CS3 installs but won't run
Oct 17, 2007 8:48 AM
Ok - not sure if this goes in this section or not.. but it's a technical question.
My b/f bought me a Dell Laptop last week. It has the recommended minimum of everything adobe says it needs for photoshop CS3 (see below for 1721 specs)
When I installed it on the laptop - it was slow, but said it installed. But when I go to open up Photoshop, it opens the screen - and then just hangs. After about 5 minutes it says not responding and I close it. Any of the other programs that came with won't even get that far. I click on them and it gives the little "thinking" circle (as I call it.. lol) and then nothing.
I have read that CS3 has issues with Vista - but their site says the home premium should work. I've also read about 64 bit issues.. but the OS is 32 bit - so it's capable of running 32bit systems... I guess.
I called adobe yesterday after installing and reinstalling CS3 15+ times... with the same issue. I was on the phone for about 2 hours with them. Basically - they have NO CLUE what it would be since it installs fine and opens with no error messages. I checked the log files and there is nothing in there I see that says any kind of error.
I have disable windows defender, uninstalled McAfee and google desktop (all are known to cause issues with CS3), I have ALL non MS startup services turned off.. I have turned off the MS users control.. all suggested by the adobe tech.
I have installed using the run as administrator. Nothing. Created a new admin account and installed on that user and opened on reg admin account. Nothing. (again typical things that correct cs3 install issues)
The last thing the guy said was that it might be a video issue. I checked and there aren't any issues mentioned and no driver updates listed.
We tryed installing this on my b/f's laptop. He bought the exact one I have (except his is red.. mine blue.. lol) and it does the EXACT same thing...
So today we called dell. they say it's a software issue and won't answer any questions for free. Apparently only hardware support is free... But they won't accept this is a hardware conflict with the software..
errrrr
Anybody have any clues on this?
LAPTOP SPECS:
Inspiron 1721 Notebook: AMD Turion 64 X2 Mobile Technology TL-56 (1MB/1.8GHz) Genuine Windows Vista Home Premium
Operating System
Memory
2 GB DDR2 SDRAM 677MHz (2 DIMMs)
Hard Disk Drive
120 GB SATA Hard Drive (5400 RPM)
Video
ATI RADEON Xpress1270 HyperMemory
Media Bay
8X DVD +/- RW w/dbl layer write capability
Base
Bluetooth Wireless
Bluetooth Wireless Card 355
Software Upgrade
Microsoft Works 8.5
Premium Pack - Advanced Photo+Music: Deluxe Pack + Paint Shop Pro XI
NoteBook Screen
17 inch WXGA+ TrueLife Glossy Notebook Screen
Hardware Upgrade
No Camera
6 Cell Primary Battery
90W AC Adapter
Network Interface Card
Dell 1505 Wireless-N
Replies 1 2 Previous Next
    Oct 17, 2007 9:42 AM   in reply to (mjae69)
    Are you installing from a DVD? Take the Photoshop folder and copy it to the HDD, and run Setup from there.
    Downloaded product? Unzip to the HDD and again run setup. I.o.w. don't run setup from within the zipped archive, unzip first.
    I also remember this: when I first installed CS3 it took a while. I also thought it had frozen. But after a while the progression bars (what's in a word) moved further.
    When I reinstalled CS3 a while ago, after a mainboard upgrade I was convinced it had stopped, so I tried to kill the process, got the "not responding" dialog, killed that, and suddenly the installation got through.
    Try to monitor both processor activity (task manager) as well as HDD read/write activity. When the thing looks stalled either of them should max out.
    If neither does anything then indeed the computer has effectively stopped.
    Rob
    Oct 17, 2007 5:03 PM   in reply to (mjae69)
    There is no incompatibility between Photoshop CS3 and AMD processors. And Microsoft has officially sanctioned downgrading from Vista to XP, and Dell makes this available; google [vista xp downgrade site:dell.com].
    Oct 18, 2007 7:39 PM   in reply to (mjae69)
    So Dell won't support you if you modify the system. They aren't exactly supporting you now, with an unmodified system, are they?
