OK, I have the same problem. Sorry my vocabulary, but this is a stupid problem with a stupid solution. The only solution I found was this:
http://kb2.adobe.com/cps/409/kb409119.html
Solution 6:
I don't know exactly what caused this problem, but I think that is related with the ICC profiles. When I found the real cause, I will tell you.
That solution simply created a new vesion of the document but without the data that was causing the printer error.
It may just have been one bad file.
I have been using old versions and change setting in my system then it is not working because of old that is not compatible with my system. Ricoh printer has approached to install a new version to fix the problem
I was getting this message periodically. I ran the troubleshooter on my printer and for some reason the print spooler was not starting automatically. Troubleshooter "fixed" the problem and I was able to print.
QUICK SOLUTION. Had this same problem of needing to install the printer even though my printer printed fine for other docs. But I noticed that some CS4 files were able to print while others not. So I simply opened another few file, split screened the two docs, and simply copied the old layers to the new doc. During the process, I confirmed that the new doc showed printer properties window when promted to print. So wala! Problem solved! This will save you some serious time. : ) Just got an urge to share that Jesus loves you very much. Me too. : )
This is old, but it actually works! hanks BOB
