Photoshop CS4 Clone Stamp Tool behavior
Oct 22, 2008 7:28 PM
I installed CS4 on a Dual Pentium Xeon 2.4ghz Compaq W8000 system with 3GB of RD 800mhz RAM and Windows XP Pro w/SP3 and all updates. The video card is a ATI Radion AGP-3855 w/512 GDDR3 RAM with latest drivers.
When using the clone stamp tool, after making a sourse selection there is a "trail" that follows the cursor to the destination (similar to using a mouse trail so you can tell where the cursor is on a notebook computer)
When the cursor slows down at the stamp destination the "trail" catches up and covers the destination with the sourse "patch" not allowing precise targeting. It is so cumbersome to use as to make the clone stamp tool almost unusable. The density of the "patch" is not affected by opacity settings.
Is this a new behaviour for this tool in CS4? And if so can it be turned off? Do I have a problem unique to my system?
Murray
    Oct 22, 2008 10:21 PM   in reply to (Murray_O\'Neill)
    Open the clone source panel. Uncheck 'Show Overlay'.
    Oct 25, 2008 10:39 AM   in reply to (Murray_O\'Neill)
    Murray I suppose that the old saying about "ones man's meat is another man's poison" is alive a kicking.
    I was disappointed that the 'patch' feature was not included in CS3 and was really pleased that it was a feature in CS4. (I even put in a feature request for it on the CS3 beta pages at the time, having found it really useful in the vanishing point filter.) I would agree that the degree of opacity is not shown in the patch - which would be a good idea - but seeing the spread and the degree of hardness or softness of the patch is a real boon.
    At least it can be turned on and off, so everyone is happy.
    Anthony.
    Dec 14, 2008 5:36 AM   in reply to (Murray_O\'Neill)
    Hi guys,
    I am also having cloning problems in CS4. I have this bright spot that won't let me clone my source point. Anyone experiencing a similar problem?
    Chloe
    Dec 14, 2008 6:26 AM   in reply to (Murray_O\'Neill)
    Can you be more explicit or post a screen shot of the bright spot?
    Dec 14, 2008 3:26 PM   in reply to (Murray_O\'Neill)
    > Hi guys,
    Could the bright spot be the previous selection of the clone source? Until you alt-click to select a new clone source, the old selection remains showing.
    Anthony.
    Dec 15, 2008 8:33 AM   in reply to (Murray_O\'Neill)
    Hi Anthony and John,
    Thanks for your help on this. For some reason, even when I alt-click, it won't let me make a new selection.
    I'm not on my home computer at the moment so I can't do a screen shot, but basically, the spot that normally makes a selection is whited out and does not change with an alt-click.
    To make things worse, a red star keeps appearing and I end up rotating my images with it unintentionally. Does anyone know what this is.
    It's a nightmare, I've got some images to edit for a client and I can't even get my basic adjustments working.
    Please help!
    Chloë
    Dec 15, 2008 10:20 AM   in reply to (Murray_O\'Neill)
    Try resetting your preferences as described in the FAQ.
    http://www.adobeforums.com/webx/.ef4a07f/1
    You either have to physically delete (or rename) the preference files or, if using the Alt, Ctrl, and Shift method, be sure that you get a confirmation dialog.
    This resets all settings in Photoshop to factory defaults.
    Dec 15, 2008 11:14 AM   in reply to (Murray_O\'Neill)
    Thanks John, I'll try that.
    Dec 16, 2008 9:07 AM   in reply to (Murray_O\'Neill)
    Murray O'Neill said
    >My immediate problem was that overlay was on as a default and it was not obvious to me where to address it.
    I understand that overlay is always on by default and you have to turn it off each time. Is there any way to set it permanently off by default? I have to say I don't like it, because I can't really see what I am doing and it noticeably slows down the painting.
    Dec 16, 2008 10:07 AM   in reply to (Murray_O\'Neill)
    Thanks Murray.
    Dec 31, 2008 10:23 AM   in reply to (Murray_O\'Neill)
    My CS4 clone stamp tool is all over the page. It will work for a while and then like in a drunken stooper will randomly start placing streaks and spots where ever it feels like it. It is also happening with the brush tool. I tried changing features in the clone source menu but nothing helps. Please help, my workload is mounting.
    Feb 23, 2009 2:13 PM   in reply to (Murray_O\'Neill)
    I am having tremendous problems also. I have a macbook, and have had cs4 for a few months now with no problems...the clone stamp is the tool that i use most often, and for some reason it stopped working today. I can't get it to do anything. I don't know if it has anything to do with this, but i opened a new adjustment layer to change saturation on the photo, when i was finished i clicked the clone stamp and it wouldn't work. I have checked to make sure quickmask is turned off, i have made sure it is on the right layer, i don't know what it could be
    Please help
    Shannon
    Feb 24, 2009 7:49 AM   in reply to (Murray_O\'Neill)
    Shannon, your mention of Macbook makes me think you want to be in the Mac side of the forum, not Windows. And both you and Kevin might see your problems fixed by deleting preferences ... the Win method is listed in our FAQ. There is probably a different method for Mac.
    Nov 10, 2009 11:40 AM   in reply to (Murray_O\'Neill)
    THank you. I called adobe to ask this and they said it couldn't be turned off, I knew it could, just forgot how. Thankyou thankyou thankyou