    Oct 20, 2007 5:15 PM   in reply to (mjae69)
    hey there. you are not alone. i just got my 1721 and had the similar problems. my situations is i can install cs3 smoothly (mine is web premium). i can open photoshop and work ok. the only thing is when i try to close photoshop, it freezes. at first i just force-quited but then i did a some experiment-- i wait. i found that it would close eventually--may be 6 hours X__X. same thing happens to illustrator and dream weaver. you can try this -- just wait. the only program works perfectly is flash cs3, but maybe i am wrong.
    i found some threads saying that 4G ram can solve this problem... just want to say WTF...
    i am so depressed because i bought 1721 for my new job....
    i am planning on install xp by myself at my own risk...sign..
    good luck . tell me what you think
    thanks
    Oct 20, 2007 10:10 PM   in reply to (mjae69)
    PSCS3 installs and runs fine on my AMD 64X2 4600+ CPU and on many others' rigs using AMD. It's very dubious that the AMD chip is the problem. Do you have an antivirus running (e.g., Norton, which comes as a free trial on most Dells? Turn it off for the install. Make sure you are running the installer from an admin account. Kill all of the crapware. Make sure jscript.dll is registered (do a forum search). Turn off UAC. Then run the installer.
    Oct 20, 2007 11:05 PM   in reply to (mjae69)
    I just got it for a week... hope its not because of AMD/ATI issue...
    please let me know if a 1720 solves your problem...
    thanks
    Oct 20, 2007 11:10 PM   in reply to (mjae69)
    and mine is TL-60 2.0GHz
    Oct 21, 2007 12:43 AM   in reply to (mjae69)
    I don't know about elsewhere, but new Dells in UK come not only with a load of useless trial-ware but also Dell-specific programs and services like Network Monitor and other superfluous carp which run in the background,
    Best advice is wipe the HD and reinstall the OS.
    Edit: Unless you think that will invalidate the warranty too!
    Oct 21, 2007 8:46 AM   in reply to (mjae69)
    My bro has an Acer with AMD Turion 64 X2 Mobile Technology TL-56 and 2 gig ram. Adobe cs3 runs perfectly on his system. I am going to reinstall the OS as John suggested. I will post the result later.
    ps. oh mine..they did not give me the driver disc...
    Oct 21, 2007 8:55 AM   in reply to (mjae69)
    Most Dells come standard without an OS disk. Unless the OP asked for the OS disk when ordering, the only option is to reinstall the original configuration complete with crapware. There may be a way to create an OS disk, but otherwise a clean OS install isn't readily done. However, you can run Crapware Cleaner (google it) to get rid of the junk, which may help.
    Oct 21, 2007 9:02 AM   in reply to (mjae69)
    Easy to be wise after the event but on most models you can add an OS disk when you order.
    Oct 21, 2007 9:54 AM   in reply to Michael D Sullivan
    The pendulum has swung back the other way. Most of them are shipping
    WITH the O/S disk again.
    Bob
    Oct 21, 2007 1:22 PM   in reply to (mjae69)
    I tried to install a clean Vista today. Guess what, CS3 is working now!!
    Thus, there is some crapware affecting CS3... I will run some tests later. I will let you know if I find out which one is.
    Good for you , Dell.
    Oct 22, 2007 7:27 PM   in reply to (mjae69)
    Running AMD dual core and ATI Radeon X1900...no problems with CS3 since updating drivers for the ATI...
    Oct 24, 2007 11:38 AM   in reply to (mjae69)
    Hi I have the exact same problem with a bit of a twist and CS3 won't even install properly. I spent hours on the phone to Adobe and they couldn't solve the problem either. I am glad you confirmed my suspicions. First I'd like to say "Welcome to the world of I T ....point the finger game." This is where nobody wants to take responsibility for problems.
    The difference in my story is that I bought a copy from Adobe who was shipping me the package and advised me to download the trial version which is exactly the same but with a time limit of 30 days. I tried and tried to install and even with their help it was hopeless.
    I suspect that there is some minor problem with the AMD 64 bit platform or big surprise the Windows OS. Why I suspect there is a conflict somewhere between the platform and the OS is that when I migrated to the 64 bit platform I could not just drop in my HD from the last machine I built. I had to do a complete reinstall and migrate data manually and there were still problems. Hence I went to Windows Vista Ultimate which has only given me minor problems such as the one we are both experiencing now.
    I would suggest going to AMD directly and at least reporting the problem to see if they have a solution or can work on a BIOS revision. Microsoft and Intel sleep with each other and I suspect that if you had an intel 64 bit chip this would not be an issue as their developers work together. Having said that however it's always a crap shoot when new technology meets new software.
    You can try disabling all the TSR's and preloads by going to MSCONFIG and shutting them down. Reboot and reload CS3. In truth I don't know whether this will work but atleast it allows you to install in a clean invironment. Who knows. If that does not work. Uninstall the CS3 and reset you CONFIG to as it was. If it does work you can go back in and do the same with CS3 installed and hopefully running.
