad with 8gb RAM running 10.5.2. This machine runs 24/7.
I use Photoshop CS3. (10.0.1)
Today when I started Photoshop it would not load and gave an error message box that says, " The application Adobe Photoshop CS3 quit unexpectedly. Mac OS X and other applications are not affected. Click Relaunch to launch the application again. Click Report to see more details or send a report to Apple."
The Report Reads as follows:
Process: Adobe Photoshop CS3 [466]
Path: /Applications/Adobe Photoshop CS3/Adobe Photoshop CS3.app/Contents/MacOS/Adobe Photoshop CS3
Identifier: com.adobe.Photoshop
Version: ??? (???)
Code Type: PPC (Native)
Parent Process: launchd [84]
Date/Time: 2008-04-16 15:07:24.231 -0400
OS Version: Mac OS X 10.5.2 (9C7010)
Report Version: 6
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x000000008fe0105c
Crashed Thread: 0
Dyld Error Message:
Library not loaded: @executable_path/../Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
Referenced from: /Applications/Adobe Photoshop CS3/Adobe Photoshop CS3.app/Contents/MacOS/Adobe Photoshop CS3
Reason: image not found
I tried holding down option, command and shift when starting in order to re-set preferences--no luck.
I have tried Disk Warrior, repair permissions, Onyx to clean caches--no luck.
When I try to use the uninstaller, I get the error message "This software cannot be installed because the file system of the OS volume is not supported."
What can I try next?