    As for me well I have MAC as well and I am going to use the MAC version. I cancelled my order from Adobe for the Windows version.
    Good luck with your problem. I hope you find a solution.
    Cheers,
    Scott Smith
    Nov 4, 2007 1:55 AM   in reply to (mjae69)
    Reinstalled Vista Home Premium but CS3 still nut running.
    Now also Google Earth only runs in OpenGL mode.
    It appears that during the reinstall the driver for the ATI Radeaon Xpress 1270 video card was not installed, just a standard VGA driver.
    Can't find on the Dell website a driver for the Radeaon Xpress 1270 and Vista Home Premium.
    I'm wondering if the CS3 problem is also related to the missing video driver.
    Nov 5, 2007 7:36 AM   in reply to (mjae69)
    Just installed the proper driver for the ATI Radeaon Xpress 1270 video card but CS3 InDesign is still not running. It actual runs, but somehow only in the background nothing is written to the screen.
    I'm at a loss how Adobe can promote CS3 as Vista compliant considering all the problems users report.
    Nov 5, 2007 8:41 AM   in reply to (mjae69)
    Just spoke to Adobe Support and they feel that the Dell OEM version of Vista Home Premium is causing the problem.
    Adobe and Dell suggest that I buy a full version of Vista and install it on the Dell Inspiron 1721 in order to run CS3 InDesign.
    ginggogo, did you reinstall Vista from the Dell supplied CD with the OEM version or a standard MS Vista? Which version?
    Nov 5, 2007 8:53 AM   in reply to (felice)
    That sounds like a load of rubbish. The machine likely came with a
    Windows DVD. Just do a clean install of Windows using that disk. Even if
    it says recovery on it, it's not. It's a full version of Windows.
    OEM Windows images have always been a bit flakey and my advice has
    always been to do a clean install on a a mission critical machine.
    Bob
    Nov 19, 2007 10:48 AM   in reply to (mjae69)
    Nov 19, 2007 10:56 AM   in reply to (mjae69)
    >>The machine likely came with a Windows DVD. Just do a clean install of Windows using that disk.
    That's exactly what I did. But some Adobe CS3 products will not run, like InDesign.
    Felice
    Dec 10, 2007 6:40 PM   in reply to (mjae69)
    I just purchased a 1721 from Dell with Vista, of course. Tried to install Photoshop CS3 and InDesign CS3. After several tries they both installed successfully, or so I thought. As I attempted to run the programs, both reported an error. The report stated that I needed to uninstall then reinstall the programs or contact my IT admin.
    After searching the web, found this string of notes. Appears there is no known solution yet.
    Sorry I can't offer that solution. I do share your pain, however.
    Matt
    Dec 11, 2007 5:33 AM   in reply to (Matt_Graf)
    See my earlier post. I'd never use an OEM image for production.
    A clean install of Windows (whatever version) is the best way to go.
    Bob
    Dec 18, 2007 8:56 AM   in reply to (mjae69)
    I find that if you using the AHCI mode( in bios setting).
    It will cause above problem.
    E.g. no responses after installation or at first time running adobe program.
    Can not seen the activation page
    no responses when closing adobe program.
    If you change to native IDE mode in bios, it seen ok.
    I had try to install a new windows a month and it can't activation again.
    Since I change to native IDE mode in my bios, no problem find again.
    It is why AMD will get more problem that intel.
    Most of AMD chip support AHCI.
    but in Intel just high-end model support AHCI.
    Could any one help me to report to Adobe about this issue?
    I hope it can fix all of the problem you get.
    Thanks a lot,
    Michael Tse
    Dec 30, 2007 6:09 PM   in reply to (mjae69)
    I also have a 1721 and experienced the install but won't run problem. I reinstalled Vista from a retail disk (used the license key that came with the computer) and now everything works just fine. I guess the problem is with the OEM version. I think you can install the os from any vista dvd and just use your key (on the bottom of the computer). You may have to call microsoft to confirm that you are reinstalling and not pirating the software.
    Good Luck.
    Mar 12, 2008 7:40 AM   in reply to (mjae69)
    Update:
    I purchased from Microsoft Windows Vista Ultimate, reformatted the hard disks of the Inspiron 1721, installed Vista, and then on the "virgine" system installed the newly downloaded trial version of Adobe CS3 InDesign , Phtotshop, and Dreamweaver.
    Installation was problem free. Start of InDesign, Photoshop and Dreamweaver also worked well. Registering the trial versions caused the first extended hang of the software, but finally cleared. But then the problems started. Neither Photoshop nor Dreamweaver could be closed. Had to stop the process. InDesign closed but could not be started again - the process was still hanging. Clearing the process allowed a fresh start of InDesign. After half an hour InDesign crashed fatally:
    Error: "The licensing subsystem has failed catastrophically".
    Removed InDesign, reinstalled it again. Now it does not start anymore. But the process is running in the background.
    Could there be a conflict between the Insprion 1721 hardware and the FLEXnet licensing service used by Adobe?
    Dell tech support, who recommended I buy the original Vista Ultimate version, tells me that they can not help me any further.
    Is anyone at Adobe reading this? Are there known issues with CS3 and the Inspiron 1721?
    Mar 12, 2008 8:42 AM   in reply to (mjae69)
    I don't think it's a problem with the 1721. My install of CS3 has been problem free for 3 months. As stated above I used the retail version of windows. I did however install Adobe Web Premium CS3 from the disk (not from the downloaded version) and it doesn't include InDesign. Maybe the problem is with InDesign or registering the downloaded version?
    I'm sorry you are still having these issues, I really hoped my solution above was going to work for you. If I find anything I'll come back and post again.
    Mar 14, 2008 2:27 AM   in reply to (mjae69)
    On the Dell Forum I received the following excellent hint:
    I had a similar problem with the Adobe Elements software. The solution that I found was to download and install the patch on this page http://www.adobe.com/support/downloads/detail.jsp?ftpID=3750 for adobe acrobat and this fixed the problems with the Adobe software.
    I have subsequently installed photoshop CS3 and it runs without any problems.
    Even though the patch is listed as for Adobe Acrobat it seems to fix a licensing problem common to all of their software.
    http://www.dellcommunity.com/supportforums/board/message?board.id=sw_o ther&message.id=64916&jump=true#M64916
    My reply:
    Hi Belmana
    Thanks for the excellent hint. It appears it solved the problem somehow. When I start now a CS3 application it takes a little longer and the programme seems to search for something. After a minute or so InDesign pops up the trial license screen and then continues fine. When I start Dreamweaver it also takes 1 minute of searching something, but then it pops up a log-in screen to another PC on the LAN! Clicking cancel the process continues and after a minute or so the trial license screen appears. After that everything seems to work fine, even closing the application is now working properly (with some slight delays).
    I'm glad you found this trick. I hope it helps others too. And I hope Adobe releases a patch that functions 100%.
    Apr 27, 2008 5:35 AM   in reply to (mjae69)
    FOR ALL THOSE THAT HAVE THE SAME ISSUE WITH WINDOWS XP
    1. Choose Start > Control Panel, or Start > Settings > Control Panel.
    2. Open the Administrative Tools Control Panel.
    3. Double click "Services".
    4. Scroll down to the FLEXnet Licensing Service on the list of services and double-click the service to open its properties.
    5. Right click one the name FLEXnet Licensing Service and choose Properties
    6. Change the Startup type to Manual
    7. Click Apply
    8. Click the Start button to start the service.
    9. Click Apply, then OK. Close Services, Administrative Tools, and the Control Panel.
    10. Relaunch your CS3 application.
    Thaken from http://kb.adobe.com/selfservice/viewContent.do?externalId=kb401528
    It worked for me.. hope it will help others.
    Cheers
    That
    Apr 27, 2008 10:22 AM   in reply to (mjae69)
    would that it were. that's ONE solution that works for SOME people. the problem is, there are 4 or 5 (or more) solutions and no one seems to be the cure all. someone (adobe) should collect them all into a kb article.
    May 13, 2008 2:13 PM   in reply to (mjae69)
    Found fix for "installs but won't run."
    You have to activate the hidden windows Vista Administrator befre you install the program. Go to:
    http://www.vistaadobe.com/main/viewtopic.php?f=4&t=6&p=25#p25
    Oct 6, 2008 12:01 PM   in reply to (mjae69)
    Easy fix guys and gals, and this is assuming that everybody is using vista, you don't need to download anything new to get it to work, go into your control panel, find your programs and features, then find the program called edata security management, and uninstall that program. Presto, you can now open your CS3.
    Sincerely yours,
    00101, Ace technician
    Nov 3, 2008 10:57 AM   in reply to (mjae69)
    I would like to second the "fix" of changing the AHCI mode in the bios. New HP 6735b, Turion 64 x2 RM-70 processor. Factory image of XP (we don't do Vista). Installs okay, runs - not okay. Changed from AHCI to IDE for the Sata settings in Bios, and it worked fine after that.
1 2 Previous Next
Actions
